05-25-2020, 09:38 AM | #1 |
F36 GC
143
Rep 259
Anyone running 275/35/19 Rear on 19x10 et 45???
Hey all,
Trying to decide between 265/35/19 and 275/35/19 for the rear with my new wheels. Car is 2015 435 GC M sport Wheels are 19x10 et 45 custom concavity Vossen. Also tire is going to be Michelin Pilot Sport 4s. EDIT: Anyone running the 275/35/19 with 19x10 with that offset or similar? Any rubbing? Thanks for any help, Chase Last edited by ozymandias435; 05-25-2020 at 10:06 AM.. |
05-25-2020, 10:01 AM | #2 |
Rep 278
Drives: 13 f30 335i Msport
what is your question or concern? I have that size on my car. rim size is 19 x 9.5 though. et20. I get some rubbing if I have people in the back.
13 f30 335i < 08 e92 335i < 04 Subaru WRX
05-25-2020, 10:05 AM | #3 | |
F36 GC
143
Rep 259
Will the 275 35 fit without rubbing on the 19x10 et 45 or similar offset |
05-25-2020, 09:53 PM | #4 |
Rep 3,190
275/35/19 will be no issue with 10" et 45. The stock M3/4 rear rims are et 40 and I have no issues on a stock 340i. Et 45 would be less aggressive.
alohasurftoad3122.50 ozymandias435142.50 |
05-26-2020, 06:05 AM | #5 |
F36 GC
143
Rep 259
05-26-2020, 09:28 AM | #6 |
Rep 3,190
I haven't taken any pictures, but with et 45 I'd expect no poke, flush with fender.
05-28-2020, 03:41 PM | #7 | |
Rep 133
Drives: F32 435dx
I also have the stock M4 M437 wheels on a stock 435dx and no problem at all. The ET45 wheels will poke less from the fender. You can also check on the willtheyfit.com site. They have a free calculator. Here's what I got for the comparison you want: LINK |
10-14-2023, 11:05 AM | #11 |
Rep 87
i am running 275/35r19 19x9.5 et 45... i tried a 5mm spacer and rubbed.. not sure i would even attempt et 35
2015 335i M Sport EBII
M Perf Exhaust / M Perf Brakes / M Perf LSD / CTS FMIC / CTS Intake / CTS DP / CTS CP / BM3 / KWV3 / Vorshlag Camber Plates / 19" VMR V710FF / XHP stage 3 / Snow Perf stage 3 meth |
10-15-2023, 10:58 AM | #12 |
Rep 3,190
A 9.5" et 35 would be 1mm further in (away from the fender) compared to the 10" et40 in this post. You would most likely still need to put the stock camber adjustment at max/near max (~2°). 275/35/18 is one profile size smaller than normal. It will cause a larger wheel gap to the fender. 275/40/18 would be better. This would be considered a somewhat aggressive fitment and the chance of rubbing would depend on the tire brand/model.
11-07-2023, 08:16 PM | #14 |
Rep 15
i'd go with 275s unless you like the slightly stretched look
I'm on 19x10 et 45 ff03s with 275/35/19 PS4S... no rubbing at all on stock m sport suspension. 2016 f36 rwd. |
