BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Staggered wheels on base 428i ?
      10-05-2019, 07:37 PM   #1
Evangoz
Drives: F32
Hi guys, so to my dumb mistake i purchased an oem 442m wheels for my 2015 428i from my friend (he had a 435i msport and bought new set of wheels) and sold his old 442m to me (transferred his TMPS too) so i decided to put them on and transfer my 17" tpms to the new 19 rims. Then i arrived to Big o wheels to get them transferred and they told me that the 19 wont fit my car because of the new staggered setup (saying the car is programmed for my base setup) and somehow the new wheels can mess up my Traction control and ABS,etc basically mess my car up. Is this true? Or can I just straight change my wheels to the 442m?
Anyone has any experience with base 428i with 19" wheels? Any help would mean alot, im freaking out if changing my wheels will frick my car up
Heres the 442m wheels https://ibb.co/YXf6GtP
      10-05-2019, 08:22 PM   #2
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
662
Drives: '13 328i Msport 6MT
It will work fine. Nothing won't be messed up.
Btw you want the tire sizes to be 225/40 and 255/35
Apex SM-10/PSS | 400m/X-ice Xi3 | Injen Exhaust
Stoptech SS Lines | 335 Brakes | Hawk HPS 5.0 | RBF600
Bootmod3 Stg 1 93 | ER Charge Pipes | Wagner Evo Comp 2 FMIC
      10-05-2019, 08:25 PM   #3
soons50
Drives: 2007 M(azda)3
Is your car xDrive? What size are the tires on the new wheels?
      10-05-2019, 11:43 PM   #4
upsidedownfunnel
Drives: 2014 335i
2014 BMW 335i  [0.00]
If you have a RWD car, you can definitely use those wheels/tires. If you have AWD, you still probably can. As far as I know, there is no special programming for either xDrive or RWD cars whether it has staggered or square tires sizes.
      10-06-2019, 12:19 AM   #5
chowser51
chowser51's Avatar
Drives: 18 F33 430ix B46 BM3s1-93
with the xdrive you will be fine with the 225/40 and 255/35 tire sizes.
      10-06-2019, 01:05 AM   #6
OC_F32
OC_F32's Avatar
109
Drives: 2015 428i
I'll start by saying that I'd be skeptical of a chain tire shop giving me technical advice about a car they likely have little experience with. Whether your car has wider back wheels or not should have no bearing on how traction control or ABS works on a rear wheel drive BMW.
I have a 2015 F32. Door sticker indicates a 17" square set up. The very first thing I did when I got it a few years ago was ditch the stock 17"s. Outside of some annoying road noise and a bumpier ride, there are no issues. I wouldn't sweat it.
19" Staggered OEM M403s
Bridgestone S001 RFTs
225/40/19 Front
255/35/19 Rear
When you get your car realigned after the wheels go on, traction control may light up/throw some errors at the bottom of your gauge cluster and iDrive but should self adjust after a handful of city miles.
Cheers
      10-06-2019, 01:29 AM   #7
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
Your new wheels and tires as mention above will fit just fine.
Big o wheels? Are they related to big o tires....get out of there and find another tire shop. That place scares me....lmao
chenry1183.00
      10-07-2019, 11:40 AM   #8
Evangoz
Drives: F32
Its not an x drive, comes with a 17"
      10-07-2019, 11:42 AM   #9
Evangoz
Drives: F32
225/40/19 Front
255/35/19 Rear
Cheers
Thats nice to know, is it important to need to get realignments right away?
      10-07-2019, 11:07 PM   #10
OC_F32
OC_F32's Avatar
109
Drives: 2015 428i
225/40/19 Front
255/35/19 Rear
Cheers
I think it's best practice to align immediately/shortly following installation of new tires. But I suppose if there are no symptoms of misalignment it wouldn't hurt to wait a few.
For me, I wouldn't want to put any unnecessary wear on the new tires so I get it done at the same time.
fitment, fitment issue, wheels
