BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Speed Limiter '' LIMIT ''
      04-09-2017, 06:17 AM   #1
Elkawass
Egypt
19
Drives: DeepSeaBlue LCI 330i 2016 Lux
Dears,
I have been on an open road during this weekend; and wanted to push my LCI_330i to top speed!
It was easy for the car to hit the 250 km/h and I've noticed that speed kept going beyond that until it almost hits a flat-out 260 km/h
My first question is; I thought that the Spped-Limiter will cut-off the engine to prevent it from going over the LIMIT,
Second question; if I coded the limiter to be off and the can go up to higher speeds (as engine RPM was still between 5000-6000) how much speed can the B48 with 252ps reach? and this will need a digital speedo activated of course
Thanks
" if everything seems under control; you're just not going Fast enough " ??
      04-09-2017, 07:40 AM   #2
Goody4
Drives: 2016 340i
It will only give you an audible warning "chime" or ring when you've reached your preset limit. It won't physically interfere with the engine, brakes, throttle or any other operational aspect of the vehicle.
      04-09-2017, 03:32 PM   #3
COKen
COKen's Avatar
Drives: 2014 435i / 2002 M Roadster
I think the OP is talking about the factory top speed limit.
2014 435i M-Sport, Mineral Gray, Black Dakota Leather, Driver Asst Pkg, Prem Pkg, Tech Pkg, 8 Spd Sport AT, Heated Front Seats, ACC, BMW M Perf Tune w/MPE, BMW LSD, BBS CH.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Steel Gray Metailic HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C.
      04-09-2017, 03:37 PM   #4
bimmer456
Drives: 340i
They really should raise the top speed limiter to be like the B58, it's pretty much the same chassis and can handle the higher speed. I read on the forum that the top speed limiter can only be removed within 10 hours from the time of ECU installation at the factory. I would think it could be removed with a reflash. They actually advertise the higher top speed limiter on the 340i as a feature you should be willing to pay more for lol. Why not just make all f30s the same?
      04-09-2017, 04:52 PM   #5
insanecoder
Drives: 340isDrive
Most bimmers in the states are limited to 130mph
if you have option 840?(usually w/msport) then its upped to 155mph
in Germany they take off the limiter
supposedly within 10 hrs you can option off the limiter via coding
which to me logically cannot happen unless its done the last day of production on the assembly line.. who gets delivery that early?
      04-09-2017, 04:58 PM   #6
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
The limit is based on the speed rating of the tires.
      04-09-2017, 05:03 PM   #7
bimmer456
Drives: 340i
My tires are rated for up to 180 Mph because they are pirelli p-zeros, same ones as on the Ferrari 458. However, the door jam indicates at standard tire pressure you should not exceed 100 mph. There is a higher tire pressure recommended for speeds above 100 apparently. Also, if the customer decides to upgrade the tires they should be able to set a higher speed limiter via the i drive. 133 MPH seems like a very low rating for sport sedan tires.
      04-09-2017, 07:49 PM   #8
kpgray
GasCompressor
kpgray's Avatar
Drives: 2019 440i M-Sport Coupe
To get the Higher speed limiter, the vehicle must have been originally ordered with "Mixed Performance Tires" or "Mixed Performance Summer Tires." This automatically adds the "Increased Top Speed Limiter" raising the limit to 155 MPH. This gives you the 8.0" wide front and 8.5" wide rear tires. This is an "840" option on RWD and "ZRT" option on the xDrive. It is usually found with M-Sport option as it has the largest selection of Rim choices with Performance Tires but some Sport versions do exist but are more difficult to find. If you find 19" OEM rims installed, these are most likely to have the higher speed limiter. The dealer should be able to find out for you to be sure.
2019 BMW 440i M-Sport Coupe Individual
Smoked Topaz Metallic / Opel Extended Merino
Wife's Ride: 2018 Jaguar E-Pace S
      04-10-2017, 11:36 PM   #9
Pr3dict
Drives: '17 340
I ordered a 340 with x drive and it has the 840 option. If think the zrt option is of they remove the limiter completely.
      04-11-2017, 12:24 PM   #10
CalCarNut
CalCarNut's Avatar
Drives: 2015 F36 Jet Black Sport Line
Hmm...thought my window sticker showed speed limiter removed/changed. Regardless, with the flash tune, it's not there anyway .
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint|
330i, b48, lci, top speed
