BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Esys select newer CAFD for ICM
proTUNING Freaks
      05-16-2018, 08:26 AM   #1
manitaci
Netherlands
Drives: BMW 320d 2013
Hi all, can someone explain me how to select a newer CAFD for ICM module?
Reason: I want to activate TLC (Lane Department Warning) and need to edit C_KOV_TLC in ICM module.
In Esys: I select ICM and Detect CAF for SWE. I only get the same CAFD files
All are CAFD_0000067B_002_003_139
I allready checked some CAFD_0000067B_002_006_xxx with CAFD Editor and those have C_KOV_TLC_Verbaut (think this will work too).
I-Step = F020-14-07-505
(I-Step when reading in VCM menu = Current F020-13-07-503)
Car: BMW 320d 2013 Germany
Q: why can't I select CAFD_0000067B_002_006_xxx which is available in used pszdata version? Do I need to flash firmware of ICM module?
Thanks in advance!
      05-16-2018, 09:59 AM   #2
atzebmw
Drives: BMW 335XD F30 LCI
I just tried the same thing and i also can only select a CAFD which is according to my I-Level.
So, i think you should flash your ICM to an newer I-Level.
But what is the problem with your current CAFD of the ICM?
Can't you find this value there?
      05-17-2018, 02:56 AM   #3
manitaci
Netherlands
Yes, there's no C_KOV_TLC or C_KOV_TLC_Verbaut available in CAFD_0000067B_002_003_139.
I need this variable to be "Aktiv/Verbaut" for Lane Department Warming.
      05-17-2018, 06:49 AM   #4
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Thanks in advance!
Yes. Only option is to flash ECU(s) with newer PSdZData Full.
cafd, detect caf from swe, esys
