11-07-2019, 07:18 PM | #1 |
Rep 353
Used TPMS sensors help
If I'm purchasing used TPMS sensors and assuming they are working and are the correct model to work with my car.. are there any other things I need to be aware of? Or is it just a simple insert, program iDrive, and all good?
11-08-2019, 08:17 AM | #2 |
Rep 849
Drives: BMW 435i
Since the TPMS sensors have a battery, I don't know if I'd go used. You never know how much life is left in the battery. I'd go with new ones knowing there will be several years of no worries.
From what I've read, BMW changed the sensors sometime around the 2014 model year and you have to be very careful to make sure you have sensors which are compatible with your model year of car. A pre-2014 sensor won't work with a post-2014 car and vice versa. Others here probably know the specifics. |
11-08-2019, 09:36 AM | #3 | |
Rep 353
11-08-2019, 10:10 AM | #4 | ||
Rep 5,392
ktrvn102.00 |
11-08-2019, 12:21 PM | #5 |
A family of bimmers
2747
Rep 7,742
https://www.rgsportshop.com/index.ph...product_id=218
have used them twice now and have worked great for both my e90 and now my f30. just make sure to get them your last 7 of VIN so they can get the proper ones.
ktrvn102.00 |
11-08-2019, 03:07 PM | #6 | |
Rep 849
Drives: BMW 435i
This the the first car I've owned with TPMS sensors actually in the wheel and not one of the more simple systems which measures tire rotation, so I'm in uncharted territory with my own car. With anything battery powered I always think long term and like to start with a device with the maximum possible battery life. |
ktrvn102.00 |
11-08-2019, 03:54 PM | #7 | |
Rep 353
11-12-2019, 08:49 AM | #8 |
Rep 849
Drives: BMW 435i
I'm running a set of TPMS sensors from Tire Rack which came with my winter wheel/tire setup and they work just like OEM. I just had to do the re-set procedure.
11-12-2019, 11:27 AM | #9 |
Rep 353
