BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Fix: annoying door creaking - bmw 3M tape solution
      04-09-2018, 05:38 AM   #111
EricVR4
EricVR4's Avatar
604
Drives: 2023 X3 M40i
Originally Posted by The Airman View Post
So, you put clear tape on the top of the trim where the top door rubber seal touches. Correct?
Correct yeah, all along the underside of the shadowline trim since that seems to be the culprit, rather than the rubber on the door.
      05-31-2018, 11:44 AM   #112
Luke Colorado
Drives: 1987 560SEC
This creaking is happening on my B7 (LWB) with shadowline trim and it's making me insane. I can't wait to try this fix!
      08-05-2018, 02:10 PM   #113
RRedline
Drives: M3 ZCP MN6
Just did this to my M3. Problem solved.
Only issue is that the 15' roll cost $36 and was about 6" too short to do both sides with no waste.
Despite this, the creaking is gone.
      08-05-2018, 02:44 PM   #114
kikcaffine
Drives: 1m
You can do this "fix" by just waxing the area also.
      08-05-2018, 03:16 PM   #115
perryo91
perryo91's Avatar
Uganda
373
Drives: 335
Idk man, I rather not get some wax build up on the felt trim that meets with the shadowline trim
Hi
      08-05-2018, 08:08 PM   #116
The Airman
Drives: 2021 i3s
I didn't feel like going back to the dealer, so I bought a spray can of 6% silicon spray, and just spray a paper towel with the silicon and wipe the trim above the doors from front to back.
The spray is expensive, but one treatment seems to last for weeks and lasts even after a wash. Just watch overspray because this stuff is slippery and hard to remove once it hits something.
2021 i3s AC Schnitzer
BMW CCA #67486
      08-05-2018, 08:23 PM   #117
F30NEEDS
F30NEEDS's Avatar
Drives: 2010 E92 M3
I used this so far great!
nextzett 91480615 'Gummi Pflege... https://www.amazon.com/dp/B004B8GTQG?ref=yo_pop_ma_swf
DL335D580.00
      08-05-2018, 09:30 PM   #118
The Airman
Drives: 2021 i3s
Great. Do you put it on the rubber felt or the black trim?
BMW CCA #67486
      08-05-2018, 09:31 PM   #119
F30NEEDS
F30NEEDS's Avatar
Drives: 2010 E92 M3
I put on trim and rubber around all doors
      08-06-2018, 11:49 AM   #120
RRedline
Drives: M3 ZCP MN6
Sure, but I wanted to fix it once.
      02-20-2019, 09:49 AM   #121
moonluv810
moonluv810's Avatar
Drives: 2017 BMW X3, 2018 BMW M3, 2022
I have a '18 M3 and have tried gummi and wax and the creaking always comes back after a month or so and a couple car washes.
Thank God I found this thread!
I will tackle this project this weekend.
Will not take my car to a dealer for this. They managed to scratch my trunk during the last oil change.
Thank you OP for putting together the DIY!!!
      02-26-2019, 09:26 PM   #122
moonluv810
moonluv810's Avatar
Bought the tape at Amazon for $6 and spent 15 min tops Saturday morning following OP's DIY.
Super happy with the result! Zero creaks and I'm sure they won't be back!
      02-27-2019, 07:08 AM   #123
Rebound
Rebound's Avatar
153
Drives: F33: The 435i Convertible
Has anyone tried this on the convertible? Because it's a frameless door, and there's a rear quarter window which directly contacts the front door window glass.
      02-27-2019, 09:12 AM   #124
Mega8489
Mega8489's Avatar
203
Drives: Bmw 2023 G80 M3 6spd
Do you have a link ? Thanks
      02-27-2019, 12:07 PM   #125
moonluv810
moonluv810's Avatar
https://www.amazon.com/gp/aw/d/B0082...0DER&psc=1
I went with 0.5" width and it's perfect.
Good luck!
      03-24-2019, 04:13 PM   #126
niclayt
Drives: Golf VII
Hello there.
Has there been a permanent non-tape solution?
I have the same problem as my Golf VII. Silicone spray etc. it does not work.
      03-24-2019, 06:43 PM   #127
vinzcast21
vinzcast21's Avatar
161
Drives: F30 340i MY2017
does the bulletin applies to canadian cars? 16' 340i
Mod bug will bite you if you buy a BMW
      07-22-2019, 09:30 AM   #128
3RS
Drives: 2018 BMW 340i ZHP
Does SIB 51 28 10 actually cover the F30. I took my car to the dealer last week, who told me it didn't apply. They just cleaned the seals which fixed the issue for about 4 hours.
Does anyone have a copy of the SIB they could post (or send me)?
Thanks
      08-06-2019, 09:54 AM   #129
ndshgyta
Drives: f30
This creaking is comming from 2 parts:
1. The shadow line trim which can be fixed with the teflon tape.
2. The glass rubbing against the seals causing the sound. The only fix i think is changing door glass seals? Or put some material inside, where the glass is moving.
I already applied teflon tape and the creaking is less but continue to have creaking from the glass and seal!
Please help!
      08-06-2019, 04:43 PM   #130
upsidedownfunnel
Drives: 2014 335i
2014 BMW 335i  [0.00]
Originally Posted by chuckles01 View Post
+1, would be interested in knowing as well. Last time I brought my car in with this issue, the SA dismissed the issue and told me, "The door seals creak when they get dirty. It's your responsibility to keep the seals clean and wash them frequently." I told him I do keep my car clean and wipe down the seals as well, and he simply replied that it's not clean enough and there's probably still dust stuck on it. As the op mentioned, cleaning was only a temporary solution.
I was pretty disappointed so hoping that if I can show them an actual service bulletin with a more useful resolution than simply "keeping it clean," then it might help.
Do you have a sport line or M Sport? I have a sport line and my previous 5 series and current F30 squeaks were solved by simply taking a cloth and cleaning my window seals after every car wash. Other BMWs I have don't have the trim on the body like the 3 series, so maybe it's something specific to the gloss trim interfacing to the door's top seal/flocking?
It literally takes 5 minutes to thoroughly clean all those seals and they will work better if kept clean anyway. I'd rather keep them clean then apply tape to the car.
      07-28-2020, 10:05 PM   #131
RecklessOne
Drives: MDX, Wrangler 4xe, X7(ordered)
Sorry for the bump, but I searched and couldn't find anything solid on this -- did anyone get this to work on the convertible?
I have an 2020 F83 and the creaks and squeaks are worse than the 10 year old Honda I bought in high school.
Dealer is claiming "the convertible top is operating as expected".
      07-01-2021, 08:24 AM   #132
casualDIYer
Drives: 340i xDrive M Sport
If you are out of warranty and didn't plan on spending over $250 for magic tape the following solution might help. Fingers crossed
https://f30.bimmerpost.com/forums/sh...6#post27756776
The short version: 1) Clean all seals, especially between upper seals, with a microfibre towel + water, then clean again with silicone remover. 2) Lube between seals with the KSP 105.
You can go insane spreading the KSP 105 all over the place but start by cleaning and lubing between the upper door seals. See how far that takes you then lube additional areas.
Good luck.
