03-02-2019, 03:32 PM | #133 |
Rep 3
What kind of codes do I need to be able to change the color of instrument cluster and hud from orange to white all the time?I tried DIM_NACHT_EIN werte = 32 in werte = FF but it does not work and HINTERGRUND_FARBE_TAG does not appear in dkombi. can i change or try for nothing? Car is F10 2010 with cic and board was changed with 6wb
03-25-2019, 04:24 PM | #136 |
Rep 120
Hello guys, i have a problem with my 6wb.
While the navigation, there is a bug in my HUD, look at the loading line above the word "km / h". Anyone can help me? Thanks |
03-25-2019, 04:36 PM | #137 | |
Rep 2,302
I have the same problem and tried everything possible, but it does not get better. I assume you have the NBT Evo (ID4 ++) between 07/2015 and 07/2016? |
03-25-2019, 04:43 PM | #139 |
Rep 2,302
04-11-2019, 11:33 PM | #141 |
Rep 66
I just finished my 2nd retrofit of the 6WB cluster in an F30. All went well thanks to everyone's research!
This time around is an LCI with iDrive 6 (NBT-Evo) and I wonder if the dealership would be able to update everything normally, or will I still need to put the old cluster in sometimes? |
04-12-2019, 12:10 AM | #142 | |
Rep 2,302
04-12-2019, 12:38 AM | #143 |
New BMW owner
139
Rep 621
Drives: BMW 316d, BMW F40 116d
I have a NBT, model 2014 with HUD.
Does this mean I need to update the i-step from my HU? |
04-12-2019, 10:10 AM | #144 | |
Rep 740
I know for the 6wb, this statement is true.
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
04-12-2019, 10:13 AM | #145 |
Rep 40,771
Dealer ISTA programming takes FA from car VCM, not their Database. If 6WB is valid factory option, and FA Build Date is original, and car has all supporting hardware, then it is no problem to be programmed by Dealer.
04-12-2019, 10:14 AM | #146 |
Rep 740
Thanks for correcting me!
04-12-2019, 10:50 PM | #147 | |
Rep 66
At some point in the fall I’m going to have them update the whole car and hopefully the cluster along with it. Both are newer than what I have available (and mismatched versions as well) and I’m hesitant to update everything anyway. Car is on 18-03-511, cluster is 18-07-549, I have 18-11-520 (63.2). I know there’s at least an 18-11-531 as of maybe 4ish months ago. |
04-13-2019, 12:13 AM | #148 | |
Rep 10,473
Dealer updated istep and thought it was updated. It wasn't. Only updated when 6WA was reinstalled. |
04-13-2019, 04:32 AM | #149 | |
Rep 2,302
But like shawnsheridan said... For my car (built 07/2015) it was no valid factory option and the ID4++ NBTEvo doesn't support the 6WB for 100%. |
04-19-2019, 09:43 AM | #150 | |
Rep 5
Last edited by TD60DAB; 04-19-2019 at 10:08 AM.. Reason: Need to include additional information |
04-19-2019, 11:01 AM | #151 |
Rep 3,876
No one has been able to make that happen yet so if you do - you'd be the pioneer
05-01-2019, 06:23 AM | #152 |
Rep 157
Is there a full DIY coding manual available for retrofitting the 6WB digital cluster?
With 'full' I mean with all the different options like HUD, compass, etc. |
05-01-2019, 07:11 AM | #153 |
Rep 142
I'm running into this issue now with my dealership. They are not able to do any update with the 6WB but I fear if I swap it out with the 6WA for them to update, I wont be able to put the 6WB back in? If they update software does the 6WB need to be re-coded?
05-01-2019, 07:14 AM | #154 |
Rep 40,771
No. Since 6WB is not being programmed and encoded, it retains its coding. If you had to Code Head Unit to support 6WB, it though would need to be coded after putting 6WB back in car.
