07-19-2021, 04:06 PM | #67 | |
Rep 221
07-19-2021, 04:12 PM | #68 |
Rep 221
[/QUOTE]note: i also still don't floor it in 6th gear at 3000 rpm . haha. it is POSSIBLE that is too much for the clutch. do you have any issues in lower gears like 4th?[/QUOTE]
Isn't this the point of spending all that money and labor getting a new clutch? to be able to go WOT in 5th or 6th gear on the highway and make use of all that torque with the stage 2+ map? Should I have gone stage 3+ clutch and SMFW instead??? LOL |
07-19-2021, 04:23 PM | #69 | ||
1297
Rep 3,536
I don't mean to laugh but damn dude that's hilarious.
07-19-2021, 05:08 PM | #70 |
Rep 221
I personally wouldn't try his method with my car, but he seems to be fine, He hasn't experienced any slip with the 550i clutch and stage 2+ map... myself on the other hand... this thing is slipping worse than my stock clutch on the stage 2+ map... but back on stage 2 e30, and it's holding strong, so fingers crossed, that in a few hundred miles, when I go back to stage 2+, this thing holds the power... so far, I have to say I am a little disappointed though.
07-19-2021, 05:44 PM | #71 | |
Rep 4,169
07-19-2021, 05:52 PM | #72 |
Rep 221
yes, and very fun. Being able to keep up with a GT500 will put a smile on your face... I couldn't believe I could keep up with a GT500 till it happened... was very suprised. once I get this clutch slip issue figured out, PS2 and LSD is next on the mod list... haha. I want 550whp and whatever torque comes with it, then I will be satisfied.
07-19-2021, 06:22 PM | #74 |
Rep 643
Correction, clutch holding beyond 550 wtq
6MT Clutch Strength https://f30.bimmerpost.com/forums/sh....php?t=1628178
M235i rwd 6mt
07-19-2021, 07:57 PM | #75 | |
Rep 221
https://www.bootmod3.net/log?id=60f6...729b192f0f40cf https://www.bootmod3.net/log?id=60f6...90c620423c513c https://www.bootmod3.net/log?id=60f6...0b436ef6b56701 Per Virtual Dyno, I am making about 404 whp, 415-431 wtq on the stage 2 e30 map. |
07-20-2021, 08:24 PM | #76 |
Rep 221
can an expert please look at this log and let me know if this is clutch slip? this makes no sense at all. I have driven on this 550i clutch for about 750 miles now... it seems to hold the power on stage 2 E30, but it is slipping in even 3rd gear on stage 2+... do I need to break in the clutch more? is it possible this is not clutch slip and it's something else? now I kind of wish I went spec 2+ or 3+, I feel like I threw $1600 down the drain. With my stock clutch, I could go wot all day in 3rd gear, 5th and 6th gear was the issue, now with the 550i clutch, I can't even pull in 3rd gear? should I take this back to the shop? if this was installed wrong, then wouldn't the clutch be slipping on the other maps also? I am so confused at this point.
https://www.bootmod3.net/log?id=60f7...0b437913781514 |
07-20-2021, 08:45 PM | #77 | |
Rep 4,169
07-20-2021, 09:59 PM | #78 |
Rep 221
nope, not beating on it, not at all. I drive like a grandma for a few hundred miles, then try a WOT pull here and there to see if the clutch holds. It holds strong on stage 2 e30 map, but on the stage 2+ map, everything falls apart. I am starting to think my stock original clutch was actually stronger? at least with that one, I could WOT in 3rd gear on the stage 2+ map...this won't even WOT in 3rd gear like my original clutch...SMH. calling the shop tomorrow to see if what they suggest doing at this point... I mean, maybe what I am feeling at this point with the stage 2+ map is not clutch slip? is it possible it is something else? like a failing diverter valve or something?
07-20-2021, 11:57 PM | #79 | |
Rep 4,169
07-21-2021, 05:15 AM | #80 |
Rep 221
07-21-2021, 07:26 AM | #81 |
Rep 643
here's a clear example of clutch slip in 4th
https://www.bootmod3.net/log?id=5e16...90c660d027d38a here's a more subtle slip https://www.bootmod3.net/log?id=5e16...90c66f5be9ab24 when viewing logs, disable everything except engine speed, and vehicle speed. you will see RPMS spike, but vehicle speed stays linear. CDV delete only quickens the clutch to grab when shifting. if you are in gear accelerating, CDV has no impact on how strong a clutch grabs.
M235i rwd 6mt
07-21-2021, 08:55 AM | #82 | |
Rep 221
hmmmm, so my graphs do not look like the cluth slip example you highlighted...not really seeing the rpm spikes... so if my clutch isn't slipping, then what in the world am i experiencing with this map? when accelerating, I hear the turbo spool, then it cuts off.. then it starts spooling again... is my turbo maybe just too weak to run this map? are my tires weak and loosing grip? i also never smell burning clutch...so maybe my clutch has been fine this entire time? Last edited by motivman; 07-21-2021 at 09:00 AM.. |
07-21-2021, 11:31 AM | #83 |
Rep 221
resurrecting this thread, still chasing down break up at WOT with the stage 2+ E30 map. it is so weird because I have no issues with the stage 2 e30 map or stage 2 91-93 octane maps. I thought the issue was my diverter valve... upgraded that to turbosmart plumback and MST inlet pipe, but its like the issue got worse. I have no boost leaks... again, car runs perfect on the stage 2 e30 map... not sure what is going on, it is definitely not clutch slip... already upgraded to 550i clutch. this log shows exactly what I am experiencing. Looks like DME is randomly reducing boost target.. ie from 21 PSi to 14-17 psi, then up to 21 psi again, then crashes again. Is my LPFP not keeping up? no way to monitor what LPFP is doing on the N55.. HPFP is holding strong... any help with be greatly appreciated to finally figure this out. Tired of throwing money at the car and the issue still persists. I am running about e50 octane
https://www.bootmod3.net/log?id=6103...0b4342c6c8d267 Last edited by motivman; 07-31-2021 at 10:47 PM.. |
07-31-2021, 10:53 PM | #84 |
Rep 221
can someone look at my most recent log? still having break up issues at wot on stage 2+ e30 map. upgraded diverter valve, but issue still persists....
07-31-2021, 11:17 PM | #85 | |
1297
Rep 3,536
what map sensor are you running btw
08-01-2021, 12:41 AM | #87 |
1297
Rep 3,536
have you sent the log to ptf? I bet halim makes you a revision for the closures
08-02-2021, 05:08 PM | #88 | |
Rep 7,616
Also, are you running multimap? |
