04-05-2020, 01:39 AM | #24 |
Rep 14,108
Drives: G82 M4C X-Drive
I've owned F30 340i, 2 F80 M3's and drove a M340i on the street and on an autocross at the UDE.
Here's my take: Used 340i - this will save you the most money. You can get a used M Sport for $25-30k. However... You mentioned you do not plan to do extensive modifications. Then get a used F80 M3. Out of the box, it's better than even a modded 340i. Yes, FBO stage 3 with giant turbos can beat an M3 in a straight line, but that's not why you get an M car. You get one because you can drive it hard all day and not overheat your: engine, steering, transmission, diffs. M cars have much more cooling. The amount of heat exchangers, design of heat sinks, airflow, etc all play a big role in keeping the car performing even after hours of hard driving. Not to mention everything will still be covered under warranty. No warranty? The S55 M3 has proven to be the most reliable M3 to date with issues being well documented and fixed (crank hub). You cannot expect a Stg3 340i to hold up under the same conditions unless extensive and EXPENSIVE modifications are made, at which point you might as well have gotten the M3. Keep in mind I'm talking about real hard driving like on a track. Street racing need not apply, it's simply not hard enough, I don't care how fast people think they are going. M340i - surprisingly capable on a short course even with a full car. I was able to get 2nd place in my group. The edge was easy to find and it's forgiving since its AWD. Having said that, it's big and it's heavy. AWD helps a lot in this case, 4000lbs is no joke. Still, it was more capable than my old 340i with track handling package. That power is undeniable. It will suffer, however, the same drawbacks as a 340i when you push it. It's not designed to be abused like a track car. It will not perform in the same way consistently as an M car because it wasn't equipped or designed to do so. M340i owners will tell you about 0-60 times and how it will beat an M3 blah blah blah... push it to the real limit, not just a streetlight to streetlight race, then we'll talk. As a street car, however, if you need the size, it's hard to justify a 340i unless money is an issue. Additionally, the price puts you in used M3 territory.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
04-05-2020, 02:11 AM | #25 | |
Rep 3,752
Anyway, I didn't hear that BMW fixed the crank hub issue. Oh you mean the $4000 dollar aftermarket fix. Just want to clear that. Last edited by Gen13 F36; 04-05-2020 at 02:21 AM.. |
04-05-2020, 02:39 AM | #26 | ||
Rep 14,108
04-05-2020, 12:15 PM | #27 |
Rep 198
I have never heard this before. Can you link your source. I've heard of changes between b58 variants (i.e. fuel pump, exhaust outlet to turbo) but have never heard a single thing about changing the turbos.
04-05-2020, 12:47 PM | #28 | |
Rep 14,108
Also, the F80 sounds horrible in comparison to the E92, but with an MPE it doesn't sound bad when it counts.
04-05-2020, 05:49 PM | #29 | ||
Cheapskate
4447
Rep 4,993
And yeah, my coworker has the MPE. Driving around town it sounds really bad and metallic. Just not for me. |
06-23-2022, 09:56 AM | #30 |
Rep 24
I'm in the same boat 2 years after this post originally posted. Is the adaptive cruise and lane keep assist better in the m340 vs 340? I would imagine it was improved?
06-23-2022, 11:23 AM | #31 | |
Rep 14,108
Anyway, I can't speak to the adaptive cruise as the only bimmer I've had it in is my 2015, 2018, and 2019 i3. I will say that the camera based ACC was excellent already. I can imagine that the LiDAR based one in the G20/G80 is much better. My G82 has the camera based lane keep assist and it works pretty well, although I have it in the lowest setting and I have it turned off in sport mode, which I run 99% of the time.
06-24-2022, 08:37 AM | #32 | ||
Rep 675
Thread resurrected? I'm the OP. I never did get a 340 or an M340… I got an M550! I started looking at the larger cars since I have kids - and once I test drove one loved it. I wanted an M3 but at the time the F80 interior seems dated - the G30 5 series had been refreshed and felt newer inside plus way more luxurious I was lucky I scored a great deal on the certified preowned bottle prior to all the car prices going ballistic. Mine is massively loaded with full leather Dash Alcantara headliner heating and cooled plus massaging front seats , heated steering wheel rear heated seats…and 20"s I haven't tuned it as I added CPO extension so the car has 4 years of warranty from date of purchase. It's a blast. Sometimes I wish it was more nimble like the M340… but then when I'm cruising to work with my adaptive cruise control and massage seats I prefer this.
Sean
2016 X5 sDrive 35i 2018 M550i |
07-13-2022, 10:55 AM | #33 |
M340i
392
Rep 967
Drives: BMW M340i
Glad this discussion came back to life....
I drive a FBO 435i GC. Great car but I am looking ahead to 2023-2024 (once the used car market corrects) and am deciding on an M340i or M3(F80). The M340 will have newer tech but the F80 has amazing looks and performance. Decisions, decisions....EV? |
07-15-2022, 08:31 AM | #34 | |
Rep 675
I ended up driving the M550 and was sold. It lacks the handling of a 3 series but makes up for it in other ways. For a DD I think it's far better. But now I need a toy car…. 🤑
Sean
Bob Loblah59.00 |
