BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > General BMW News and Cars Discussion > 2023 G87 M2 Spied Testing!
      04-27-2021, 10:23 AM   #683
Colinv6
Colinv6's Avatar
Drives: E92 M3 competition
Originally Posted by W/// View Post
To add to E92 M3 right?
High chance this will be my ICE end game.
Absolutely! That baby is going nowhere The M2 will replace the wife’s M140i hatchback.
I can only hope to spec CCB’s as I really miss them from my M4CS.
      04-27-2021, 06:51 PM   #684
bmwloverm2
Drives: bmw M2 2017
M2 will have new idrive 8 like in the i4 or traditional cluster?
Looking at the latest camo car spotted, I can't see the new "idrive 8" long screen raised, seems like the traditional infotainment etc.
I haven't followed much in which models iDrive 8 will be present, i expect it in the i4 of course... but what about the upcoming series2 + upcoming M2?
Is there any information leaked about if they will bring the current Series 3, Series 4 infotainment or if it will be the long panel idrive 8 ?
Thanks!
      04-30-2021, 02:54 PM   #685
mbanck
Drives: Skoda Karoq
The 2er coupe will get the ID7 / current 3er infotainment initially, but get upgraded to the ID8 one after a year or so in 8/2022. The M2 will get the ID8 one from the start (cause it launches in late 2022).
In any case, the above photo looks like an ID8 wide screen to me, just not very rounded like on the i4? Doesn't look like a 3er/ID7 screen to me at least. Nobody said the screen would be identical everywhere.
Finally, what the test mules have as infotainment at this point of development is not really a conclusive hint at what will show up in the production car.
      05-05-2021, 03:51 AM   #686
quenotte
France
46
Drives: F87N M2 Competition
Originally Posted by RugbyBro View Post
Yeah I don't see any chance that the M2 gets a DCT. ZF8 is just too easy from a supply chain perspective and too good from an objective performance perspective that it wouldn't make sense to appease a couple of us old heads kicking and screaming for DCT.
Plus philosophically speaking, if BMW paired S58 with a DCT, they would then have to answer the question as to why they are keeping the redline low at 7200 when DCT can easily handle the 7600 engine limit. If they raise it on a mass production model like an M2, the M3/4 & X3/4M owners will be up in arms.
7200 is ZF8 max rpm...
DKG was able to handle a lot more paired with S65 engine.
      06-07-2021, 05:57 AM   #687
BMWGirlFL
BMWGirlFL's Avatar
2037
Drives: Z4 M40i
AutoCar Claims:
The second-generation BMW M2 will have even stronger performance and more versatility than the well-received current model when it reaches UK showrooms by the end of 2022, according to insiders.
The new version of M division’s smallest model is based on the upcoming third-generation 2 Series Coupé, which has been comprehensively re-engineered with a revised line-up of longitudinally mounted engines, a new eight-speed automatic gearbox, an updated platform, a significantly stiffer body structure and more advanced electronic architecture.
The changes provide the new, G87-generation M2 with much closer engineering ties to other M models than today’s M2 has. M division insiders say this will enable the new M2 to offer a further step up in performance while helping it to retain a reputation for dynamic excellence through the sharing of key components.
An internal source told Autocar: “It’s more powerful, with greater torque, but sharper, too. It’s still puristic, a driver’s car, but with a broader spread of characteristics, a greater divide between comfort and sport, than what we’ve seen up to now.”
Central to the model-specific changes for the upcoming Porsche Cayman GTS rival is the arrival of BMW M’s S58 engine. The twin-turbocharged 3.0-litre six-cylinder unit was introduced on the X3 M and X4 M, and more recently deployed in the new M3 and M4. It will replace the existing M2’s long-running N55 unit, introduced in 2009, as well as the S55 engine used by the more potent M2 Competition and M2 CS.
Key elements of the S58 engine include a newly designed crankcase, a longer stroke, a reworked cylinder head and a more efficient induction system, which uses two mono-scroll turbochargers in place of the single turbocharger in the engine it replaces. As with the older S55 engine, it also gets a petrol particulate filter.
Autocar understands the new inline powerplant, which will be updated to meet Euro 7 emission regulations during the M2’s planned seven-year life cycle, will be offered in two states of tune in a move mirroring that of the new M3 and M4 – both with a 7200rpm redline – although only the higher-output Competition car is likely to be available in the UK.
Details remain under wraps more than a year before its planned introduction but standard M2 models are expected to receive up to 410bhp, with the successor to today’s M2 Competition set to offer up to 430bhp, just 50bhp short of the standard M3 and M4. The rise in power is claimed to be accompanied by a moderate lift in torque. Again, nothing is official but BMW M sources have revealed to Autocar that the new M2 could have as much as 428lb ft – 22lb ft more than the existing M2 Competition and M2 CS.
BMW will offer the new M2 with the choice of either a standard six-speed manual or a new eight-speed torque-converter automatic with steering wheel-mounted shift paddles. The auto replaces the current seven-speed dual-clutch item, which will no longer be available on the M2.
Both the standard and Competition models will have rear-wheel drive with an electronically controlled M differential. Although four-wheel drive is now offered on the car’s M3 and M4 siblings, an xDrive M2 is not planned.
The styling of the new M2 is closely related to that of the upcoming M240i xDrive. Distinguishing elements include a new-look front end with a lower and wider kidney grille than that seen on today’s M2 Competition. Set within a deep front bumper, it goes without traditional fixed vertical louvres, adopting electronically operated active elements that open and close to suit the cooling and heating demands of the new engine.
The headlights, LED as standard, also adopt a more angular design and will be offered with optional laser projectors, with dynamic indicators housed within the front lenses.
The bonnet adopts a prominent power dome and the wheel arches have been enlarged to accommodate wheels of up to 20in. A more pronounced shoulder line runs back to form wider haunches below the rear side windows. The windscreen and rear window are also more heavily raked than on the first-generation M2, giving it an altogether sleeker appearance.
In keeping with more recent M models, the tail-lights have a heavily structured design with OLED graphics while the boot slopes down towards the rear and receives a larger lip spoiler than today’s model for added downforce. A wider diffuser is also integrated into the bottom of the rear bumper.
An optional carbonfibre package will allow prospective customers to specify the new car with various carbonfibre elements, including the roof and door mirrors, although the M2 Competition is set to get a carbonfibre roof as standard.
The new coupé has grown in size, albeit only moderately over today’s 4468mm-long, 1984mm-wide and 1410mm-tall M2 Competition. Along with the increase in dimensions, the wheelbase has been extended by 51mm, at 2744mm, and the tracks have been widened at the front and rear. Crucially, the new M2 will match the 50:50 weight distribution of the less powerful M240i.
Autocar has been told the CLAR platform adopted by the new 2 Series provides a 40% increase in body rigidity compared with the structure used by the old model. The new M2 will add further rigidity with its own unique front suspension dome brace strut and a new brace integrated within the rear suspension.
Underpinning the new M2 is a heavily reworked MacPherson strut front and multi-link rear suspension. Among the benefits of the new set-up cited by BMW M engineers is its ability to support increased front camber. It will be available with the choice of either lift-related or variable dampers.
In a significant shift in M division operations, the next M2 will be manufactured alongside other 2 Series models at BMW’s newly established factory in San Luis Potosí, Mexico. Today’s M2 is produced exclusively at BMW’s Leipzig plant in Germany. Details about the sourcing of key components, including the S58 engine, have yet to be made official, although insiders suggest it will continue to be manufactured at BMW’s Munich engine plant.
https://www.autocar.co.uk/car-news/n...er-and-sleeker
TAZ007277.50
Game1154.00
      06-07-2021, 08:27 AM   #688
TAZ007
TAZ007's Avatar
278
Drives: 2015 M235 Vert
2015 M235 Vert  [0.00]
Originally Posted by BMWGirlFL View Post
You find the most detailed information...thanks.
BMWGirlFL2036.50
      06-07-2021, 09:52 AM   #689
jpy1980
jpy1980's Avatar
Drives: 2015 BMW M3 -Smurfy Blue Vinyl
Hmm she also just found my next car to replace my F80!
BMWGirlFL2036.50
      06-07-2021, 09:57 AM   #690
TAZ007
TAZ007's Avatar
278
Originally Posted by jpy1980 View Post
Hmm she also just find my next car to replace my F80!
Yup, she is good like that. A veritable wealth of good information.
BMWGirlFL2036.50
jpy19801461.50
      06-07-2021, 10:39 AM   #691
CCM11285
Drives: ‘19 BMW 440i
Please keep the vibrant color palette for the G87 seen on the G80/82
      06-07-2021, 10:41 AM   #692
BMWGirlFL
BMWGirlFL's Avatar
2037
Drives: Z4 M40i
Making me laugh!
      06-07-2021, 10:44 AM   #693
TAZ007
TAZ007's Avatar
278
Making me laugh!
Thanks, but looks only go so far.
      06-07-2021, 11:16 AM   #694
pz619
Drives: F87 M2C
I really hope you can get the higher output versions of the S58 with the 6MT. Not like the G80/G82 shenanigans where you can only get the 6MT with the lower output variant. I didn’t read all 32 pages, so not sure if the info is buried in there.
      06-07-2021, 11:32 AM   #695
F8SEVEN
F8SEVEN's Avatar
Drives: Ilse - 2021 SO 6MT M2C
Originally Posted by pz619 View Post
I really hope you can get the higher output versions of the S58 with the 6MT. Not like the G80/G82 shenanigans where you can only get the 6MT with the lower output variant. I didn't read all 32 pages, so not sure if the info is buried in there.
Likely won't be any higher than it is on the G80/2 6MT...possibly lower in base form.
pz6192963.50
      06-07-2021, 11:43 AM   #696
pz619
Drives: F87 M2C
I get that. I meant more that the competition version might be automatic only.
Ex
6MT = 425 hp
Funsapper Automatic = 450 hp
      06-07-2021, 11:57 AM   #697
JustinHEMI
JustinHEMI's Avatar
Drives: 2020 M2 Comp
Ex
6MT = 425 hp
Yes I hope the comp comes with manual. I hope they don't do us dirty like that.
2020 BMW M2 Comp SOLD.
2023 BMW M2 Comp TBD.
pz6192963.50
      06-07-2021, 12:16 PM   #698
TAZ007
TAZ007's Avatar
278
I agree, these cars need to come with the high HP and millennial anti-theft device.
pz6192963.50
      06-07-2021, 01:14 PM   #699
chapmans
Drives: 2003 M3, 2012 Boxster S
Need competition with bucket seats and manual, don't mess it up BMW.
      06-07-2021, 03:32 PM   #700
Colinv6
Colinv6's Avatar
and CCB’s!
      06-07-2021, 04:40 PM   #701
jpy1980
jpy1980's Avatar
I thought the reason they didn’t do it with the g8x was due to the torque that the manual could handle. Since the output of the m2 comp would be lower, i wonder if the manual will come to the comp m2
