08-12-2021, 04:06 AM | #639 |
Rep 21
Will it work with standard dash
I would love SLI on my 2013 F10 530D. I have no KAFAS and am happy to buy whichever emulator box (NBT headunit with latest maps).
However, I have the "standard" dash - IE: The screen at the bottom extends to the right over the rev counter but NOT over the speedo on the left. Will I need a 6WA/WB dash as well or can any of the emulators be made to work with the standard dash ? Any help MUCH appreciated. |
08-12-2021, 02:37 PM | #640 | |
Rep 379
I am selling my sle if any. |
08-13-2021, 01:47 AM | #641 | |
Rep 21
The attached pic isn't actually THE cluster on my car but it is exactly the same one (I googled and found a pic as I am not near the car at the moment). You notice how the bottom LCD screen only goes over the rev counter to the right and not the speedo to the left. |
08-13-2021, 06:16 AM | #642 | ||
Rep 379
https://www.facebook.com/marketplace...id=12&_rdr |
08-13-2021, 09:41 AM | #643 | |
Rep 21
Although looking at the pic you sent, that is the full width LCD - The speed limit symbol is actually further to the left than the screen on mine actually extends so still makes me wonder if it will work ? Example photos attached : |
08-13-2021, 10:23 AM | #645 |
Schmollbraten
12503
Rep 1,985
As far as I recall this from my mod period, you have to have the extended instrument cluster, because those (and other infos) are displayed into the center (here left side) of the extended cluster.
Never heard before that this also works at the small ones but maybe anyone else knows more
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
08-13-2021, 10:37 AM | #646 |
Rep 21
I've found this one on eBay : https://www.ebay.co.uk/itm/254595685014
it says it works on : "6WA, 6WB and basic kombi clusters" I think the extended cluster is the 6WA and the all digital one is the 6WB. I am assuming that the one I have is the "basic kombi cluster" ? I have messaged the seller to clarify but he is on holiday at the moment. |
08-26-2021, 04:39 AM | #647 |
Rep 275
I bought and installed the bimmer8 module, it's absolutely perfect.
Arrived quickly, really well packaged, came with all the tools you need to fit including torx screwdriver etc, and even has switches to change between kmh mph round square etc. Absolutely recommend this! https://bimmer8.com/products/bmw-spe...module?lang=en
Previous: 2002 E46 330i M-Sport (m54b30 LCI), 2007 E92 335D M-Sport Coupe (m57), 2003 z4 3.0i (m54b30), 2010 E92 325D M-Sport Coupe (n57 LCI), 2019 F36 430i M-Sport Pro Gran Coupe, 2018 F36 440i M-Sport Pro Gran Coupe MPPSK
Current: MY2021 M550i, Aventurin Red, Ivory Nappa, Comfort Pack, Tech+ |
08-28-2021, 07:02 AM | #648 | |
Rep 379
08-30-2021, 04:57 AM | #649 |
Schmollbraten
12503
Rep 1,985
Aside from you unnecessary full quote...you have to specify your area of useage into the order. Default is European delivery.
ReMiii4021.50 |
08-31-2021, 09:30 AM | #650 |
Rep 275
there's a little switch on the bimmer8 module to switch between
08-31-2021, 11:47 AM | #651 |
Rep 379
I believe that's to switch between F series vs G series.
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop |
08-31-2021, 03:09 PM | #652 |
Schmollbraten
12503
Rep 1,985
There are different modules available, few have dip switches to set the box to the desired sign layout. Idk if this one has those also, this was only the quote from the site.
09-02-2021, 06:58 AM | #653 |
Rep 47
Drives: 2017 BMW 340i, 6MT, RWD
Anybody try the BimmerTech Speed Limit module? It's much more expensive, but I wonder if anybody has had experience with it.
https://www.bimmer-tech.net/products...mation-for-bmw
2017 340i, RWD, 6MT, MPPSK, LSD
Gone but not forgotten: 1999 328i (E46) |
09-02-2021, 07:19 AM | #654 | |
Rep 685
Bimmercode best coding options (Basic and Advanced):
https://g20.bimmerpost.com/forums/sh...5#post29807925 |
INROADRACR74.50 |
09-02-2021, 09:33 PM | #655 |
Great Teacher
1026
Rep 1,272
Drives: 06 e91 325ix
The new 3rd generation version does, I had a 2nd Gen and now a 3rd Gen bimmer8.
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
09-03-2021, 08:04 AM | #656 |
Rep 275
there are 4 switches, one is the f series, one is the mph / kmh, one is square vs round, one is business vs pro nav iirc
09-10-2021, 07:26 AM | #657 |
Rep 10
So everyone post about coding but nobody mentions what exactly needs to be coded. Can you confirm that this is correct? It does not mention that VO needs to be added.
https://bimmer8.com/products/bmw-speed-limit-module?lang=en Code:
Coding is required for Kombi and HU_NBT/HU_NBT2 for normal display after the product is installed. Coding to be modified for KOMBI or DKMOBI ( ignore this if not applicable ) 【F Series】 ANZEIGE_NPI = aktiv KI_PIA_SPEED_LIMIT = aktiv SPEED_LIMIT = aktiv SPEED_LIMIT_GENERATION = sli_gen_2_npi RCOG_TRSG_APPL = aktiv (* See Notice below) RCOG_TRSG_TIMEOUT = aktiv (* See Notice below) 【G Series】 ADDITIONAL_SIGN_ENABLE = aktiv ANZEIGE_NPI = aktiv CB_TACHOZEIGERBAND = aktiv CB_SLI_NPI = aktiv PIA_SLI_NPI = aktiv RCOG_TRSG_APPL = aktiv (* See Notice below) RCOG_TRSG_TIMEOUT = aktiv (* See Notice below) SLI_PERMANENT_ENABLE = aktiv SPEED_LIMIT_ENABLE = sli TACHOZEIGERBAND_ENABLE = aktiv NO_PASSING_ENABLE = aktiv SPEED_LIMIT_UNIT_ENABLE = Wert_02 ( *If you dont want to display the speed unit kmh or mph, please set Wert_0 ) * If your vehicle have HUD (Head-Up Display) , ignore this if not applicable HUD_NPI_ENABLE = aktiv HUD_PIA_SPEED_LIM = aktiv HUD_SPEED_LIMIT_ENABLE = aktiv HUD_SLI_ENABLE = aktiv PIA_HUD_SLI = aktiv PIA_HUD_SLI_NPI = aktiv PIA_HUD_SLI_PORTIERUNG = aktiv PIA_HUD_VSLI = aktiv Coding to be modified for HU_NBT or HU_NBT2 SPEEDLIMIT_INFO = aktiv SLI_NAVI_DISPLAY = nicht_aktiv |
10-31-2021, 11:39 AM | #658 |
Rep 8
Guys, help me, please.
I have f33 2014 with kafas2 and i have only 3 dashes in my country(Ukraine). I try coding via esys, but in kombi i dont have "SPEED_LIMIT_GENERATION". What i need to do? Maybe update istep of KOMBI? |
10-31-2021, 12:47 PM | #659 |
Rep 519
You will need fsc for SLI
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
