BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Sudden influx of B58 lower turbo inlet pipes available
      10-14-2021, 07:42 AM   #1
Th3Walrus
Drives: 2020 X3MC Alpine White/Sahkir
For those that don't know, I've noticed a sudden influx of lower turbo inlet pipes now available for B58:
Turner Motorsport
Paradigm Engineering
Burger Tuning
      10-14-2021, 09:08 AM   #2
weehe126
Drives: 2017 340i
China makes large batches and sells to everyone interested
      10-14-2021, 10:49 AM   #3
BMWILUVU
Drives: 340ix
Has anyone had their turbo inlet bust even with stage 2 pressure?
      10-14-2021, 03:19 PM   #4
Th3Walrus
Turbo inlet has absolutely nothing to do with stage/tune pressure. Turbo inlet is under vacuum, never pressure.
kern4174445.00
      10-14-2021, 03:20 PM   #5
Th3Walrus
They are all slightly different construction, so they aren't from a large batch like you suggest.
      10-15-2021, 06:13 PM   #6
zen_f30
Drives: 2018 340i
The Paradigm turbo inlet looks the best IMO. I see the potential for better turbo sounds with the removal of the resonator, but I wonder if there's actually better engine responsiveness?
      10-16-2021, 12:59 PM   #7
Wires
Drives: 2016 340i xDrive
Million dollar question! My guess is you probably cannot perceive any quicker spool times. Maybe if you were tracking the car, and every 1/10 second matters.
I did the BMS silicone upper tube. It removes that resonator (didn't realize there was a lower resonator as well). I'm guessing if you did the lower, you'd hear more turbo blow off, but speculation on my part.
      10-16-2021, 06:10 PM   #8
Asvplee
Drives: Bmw 340i
They are mostly for increased induction sound (deletes the inlet muffler). Only benefit would be if you paired with an upgraded turbo that uses factory design compressor inlet where its still push to connect with lock ring, daw for example. Reason being the inner diameter isnt choked down like the factory muffled inlet.
I received my inlet from ross racing when he offered them, made a big induction sound difference. completely happy with it.
17 6MT 340i
Airlift Performance 3P
