06-29-2020, 04:39 PM | #1 |
Rep 7
Xdrive, rear wheel spin during launch
I have a 2014 435I x drive. Recently when I do a launch or use launch control I get the rear wheels spinning but front stay still. Will also get a stabilization warning and put in to comfort mode. No codes. First BMW so any help will be greatly appreciated.
FBO, custom tune, xhp stage 3 |
06-29-2020, 04:42 PM | #2 |
Rep 7,606
I assume you are not running Xdelete?
It sounds like potentially a T-case issue. Any active or shadow codes? How many times have you launched the car - a few, dozens, or hundreds? |
06-29-2020, 05:17 PM | #4 | |
Rep 7,606
I am honestly not sure if there is some ISTA or procedure to "test" the T-case; i imagine there has to be. Might need to do some research on that. Does it basically seem like you are RWD all the time? Was there a time when it used to launch fine, then all the sudden it did not? |
06-29-2020, 05:49 PM | #5 |
Rep 7
Only feels like it under hard acceleration will swing in a corner w hard accel. Was no quick on off type feeling or like something broke. I dont launch all the time but I do drive hard. It does spin every time now when launch. Makes it hard to beat those trackhawks!
05-03-2023, 10:19 PM | #6 |
Rep 25
Drives: 2017 BMW 340i xDrive
Did you ever figure this out? I’m having this issue with my 340i xDrive
launch control, transfer case, wheel spin, xdrive |
