03-14-2023, 04:07 AM | #1 |
Rep 2
Shudder Slipping on acceleration
Hi all
Picking up an issue when driving, as I accelerate the car seems to be jerking or slipping of some sort. However, if I engage the manual gears and accelerate then this doesn't happen. Any ideas? |
03-14-2023, 11:53 AM | #2 |
![]() 151
Rep 230
When you say Jerking and slipping, do you mean the car will rev up like the car is in neutral? That would indicate a transmission issue. How many miles on the car? Leaking fluid? Scan the car for the trouble codes. If you don't have any scan tools, have a local garage help you out.
03-14-2023, 12:06 PM | #3 |
![]() ![]() ![]() ![]() ![]() 648
Rep 985
Drives: 2016 F36 435x MSport
all times? or just cold?
Its fairly normal if the car is "cold" (i.e. has sat for like 8+ hours) for the ZF to slip in order to warm up the internals. Its a common topic of discussion.
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
11-09-2024, 04:40 PM | #5 |
![]() 0
Rep 2
Drives: 2017 330i
Have you identified the cause of this issue, as I’m experiencing the same problem? The engine doesn’t rev as it should when in neutral. However, when I transition from manual to automatic after stopping and then accelerate, it seems to slip into second gear. Other gears function correctly.
