BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Cold Start Delete BM3 Cat Heating Delete
      11-20-2020, 02:34 PM   #1
Icy340
Icy340's Avatar
Drives: BMW 340i
Anyone using the BM3 cold start delete on their tune ? I've had it in for the last 2 months
after installing my downpipes. I've noticed a really rough cold start & idle, anyone else deal with this as well? Car shakes heavily on cold starts 50% of the time.
Mods are are BM3 STG 2 91, CTS catted downpipe & dual resonator delete
      11-20-2020, 07:22 PM   #2
leew102
Drives: F30 BMW 340i xdrive
I had cold start delete turned on on stage 1 with stock cats, mainly because I let the car warm up a bit before I drive off. I noticed that I had some really rough cold starts where the car would start then drop down to around 800 or 900 rpm then would drop down to the normal 600ish rpm but what would happen was the car would keep dropping below the normal 600 and would cause for rough idles so I turned the cold start back on.
Icy34043.00
      11-21-2020, 02:36 AM   #3
Icy340
Icy340's Avatar
Drives: BMW 340i
Appreciate the reply ! Yea I noticed the idle is getting rougher. I always let the car warm up before I drive as well,I'm just gna take it off. Not worth harming the car, neighbors gotta deal with it lol
      11-21-2020, 03:20 AM   #4
G.Newt
Drives: CT4-V Blackwing 6MT
You're in Cali, so probably don't experience as cold as temps as we do in Denver. With cold start on, with my car sitting outside, my car would literally stall (6-speed) if I tried to go before it was done with the cold start procedure. With it off, it does do the rpm fluctuation at first, but then is good to drive after a minute or so warmup. Now that it's garaged, even with an E30 tune, it starts right up with no issues. Idles pretty steadily at 800-850rpm initially, then drops to 600ish after a minute or two.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed
DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2
      11-21-2020, 10:34 AM   #5
Supr3me
Supr3me's Avatar
Drives: Your mom crazy
I'm assuming you guys are all on OTS maps. I experienced the same with OTS and with some of my early custom tune revs. I mentioned it to my tuner and he added fuel on startup and the problem went away completely. I feel like MHD and BM3 need to add a table that looks at "if cold start delete = true; add fuel on start"
I'm no tuner but doesn't seem like that'd be hard.
2020 X3M
MG Flasher; Wedge Performance E50 tune
MSS Urban; Rohana RFX11
      11-23-2020, 01:27 PM   #6
Icy340
Icy340's Avatar
Drives: BMW 340i
See I thought it was just me, yea that would be a good option. & your correct I am running OTS map, after taking c start off no issues since then
      11-24-2020, 07:53 AM   #7
kern417
Cheapskate
4447
I've had mine off for a year and a half, running ots maps and custom tune, and it's never been a problem.
