05-21-2020, 03:14 PM | #89 | |
Rep 495
05-21-2020, 03:39 PM | #90 |
Rep 1,454
05-21-2020, 04:13 PM | #91 | |
Rep 495
Additional ZDDP and moly are things of the past. |
05-21-2020, 05:59 PM | #93 |
Rep 495
05-22-2020, 09:26 AM | #94 | |
Rep 3,189
05-22-2020, 10:00 AM | #95 | |
Rep 495
I'd love to see the UOAs that show rotella is beneficial to B58 engines. Otherwise you're promoting voodoo, same as anyone else. Tell you what, if my B58 which runs on 0w-20 OE oil and your B58 run on Rotella have a difference in wear of > 0.01% after 300,000mi - I'll personally buy you any Ferrari of your choosing. |
05-22-2020, 11:29 AM | #96 | ||
Rep 1,454
I don't think there's anything wrong with being faithful to a certain type or brand, especially if you've had good results with it in the past on other cars. If you like Rotella T6, keep using it. I'll probably stick with 0W-40 Castrol because it's cheap as fuck and has high levels of ZDDP for a gasoline oil.
2022 CT4-V Blackwing 6-speed
OzBMR574.50 |
05-29-2020, 08:28 AM | #98 | |
Rep 521
MANY oils have those now... but that's one of the things the BMW spec requires, so if you want to be sure, following the BMW spec is the easiest way to be sure. |
10-28-2020, 10:49 AM | #100 | |
Rep 1,909
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost. Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold) |
10-28-2020, 01:30 PM | #101 |
Rep 1,597
BMW and conditions for LSPI are a thing in the F30. Nothing LSPI issues so far and from looking around, forum members log.
11-02-2020, 01:19 PM | #102 |
Rep 1,909
They are a thing? From the second part of your post, I'm assuming thats probably a no lol.
02-09-2021, 09:03 PM | #106 |
Rep 1,454
Attached is my oil analysis. The Castrol 0W-40 is a thin 40 as has been mentioned and it's performing great and it's super cheap.
Looks like 6k is the most they want me to run the oil for now. That's about when I change it anyway (~5.5k). Very little/no bearing wear, the most important thing I was watching out for. I see little reason to run 0W-20 when it's typically more expensive and provides less protection, at least on paper. https://www.speediagnostix.com/new-o...ysis/bmw-ow-20
Atom Ant3.00 |
04-14-2021, 03:55 PM | #107 |
Rep 8
My first report after I dumped the 0w20 crisco from the dealer and put in LiquiMoly Leichtlaufe 5w40. I went 6800mi on purpose to see what all is going on with the b58. I will be changing it before 6k. I've changed it since and didn't get it tested. I will test this current oil as I did the LM ceratec treatment. Wondering if that will increase the moly or if I need to go back to using Mos2 once or twice a year instead.
2016 340i Sport - MHD Stage2 E30 / xHP
04-14-2021, 05:11 PM | #108 |
Rep 1,597
I would refrain from additives especially Ceratec since it has residue I can see. Our modern BMW engine has many solenoids and sensors you don't want to gunk with residue. I have no proof it was but I have oil pressure solenoids replaced twice and was using ceratec and I was taking ultra care of the car using nothing else out of the ordinary. The dealership was very curious why and asked if I was using any additives and I kept my lips zipped.
07-08-2021, 11:23 PM | #109 | |
Rep 2,897
I would like to understand why BMW changed the manual for 2018 and only recommend 0-20 or 0-30. As far as I know the engine in 2028 didn't change from prior MY's. I would like to use 5w-40 which is what my tuner is recommending (Motul or Liqui Moly) but am slightly concerned that the engine is not built for such heavy oil?? Quite confused at this point. |
07-09-2021, 12:07 AM | #110 | |
Rep 1,454
You're also in SoCal, I wouldn't sweat running 5W-40, but that's as thick as you can go.
