01-08-2021, 10:18 AM | #1 |
Rep 60
F36 Eibach Spring issue - Lower Spring Pad fitment
Hi guys,
I've recently tried to install a set of E10-20-031-05-22 Eibach springs on my F36 w/ M Adaptive suspension, and it looks like the spring doesn't sit flush on the lower spring pad the way it would with the OEM spring. Is this an issue that anyone else has faced? I can't find anything about it on the forum, so I'm wondering if this issue is a one-off. It sits very loose on the spring pad, and the only way it would fit when installing is if I cut the spring pad wall, which may cause some rubbing. Any advise would be highly appreciated. Thanks. |
01-08-2021, 11:27 AM | #2 |
Rep 3,539
Do you have any pictures? Does the shop have the rear springs right side up?
01-08-2021, 11:56 AM | #3 |
Rep 60
I found the issue. Tunershop sent a set of Citroen springs instead of the springs written on the box. Of course I'd only find this out after my mechanic attempted to install both the front spring and the rear spring, so my suspension is half-apart right now. What a frustrating experience. Thank you for your message, Farkle.
01-08-2021, 12:10 PM | #4 | |
Rep 3,539
01-08-2021, 12:12 PM | #5 |
Rep 60
Sorry to bug you again, I managed to source a local set of 06-22s just up the street from my mechanic. Would this fit a F36 440xi Gran Coupe?
01-08-2021, 12:34 PM | #6 | |
Rep 3,539
You can use Eibach's online catalog from their euro site to confirm the rear spring PNs are the same between the two kits.
Shady6747.00 |
01-08-2021, 02:46 PM | #8 |
Rep 60
Awesome, thanks a lot Farkle. The forum needs to accumulate all of the info you've provided and created a stickied thread. Appreciate it sir.
01-08-2021, 03:00 PM | #9 | |
Rep 60
I just have to avoid looking at any pics of your car, so I don't hate myself even more! Thanks for the help, smak168. You've been extremely helpful. |
smak16899.00 |
