BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > bootmod3 for BMW F series Vehicles - General Discussion
      01-05-2021, 02:37 AM   #1035
Luverse
Luverse's Avatar
Indonesia
158
Drives: BMW F30
Hi all,
can someone give me opinion about my datalog below?
https://www.bootmod3.net/log?id=5fed...729b3fe468fb58
https://www.bootmod3.net/log?id=5ff0...729b406cb66323
i think the timing is not to great.
Already send the datalog to PTF, and PTF asked me to flash back to stock and do the datalog again.
Stage 2 91 Oct on 93 Oct fuel
catless downpipe
valvetronic exhaust
stock intake
FTP charge pipe
FTP intake pipe
20k miles
Instagram: nightfall.f30
      01-05-2021, 05:10 AM   #1036
tpoddar
Drives: BMW 320i B48
Originally Posted by Luverse View Post
Hi all,
Timing is okay not great. Try the ACN 91 map, it may run better.
      01-05-2021, 06:45 PM   #1037
Luverse
Luverse's Avatar
Indonesia
158
Drives: BMW F30
So the fuel quality in my country is that bad.
Been using 93 oct fuel on 91 oct map for a better an cleaner performance, but seems its not enough.
      01-05-2021, 08:41 PM   #1038
tpoddar
I feel ya man. I'm using the 91ACN map currently on 99RON fuel + 4 RON octane booster. Bootmod3 is tuned for the amazing fuel quality and anything less than that creates problems. That is why I stick to the ACN map and performance wise it's honestly not much of a difference. Btw, here's some of my logs. They seem quite similar to yours in terms of boost targets.
https://www.bootmod3.net/log?id=5fee...0b431a1b66bdcc
https://www.bootmod3.net/log?id=5fee...729b406cb660dd
      01-05-2021, 10:24 PM   #1039
Knifeedge2k1
Drives: BMW G30 520i 2019
Which country?
      01-06-2021, 07:06 AM   #1040
Luverse
Luverse's Avatar
Indonesia
158
Drives: BMW F30
Just flashed to stock and relock DME as instructed by PTF and will perform datalogging for 2 days on 3rd gear WOT.
If ACN91 delivers better and cleaner datalog, i will flash to that map after discussion with PTF.
      01-06-2021, 07:45 AM   #1041
Luverse
Luverse's Avatar
Indonesia
158
Drives: BMW F30
Originally Posted by Knifeedge2k1 View Post
Which country?
Indonesia.
We have shell v-power 91oct, but idk if that's any better to pertamax turbo 93oct which i use
      01-06-2021, 08:19 AM   #1042
tpoddar
Do you know why PTF asked you to flash stock map? If it's just an octane issue it should be solved by using ACN map.
      01-06-2021, 07:08 PM   #1043
Luverse
Luverse's Avatar
Indonesia
158
Drives: BMW F30
Idk, when asked why, they just say flashed to stock and lock dme, then do datalog and screenshoot the diagnostic tab
It seems i had shadow code keep appearing on stage 2 and stock map
21A02D - no description available
Now ptf asked me to check my vehicle to BMW dealer
This code already appeared when i do my routine maintenance at BMW last year
BMW tech said it appear because of my aftermarket intake, and nothing to be worried.
But now i'm using stock intake for 6 months, the same code still appear.
      01-06-2021, 09:03 PM   #1044
tpoddar
This code is related to valve lift correction at idle. Ask the dealer to check the intake vanos solenoid actuator. Related thread - https://f30.bimmerpost.com/forums/showthread.php?t=1702690
      01-06-2021, 10:58 PM   #1045
Luverse
Luverse's Avatar
Indonesia
158
Drives: BMW F30
This code is related to valve lift correction at idle. Ask the dealer to check the intake vanos solenoid actuator. Related thread - https://f30.bimmerpost.com/forums/sh....php?t=1702690
For the software, i already update the i-level on February 2020. So does that mean i need to update the i-level again?
i'm afraid if the i-level is updated to the newest one, i can't flash BM3 anymore to my car
i have schedule routine maintenance on the BMW on 22 Jan, and will ask the dealer to check it.
Is intake vanos solenoid actuator expensive to repair?
      01-07-2021, 12:12 AM   #1046
tpoddar
I have no idea. I just googled the error and found the relevant problem :P
      01-07-2021, 04:41 AM   #1047
Luverse
Luverse's Avatar
Indonesia
158
Drives: BMW F30
part and labour at BMW dealer cost around $200
what a very uncommon error, even my service advisor said it's a very rare part to broke.
the will perform inspection first wether that part needs to be replace or not.
hoperfully just need i-level update
      01-14-2021, 12:58 PM   #1048
culpability
Drives: 2014 328xi Stage 1 (bm3)
gurgles
Just did my first flash to 93 Stage 1 on my N26 last night. Holy cow, the car WOKE UP... literally less than 100 miles on brand new bridgestones and they're chirping when i lightly accelerate off a speed bump!!
I've been doing some toying with the gurgle settings. I've got EXACTLY the right gurgles going on with my current flash... but it only gurgles when I'm in park. It almost seems like the RPMs aren't dropping fast enough when actually in gear for the engine to start gurgling.
Anyone else have a similar experience. Car is bone stock aside from the flash. Don't really want it making gunshots or anything but I absolutely love the little bubbly sounds when coming off the gas.
      01-20-2021, 05:41 AM   #1049
Luverse
Luverse's Avatar
Indonesia
158
Drives: BMW F30
mine doesn't even burbles on comfort, even though it's active on custom or ots setting
      01-20-2021, 06:34 PM   #1050
1slow320
1slow320's Avatar
Drives: 2014 F30 320i
All of the OTS maps are gone for me. Anyone else have this issue? My engine is N20-EWG-H-P if that makes any difference
2014 F30 320i | BM3 Stage 2 | Euromotive Catless Downpipe | GPlus FMIC | Muffler Delete
      01-20-2021, 08:11 PM   #1051
Luverse
Luverse's Avatar
Indonesia
158
Drives: BMW F30
open support ticket. still normal for me.
      01-21-2021, 10:09 AM   #1052
GreenF30N26
Drives: F30 328ix N26
I think something happened yesterday. I have all my OTS maps but they were all re-published yesterday at some point for N20-EWP-L-P.
      01-21-2021, 09:12 PM   #1053
davewes
davewes's Avatar
Drives: 2016 BMW 328i
Just checked my BM3. Maps are updated with a new release date. All my maps are showing version 4.5, released on 2021-01-20. Anyone else seeing the same?
Injen | Horsepower Freaks | Active Autowerke | VRSF
      01-22-2021, 04:13 AM   #1054
Luverse
Luverse's Avatar
Indonesia
158
Drives: BMW F30
all normal for me
B48-F-H
version is still the same
maybe there's minor update for N20 engine?
      01-22-2021, 06:50 AM   #1055
floridaorange
floridaorange's Avatar
Drives: 2013 bmw 320i xdrive
Congrats on your bubbles and gurgles!!
Stage 2 BM3
Originally Posted by GrussGott View Post
Sounds pizzagatey.
      01-23-2021, 11:43 AM   #1056
lemonchicken
Drives: 2013 328i blue
My n20 stage 2 map is updated to 3.1 which looks like a minor change. I did have some login problems and missing ots maps for a day or 2. No big deal.
What is the “boost plausibility code fix” in 3.1 for??
bm3, bootmod3
