BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Halogen to LED
      05-20-2018, 07:32 PM   #23
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Originally Posted by CDJohn1223 View Post
They fit into the stock housing. The only trickery is getting your hands and head in the wheel well at the same time. You can either look at where the bulb goes, or you can put your hands in there, but not both. I took a pic with my phone so I could see what I was feeling in there...
Good call, Ill probably do the same now that you mention it!
Glad to hear they fit properly!
      05-20-2018, 09:12 PM   #24
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Originally Posted by sspade View Post
I understand what you are saying and agree (for Low Beams) but do you honestly think my fog lights will be blinding? Arent they generally pointed much lower than headlights?
Time will tell. Reflector beam patterns are created by reflecting the bulb radiation pointing to the sides and rear. They can't control any forward radiation from the bulb, so halogens have no forward radiation.
      05-20-2018, 09:25 PM   #25
sspade
sspade's Avatar
Drives: F30
Understood. These ones do have a half ass projector/focus lens on them lol. Interested to see how they look/perform. Im no lighting expert, by any means!
      05-20-2018, 09:34 PM   #26
sspade
sspade's Avatar
Drives: F30
Originally Posted by crimson_king View Post
I am going to take a chance and buy these in the future
https://www.ebay.com/itm/S2x-H8-H9-H...EAAOSwyYFaHPGI
Those are pretty cool... have never seen a bulb that alternates between two different color temperatures. Also wrestled with the idea of yellow fogs, think they can look really nice on certain setups. Best of both worlds being able switch at will depending on conditions on mood
Let us know how they work out.
      05-21-2018, 02:17 AM   #27
rickynguyen
Drives: Bmw F30 320i sedan
Can i change xenon headlight lens with halogen head light (lens only) because my xenon headlight lens broken
      05-21-2018, 07:27 AM   #28
Billfitz
Billfitz's Avatar
Off-topic thread bombing is bad form. You should search one that addresses your question or start your own. That said, the lens is not a separate part. The entire lamp would have to be replaced.
What must be comparable is the distance from the mounting flange to the middle of the LED elements versus the middle of the filament on the halogen. The picture appears to show the LED elements closer to the flange than the halogen filament, which will give a different beam pattern. The lens on the front of the LED may give an acceptable forward radiation pattern, but it may not.
      05-22-2018, 08:55 PM   #29
sspade
sspade's Avatar
Drives: F30
Beamtech LOW BEAMS arrived and installed. I decided to take each wheel off because... why not?
Had perfect access to look and see what I was doing.
Lights work perfect and are definitely whiter/brighter than factory halogen.
      05-22-2018, 08:56 PM   #30
sspade
sspade's Avatar
Drives: F30
Before.
      05-22-2018, 08:57 PM   #31
sspade
sspade's Avatar
Drives: F30
Looking forward to the rest of the stuff to arrive. Full list with links in original post.
      05-22-2018, 08:59 PM   #32
sspade
sspade's Avatar
Drives: F30
After.
      05-24-2018, 01:44 AM   #33
rickynguyen
My xenon headlight broken, where to buy the lens only or can i change the broken lens with the lens of halogen headlight version. Thanks for your help.
      05-24-2018, 07:37 AM   #34
Billfitz
Billfitz's Avatar
OK, this time with feeling:
      05-26-2018, 01:31 PM   #35
sspade
sspade's Avatar
Drives: F30
I can confirm that all lights linked in my original post fit and function perfectly (with a bit of simple coding).
Very simple, plug and play for all. Zero modification required which is what I was hoping for. Lights are all without a doubt brighter and whiter (with an exception for the High Beams with have a slight bluish hue compared to the LEDs).
      12-01-2020, 02:30 PM   #36
BlackBetsy
Drives: 2015 BMW 328i Xdrive
I currently have the factory halogen headlights with the halogen bulbs. I am looking for a led low beam bulb that doesnt require modification or coding. What is the best option?
      12-01-2020, 03:23 PM   #37
Billfitz
Billfitz's Avatar
There are none. BTW, duplicate posts are poor forum etiquette.
      01-03-2022, 04:01 PM   #38
Erebus_F30
Erebus_F30's Avatar
Drives: F30 328i
I have the Beamtechs that You bought. No issues.
Those look so much brighter than mine and I have Hikari H7. Either that or Washington is just gloomy all the dang time lol. Any preference for high beams? I need those the most especially going through mountain roads. I love your lights!
      01-03-2022, 04:04 PM   #39
Erebus_F30
Erebus_F30's Avatar
Drives: F30 328i
Hi sspade! Do you know what size high beams are? The eBay link seems to have expired. I appreciate your help!
Just finished reading on KiesMotorsports and it seems both low and high beams are H7. Just curious if anyone else is running H7 for high beams and are they brighter than DRL H7?
      01-16-2022, 07:45 PM   #40
boyerizm
boyerizm's Avatar
Drives: BMW 328i xDrive M-Sport
DRLs are PW24W. Low and high beams are H7 which are 55W so quite a bit brighter.
I'm running Morimoto H7s which are probably not work the extra cash but gave me piece of mind. The DRLs and parking lights I got from Ijdmtoy/Amazon.
