04-05-2019, 09:58 AM | #1 |
Rep 622
320i BimmerLink Exhaust Flap
Hello all! I have a stock F30 320i. As many of you all know, there's an app called BimmerLink. And on that app, you can open up the exhaust flap. That's pretty much the only reason I want this app. Should I expect to hear a louder exhaust tone? Also, what else would I find this app to be useful for?
Ishan Achar
Former: 2004 BMW E46 325i Current: 2017 BMW F30 320i Follow @Black_Lux_Cars on IG |
04-05-2019, 02:39 PM | #2 |
Rep 3,679
If you have a 320i you don't have an exhaust flap.
floridaorange10150.00 sspade2464.50 |
04-05-2019, 03:22 PM | #3 |
Rep 293
Yes the 320i does not have the exhaust flap. Bimmerlink is pretty useless imo, I think everything was in German when I got it a while ago. BimmerCode is useful for coding, then you can use nearly any OBD linked app on the App Store for other parameters.
12-23-2020, 09:52 PM | #5 |
Rep 101
Even if you did have an exhaust flap, BimmerLink is for diagnostics and it is true you can open the flap but it's for testing purposes and once you shut off the car the flap will return to normal operation.
There is a fine line between being a hero, and being a victim.
12-25-2020, 01:54 AM | #6 |
Rep 18
I tried it for the bmw 3.20d, unfortunately there is no exhaust flap option even in the options, no flap anyway but it's a nice app to detect problems early.
01-24-2021, 09:58 AM | #7 | |
Rep 18
07-26-2022, 07:47 AM | #8 | ||
Rep 17
07-27-2022, 05:47 PM | #9 |
Rep 2,669
The MSport does, that's cool!
The non MSport does not. I coded my rear fog lights with Bimmerlink and Sport+. |
07-28-2022, 09:54 AM | #10 |
Rep 706
How can you tell if the stock 320i has an exhaust flap?
I am thinking of buying this module, valvetronics exhaust valve controller since i have an aftermarket valvetronics exhaust https://x-ph.com/valvetronic-bmw-exh...ap-controller/ |
07-28-2022, 10:18 AM | #11 |
Rep 5,456
Drives: F30
mike@x-ph.com
Will the item linked above work with a 2015 320i? Guessing not but gameson needs confirmation. |
07-28-2022, 10:29 AM | #12 | |
Rep 706
Thanks. |
07-28-2022, 12:52 PM | #13 | ||
Rep 190,777
When you say Valvetronic exhaust, do you mean an exhaust made by Valvetronic or an exhaust which uses valve controllers?
07-28-2022, 01:15 PM | #14 | |
Rep 706
My exhaust now doesn’t have the controller but have the valve flap which i currently set to closed by pulling back the flap and tie the flap adjuster to the chassis using stainless wire. |
07-28-2022, 01:18 PM | #15 | |
Rep 190,777
Which brand is the exhaust?
