11-26-2020, 03:10 PM | #45 | |
Rep 102
Give them a call |
12-08-2020, 04:28 PM | #46 |
Rep 343
Got the Akro DP installed last week on my 2018 F30 340i.
Car is stock with the stock exhaust with both flaps open mod. My observations mirror other experiences here: * Cold start is definitely louder with a metallic sound as others have mentioned * In comfort car is as quite as before. Nothing really happening below 4k rpm *Sport/Sport+, car is definitely louder with the Akro DP shinning over 4k rpm. Its hard to describe it inside the cabin but I find that its almost as loud as the ASD. Car was super quite inside the cabin after I turned off ASD but with the Akro DP and sport mode, its almost as loud as having the ASD back but its real sound which is great *more gurgles in all modes for sure I wanted something that would enhance the noise level inside the cabin while still sounding great on the outside without being disruptive. I also wanted the car to pass emissions and without causing CEL. I think the Akro DP accomplishes the mission. I would definitely do it again in a heart beat. |
12-09-2020, 12:52 AM | #47 |
Rep 3,863
@aardate
Thanks for sharing your experience as well! 👍🏼 Just one question - you write "stock exhaust with both flaps open mod" - however the stock exhaust has a single flap only....!? And I guess when you refer to 4000rpm it is just a number you picked, as if you have the flap open all the time, there is nothing changing at 4000 rpm in comfort (which is otherwise when the flap opens)? I find it interesting that you don't find it louder under 4000 rpm (in your case in any mode).
12-09-2020, 06:42 AM | #48 |
Rep 203
A little video would be greatly appreciated if you have time !
340 xdrive 6MT - HJS catted DP - MPPSK - TU HPFP - 550i clutch - VAC monoball control arms - Eibach springs - H&R antiroll bars - AutoSolutions SSK - Brembo HP2000 pads
Corvette C6 Z06 Z07 |
12-09-2020, 08:50 AM | #49 | |
Rep 343
the 4k rpm is what my ears are picking up inside the cabin, and my wife will tell you I don't hear/listen very well Its not very scientific I know but that's how it feels to me. I don't feel its louder under 4k rpm but I'm talking about just inside the cabin. I do hear more burbles and gurgles when I roll down windows though at all rpms and all modes. |
Skyhigh1879.00 |
12-09-2020, 09:00 AM | #50 |
Rep 343
As others have mentioned, its hard to capture the true impact on video but I am happy the way it has enhanced the driving experience inside the cabin.
I hope this helps. Sport+ with flap open and revving the engine to 3k-4k. |
12-09-2020, 11:11 AM | #51 |
Rep 3,863
That is quite good with the standard exhaust! Stock software too!?
Congratulations and welcome in the Akra club
aardate193.50 |
12-09-2020, 02:04 PM | #53 | |
Rep 102
This is akro dp + mppsk |
12-29-2020, 01:11 PM | #55 | |
Rep 10,256
aardate193.50 |
01-11-2021, 01:42 PM | #56 |
Rep 140
Anyone have any info on the HJS cat (in the Akrapovic DP)?
I recall hearing that the HJS cat they used was metal/steel which is more durable, provides better airflow, and needs less heat to warm up than the more common & traditional ceramic cats. Tried to find more info about this but came up empty. |
01-11-2021, 02:07 PM | #57 |
Rep 3,863
Look at the photos in my review in this very thread. You can see it is metal, unlike the OEM ceramic.
11-04-2023, 06:05 AM | #58 | |
Rep 4
Moi, olen ajatellut hankkia downpipen katalysaattorilla ( 300) - esim HJS - autooni joka on 21 mallin M440i ( G22). Koska sinulla on selvästikin kokemusta ko projektista niin kysyisin a) kannattaako harkita itse asennusta ( like velottaa 200-300 asennustarvikkeineen) b) tuleeko ongelmia lambda valon vilkuumisen kanssa b) miten katsastusviranomaiset suhtautuvat. Onko "katti" aina osa perussyynäystä vai katsovatko vain päästöarvoja ? G22 mallissa taitaa olla V-band kiinnitys molemmissa päissä ? c) onko jotakin erityistä huomioitava asennuksessa jos itse tekee ? |
11-04-2023, 06:39 AM | #59 |
Rep 4
Sorry guys, I was trying to reach one Finnish guy that has posted earlier here...that is why in Fnnish language - I can translate what I ask - maybe you others can answer these questions as well: car is 2021 M440i ( G22) with all standard and the exhaust will remain such as well except the downpipe which I am planning to replace either with a god decent price product ( HJS?) with catalysator
a)is it worth considering to do the installation by yourself and if yes what are the pitfalls ? b) any problems with the lambda light after installation ? c) any issues with the yearly inspection regarding emissions ( HJS has 300 cat but it is metal instead of the OEM ceramic) |
11-07-2023, 06:12 PM | #60 | |
Rep 145
Drives: 2016 F30 340i
11-08-2023, 10:58 AM | #61 |
Rep 3,863
That was 3,5 years ago mate
Prices have increased massively since 2020 I am afraid… :-/
11-09-2023, 04:57 AM | #62 | |
Rep 358
My $.02 - Better off with an Active Autowerke ($1500) or HJS ($1945). Both will not produce a CEL... |
11-09-2023, 07:06 AM | #63 |
Rep 3,863
Well... hard to compare to AA, but since you compare to the HJS - both the HJS and Akra have the same HJS cat converter. The only difference is the Akra is much better designed and built, made of cast iron and has better gas-flow (e.g. full diameter inlet, vs reduced as most DPs, incl HJS)....
So the 30% extra cost of the Akra does not seem totally off if you ask me. I can agree that either option is expensive. But costly and overpriced are 2 different things.
11-09-2023, 10:50 AM | #64 |
Rep 190,725
Akrapovic's craftsmanship is exceptional; their products are a work of art.
However, when comparing the cost with Active Autowerke, i can't say Akrapovic brings double the value than AA to justify it being double the price. It's not that Akrapovic's products are overpriced, but they cater to a niche where value for money isn't the primary concern. Their customers prioritize getting the best quality and exclusivity over cost. Its just a different target audience
Skyhigh1879.00 |
11-09-2023, 10:52 AM | #65 |
Rep 3,863
I agree.
But that’s also how it always is - twice the price is never twice the quality. It is not a linear ratio. You do net get two VWs when you buy a BMW for twice the price. But you do get appreciably more.
11-10-2023, 05:25 AM | #66 | |
Rep 358
