01-24-2021, 05:23 PM | #26 |
Rep 143
I've reached back out to the PTF team to see what they think we should do clearly it is becoming an issue like you said now that it is cold out again
01-25-2021, 12:29 PM | #27 |
Rep 2,485
Drives: 340Xi MG 2017
As much as I feel sorry for you guys, it's nice to see my issue isnt isolated. More people experiencing this issue means more effort put towards a solution.
So far, I tried everything they suggested and nothing gave any results. Keep me posted if one of you finds a permanent solution.
parch841.00 |
01-25-2021, 01:22 PM | #28 | |
Rep 143
01-25-2021, 01:34 PM | #29 | |
Rep 2,485
They definitely know more about their own software than I do; so i'll trust them. But if they fail to fix it, there's no way i'm gonna keep using BM3, for the sake of my neighbors peaceful mornings ahah. But i'm still hoping that they do find the issue. Finger crossed.
01-25-2021, 02:01 PM | #30 |
Rep 143
Yea it's not enough for me to purchase another software personally because there's ways to quiet it down when it does it and it isn't very frequent for me but I completely get what you mean if it's frequent it could be super annoying for the neighbors and yourself. Hoping what they have my try works I'll report back if it does or doesn't
01-25-2021, 02:07 PM | #31 | |
Rep 2,485
For me, it is an absolute deal breaker. If this issue isnt getting resolved, i'll switch software. The only negative thing is that I bought the license used. So I cant resell it.
01-25-2021, 03:18 PM | #32 | ||
Rep 24
01-25-2021, 07:09 PM | #33 | |||
Rep 143
Duncan140i18.00 |
01-26-2021, 10:12 AM | #34 | |
Rep 1,239
I have noticed here in the UK when the temps are -1oC or colder the car does have a cold start again but its nothing like the stock cold start, it holds the rpm closer to 1000rpm vs the normal idle. One thing im looking forward to the switchable maps is turning of the GTS roar for them stealthy get aways when i could be doing with making as little noise as possible! MPPSK exhaust draw backs! |
01-26-2021, 06:03 PM | #35 |
Rep 1,453
There's 3 cold starts I've experienced:
1. Normal loud start (untuned, or tuned with COLD mornings) 2. Normal quiet start (tuned/didn't meet COLD morning condition) 3. Safety, low-rpm start (when the morning is EXTREMELY OMFG COLD) Experiencing a #1 cold start when you were expecting #2 is annoying. However, I wonder if that #3 cold start is a temperature related safety mechanism. If so, I wanna keep it.
2022 CT4-V Blackwing 6-speed
01-27-2021, 08:56 AM | #36 | |
Rep 2,485
I don't see the cold starts as possible safety mechanism because there isn't any cat left to heat up before you hit the road; so I'm really puzzled right now.
01-28-2021, 02:06 PM | #37 |
Rep 2,485
It's really not that cold today (-4 celcius), and i'm still running tests and every attempt lead to the same result; i.e. cold start.
And their suggestions are sometimes pointless. Today they wanted me to download a fresh stage 2 map; not change anything in the settings and flash. I would have bet a month's worth of salary that it would do a cold start (they werent disabled), but asked them what was the point, and they kept telling me the same thing. On another hand, I tried revving the engine to bypass the cold start but it makes even more noise by doing so. But the more I waste time trying to follow PTF's troubleshooting, the more i'm trying to convince myself that I should try mastering this technique lolll At least this can lead me somewhere... I hope my patience will be rewarded.
01-28-2021, 06:59 PM | #38 | |
Rep 1,453
MaximusJ303.00 |
01-29-2021, 10:04 AM | #39 |
Rep 2,485
Good to know; last winter I had my OEM DP on so I wouldnt have noticed it.
01-29-2021, 02:28 PM | #40 |
Rep 143
I also tried fresh maps and now that it's very cold here it continues, the way I mitigate it is to right after it cold starts very lightly pressed the throttle just enough and it will quiet the car down if you continue to do so for about 15 seconds. Also going straight into drive does something similar. Not ideal but it's what I'm doing until they fix this
MaximusJ303.00 |
01-29-2021, 02:30 PM | #41 | |
Rep 2,485
01-29-2021, 08:16 PM | #42 | ||
Rep 143
01-31-2021, 08:15 AM | #43 |
Rep 2,485
Support is stalling; to a point where it’s getting frustrating.
« I went over your map and coldstart is definitely disabled. If you start it up on a cold morning RPM will be slightly higher than usual but that’s it. You can flash to stock tune and watch the difference sir. » Of course it’s disabled hence why I opened a ticket. I offered to send a video so we can start constructive troubleshooting. This is not going anywhere as it is. |
01-31-2021, 01:53 PM | #44 | |
Rep 1,453
