11-25-2020, 02:40 PM | #1 |
Rep 47
DIY: Adding more Ambient lighting, the OEM way
Hi everyone!
I'm currently in the process of retrofitting more ambient lighting to my F20 LCI with lighting package from factory. I am underwhelmed with the amount of ambient lighting that came standard, so I'm adding more using all OEM BMW parts. I'm making a full write-up over on the 2er forums, but since this retrofit can be done to nearly all F-series I'm posting a link here as well. https://www.2addicts.com/forums/show....php?t=1776040 |
11-25-2020, 03:16 PM | #2 |
Rep 16,079
With respect to what you posted in the other forum, the reason why all the wiring is present is because it's much less expensive to have the same wiring harness installed in cars with different accessory packages than to use a different harness for each package. The reason why the lamps associated with the wiring aren't present is so they can charge for them in said accessory packages.
11-25-2020, 03:33 PM | #3 | |
Rep 47
11-26-2020, 03:00 AM | #4 |
Schmollbraten
12512
Rep 1,985
Additionally we have an extra DIY section and this is wrong placed here.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
11-26-2020, 10:23 AM | #5 | |
Rep 47
If you don't have anything constructive to say, then please don't. Move on, thank you! Last edited by Beau2795; 11-26-2020 at 10:54 AM.. |
Billfitz8241.50 |
