12-23-2020, 10:19 AM | #1 |
Rep 71
Volk te 18 fitment question
I have a set of 18x9.5 et 22 and 18x10.5 et 20 volks that I would like to put on a 15 335i RWD
What would be required to make these work ? I know some camber but would I need to pull fender |
01-05-2021, 01:25 PM | #2 |
Cheapskate
4447
Rep 4,993
a lot of camber and a lot of tire stretch. That's F8x fitment.
01-05-2021, 01:46 PM | #3 |
Rep 2,152
I'd get a square set if you could. the front could work with a camber kit and around -2 camber, you could even run factory radius 255/40/18 tires. the rear... good luck.
01-05-2021, 07:23 PM | #4 |
Rep 125
so what is the deal with TE37s and difficulty in installation?
i'm a wheel noob. do TE37s not come in narrower width configurations? is that what makes the rears difficult? what about reps? |
01-08-2021, 02:53 PM | #5 |
Cheapskate
4447
Rep 4,993
They come in different sizes but because of the price. Basically the wheel market is saturated with low offset/wide sizes because more were purchased by F8x owners since F3x owners don't usually spend as much on wheels and tires. So people that want to get a deal on a used set are either waiting forever for a set to pop up in F3x fitment or buy F8x spec and do what it takes to make them fit.
01-23-2021, 01:07 AM | #6 | |
Rep 528
Recommended setup would be this but I know 9.5 square can be done. F 8.5 et36 R 9.5 et36 You could also do stretch tires in the rear I got a friend with an 18x10.75 et22 his tires are 225/40/18. They look like rubber bands and debead once in a while tho
@cheungkyf80
