06-13-2018, 01:07 PM | #1 |
Rep 1,782
So I removed my JB4 and recently went to BM3. I'm on OEM Plugs and Coils. N55 PWG latest OTS Map from PTF. Car has full power u til I cross a certain speed/RPM then I limp out. I'm in the process of getting logs. I did get these codes from the PTF agent and not sure what to make of them. I'm trying to make a longer cord right now as the one cord I have is super short. That explains the super cropped pic angle lol. Will try and pull more codes today if I can. The stock map works fine. Car has no issues. I noticed yesterday when I stomped the car (before the DT Malf) that a huge fuel cloud came out the back of my car when it took off. Almost seems like it's running super rich but I'm not sure. Will have to log it or something. The car does not have a bad TMAP ground as I tried grounding it and was not lucky. Just trying to get general feedback on the subject. I do have an open ticket with the PTF Customer Service and they are amazing.
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
06-13-2018, 02:20 PM | #2 |
Rep 1,499
following! curious to see what they come back with.
06-13-2018, 03:43 PM | #3 |
Rep 955
not going to be much help but i flashed bm3 last week on the same motor.
n55 pwg. aside from the 'known' fuel pump issue that required an 'online flash' click via the flash tool, i am having no issues at all. for what its worth the fem / kombi codes are most likely unrelated. although if they were not popping up before and are now... maybe battery? did you flash with a charger / external power supply hooked up? edit : no issues... rather... my dsc likes to kick in a lot more frequently now when i floor it |
Chicken_Joe608.00 |
06-13-2018, 03:45 PM | #4 | |
Rep 1,782
06-14-2018, 06:57 AM | #5 |
Rep 367
Unrelated to your specific issue, but how did you open your support ticket? Via email or via the bootmod3.net login, and then choosing "req support" under the "my tunes" tab?
I opened a support ticket using the latter method and haven't heard back for over a week. |
06-14-2018, 07:12 AM | #6 |
Rep 932
Support stuff they got a separate website for. A week is too long as they respond super fast every time I contact them there or support or especially the facebook group
https://bootmod3.atlassian.net/servi...tomer/portal/1 |
FSociety3816.50 |
06-14-2018, 07:13 AM | #7 | |
Rep 1,782
FSociety3816.50 |
06-14-2018, 10:51 AM | #8 |
Rep 488
In my experience, the code reading in the BM3 app is less than helpful. It tends to be very generic, or most of the time just not have a description (and also never seems to clear codes). Do you have Carly? The most recent updates added a TON of information for diagnostic codes and has been extremely helpful for me in solving issue like these.
2013 ActiveHybrid 3 (335ih) • N55 PWG • Meisterschaft GT catback • Wagner tuning catless DP and Stage 2 Evo Comp Intercooler • ER chargepipes • CTS intake • io2V3 O2 simulator • Pure Stage 2 turbo with high-flow inlet and DV upgrade • Fuel-It Stage 2 LPFP • JB4 ISO firmware • Fuel-It DIY PI Kit • bootmod3 •
Chicken_Joe608.00 |
06-14-2018, 12:10 PM | #9 | |
Rep 1,782
06-14-2018, 12:28 PM | #10 |
Rep 1,499
can you post the logs?
06-14-2018, 12:30 PM | #11 |
Rep 1,782
I don't have any logs as of yet. Long story short I need to make an extension or buy another cord. I'm making an extension as my cord was used for the agent device so it's very very short. I will do some logs in OEM stock map and this stage 2 as well
06-14-2018, 01:21 PM | #12 |
Rep 488
What spark plugs are you running and at what gap?
06-14-2018, 02:06 PM | #13 |
Rep 5,394
I wouldn't be logging under and significant load. Your DME seems to be indicating that there's a lot of knock happening. Unless you are hell bent on spinning a rod bearing or destroying a piston, I'd hold off and in the interim, go back to a stock tune or very conservative tune.
I don't think you're going to be alone in that as more flashed cars are driven in hot summer temps and start knocking badly because the tune is pushing things a bit too hard.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
06-14-2018, 02:08 PM | #14 |
Rep 1,782
Spark plugs are the oem N55 Bosch plugs gapped at whatever the dealer put in
06-14-2018, 02:09 PM | #15 | |
Rep 1,782
06-14-2018, 02:19 PM | #16 | |
Rep 488
06-14-2018, 04:01 PM | #17 | ||
Rep 1,782
06-14-2018, 06:42 PM | #18 |
Rep 1,782
Update!!
Flashed Car back to Stock. Been talking with Dzenan and I am going to log a few run this evening and try and get them to him for tomorrow or the weekend. Then will go from there
ronanz1822.50 |
06-14-2018, 09:38 PM | #19 | |
Rep 1,348
I would think tuning the car now that it is warmer would be more beneficial vs tuning the car in cold weather. It would be easier to tune out advanced timing which would be prone to knock vs tuning for advanced timing and knock under cool weather conditions. The motor likes cold weather tuning. More power. As soon as it gets warmer watch out the parameters start to change. Some tuners like with AEM stand-alone s would have a cold weather tune and a warm weather tune.
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 Last edited by ceedawg; 06-14-2018 at 09:44 PM.. |
Chicken_Joe608.00 FSociety3816.50 |
06-14-2018, 10:25 PM | #20 |
Rep 1,782
Update
So I ran the car on the Stock map and did a few logs. Car runs like a top. The issues are definitely in the tune so now it's down to the custom files. I might talk with PTF team after I send them the logs and see what they say. I'm feeling a lot better now that I know it isn't the car
Anthony235715.00 |
06-14-2018, 10:31 PM | #21 | |
Rep 1,348
06-14-2018, 10:32 PM | #22 | ||
Rep 1,782
