07-02-2018, 09:41 AM | #1 |
Rep 159
Burger Tuning Billet Tips
Hey guys, I wanted your help with something, maybe someone has run into this ?
I have the new BMS tips. I know they are supposed to be installed over your stock tips. When I place them over the oem tips, it looks like the oem tip can't sit flush inside of bms tip. The locating pin is preventing the bms tip to be fully seated against the oem one. Anyone else have this issue or is it supposed to be like that? The previous designs all had a notch for the locating pin. |
07-02-2018, 11:24 AM | #2 |
No 55mph
1623
Rep 8,479
IDK, 1st I heard of these type tips from BMS
Looked on their site & see they are new The version I had (slip on), you removed the OEM tips and installed the BMS in their place - fitment was perfect with those Why would you want tips that go over the OEM's when they are so EZ to remove to begin with, & what would be the benefit of installing over the OEM?
07-02-2018, 11:29 AM | #3 | |
Rep 5,460
Drives: F30
I have ///M etched tips from eBay that slip over and fit/look fine. |
07-02-2018, 11:35 AM | #4 | |
Rep 159
It just comes with the tips is two screws to hold the tips over the oem. |
07-02-2018, 11:54 AM | #6 |
Rep 5,460
Drives: F30
07-02-2018, 11:58 AM | #7 |
A family of bimmers
2757
Rep 7,743
I dont see a billet option for the f30. where did you find these? all i see is e9x and f8x
E90: http://www.burgertuning.com/billet_e...r_e9x_335.html F8x: http://www.burgertuning.com/billet_e...M4_M5_BMW.html The F30 option is: http://www.burgertuning.com/exhaust_tips_for_BMW.html
07-02-2018, 12:19 PM | #8 | |
Rep 159
Thanks for pointing this out. It's always the stuff right in front of you that you miss. Hmm wonder if Burger would swap them out for the correct ones. I would hate to be out $140. The correct ones are $100. Thanks everyone |
