BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > 335i Exhaust Installed on 328i (pictures and video attached)
      06-26-2017, 01:01 PM   #199
socalr53
Drives: 328i
I was looking a for a cheap 335i exhaust for quite some time, but couldn't find one under $300, so I thought I will spent $490 more and get a 335i MPE instead
Eric and his friends at Canyon Muffler, Santa Clarita did a super awesome job installing it perfectly for a very reasonable price. Here is how my M Sport 328i looks. couldn't be happier.
Thank you TurboM for the idea!
Side note: the 335i MPE wasn't a bolt on to the 328i. The muffler shop had to weld their own hangers, do a lot of cut and weld on the exhaust pipes to align it right
      06-26-2017, 08:54 PM   #200
madmortar
Drives: 2013 BMW 328i M-Sport
Sick! How's it sound?
      06-27-2017, 12:24 PM   #201
socalr53
Drives: 328i
Sounds great too. Deep, but not too loud. no drone either
I will post video after few 100 miles
      07-28-2017, 09:36 PM   #202
LittleBlackHawk
Drives: F30 --> E89
hi all, I recently get the 335i muffler on my 328, but after the mid, the exhaust flap do not close anymore. I tried three flap controllers (the one came with 335 muffler, and mine original one and one that the muffler ship has), and the flap just don't close at all. Does any one have this experience and know how it make the flap function normally? Thank you!
      08-16-2017, 01:05 PM   #203
Basswacker
Basswacker's Avatar
Drives: 2013 328i M-Sport package
just got home from having a 335 M performance exhaust installed on my 328.
https://www.youtube.com/watch?v=F1sG...ature=youtu.be
Installed at https://www.wilemotorsport.com in Walpole MA
diffuser: https://www.bavauto.com/f30pdiff335
2013 328i M-Sport Estoril blue W/335 M-Performance exhaust
Carver, Mass
      08-17-2017, 09:58 AM   #204
Domotron
Domotron's Avatar
Drives: 2014 BMW 328xi M-Sport
seems like the DP is makes everything louder lol
      08-23-2017, 02:41 PM   #205
Vinboyblue
Drives: BMW 335
I'm selling a 335 Muffler 300 CDN
      02-24-2018, 03:16 AM   #206
tonyec7
Drives: 228i M Sport
For those of you that installed the 335i exhaust on the 328i, is your exhaust valve always open no matter what mode you're in?
I installed a m235i exhaust on my 228i (wrong sub I know). And it seems to stay always open after the initial 30 seconds after turning on my car. I hear it opening up and never closing if I go to Eco or comfort.
      02-27-2018, 02:43 PM   #207
EstorilKC
Drives: 2013 BMW 328i MSport
Dang. That looks perfect. Nice work.
      02-27-2018, 03:04 PM   #208
MONSTAR
#gotboost
MONSTAR's Avatar
Drives: 2018 M2
*snip*
I know this is an old post but what diffuser is that and where did you get it??
2018 F87 M2 (09/2020 - )
Dinan Cold Air Intake |Dinan Axle Back | VRSF 6.5" Intercooler | VRSF Catless Downpipe | VRSF Charge Pipes | BM3 | MST Inlet v2 | Turbosmart VR11
2013 F30 328i (12/2015 - 09/2020) SOLD!
      03-02-2018, 06:24 PM   #209
Nd0udoinwork
Drives: Red 328i XDrive
the tips seem to be hanging kind of low
      04-24-2018, 06:36 PM   #210
awmenard
Drives: 2012 320i
Quick question, I'm about to do this mod on my 320 base model.
I have seen a few videos of people opening the exhaust on the e92 M3 and replacing the perforated pipe with a regular one.
Does the 335 exhaust have the same type of piping inside?
Thanks in advance
      04-25-2018, 12:28 PM   #211
7iM3less
7iM3less's Avatar
Drives: F80 M3 ZCP
Thanks in advance
The piping on the 335 MPE exhaust is 3"...not sure if the stock exhaust is the same but when I installed it on my 328 I had to create a bridge that scaled down 5mm.
2016 BMW F80 ZCP
Instagram : 7IM3LESS
https://instagram.com/7im3less?igshid=YmMyMTA2M2Y=
awmenard142.00
      04-25-2018, 12:31 PM   #212
7iM3less
7iM3less's Avatar
Drives: F80 M3 ZCP
A note that commonly seems to be missed throughout these install posts is the fact that (in addition to different diameters) the 335 exhaust doesn't 100% align to the original 328 pipe. Depending on how the shop marries the two you are very likely to get tips that don't center properly.
When I did mine yesterday i had to add a slight bend to my bridge...it allowed me to get optimal centering both vertically and horizontally. It took almost 20 minutes to get it right.
I didnt need new hangers like @socalr53 but as mentioned it wasn't a direct bolt on.
2016 BMW F80 ZCP
d_a_m92.50
awmenard142.00
      04-25-2018, 02:10 PM   #213
awmenard
Drives: 2012 320i
In my case I'm getting new tips and also need to cut a whole in my base bumper.
I suppose this could be seen as an advantage when it comes to fitment.
      04-29-2018, 09:55 PM   #214
d_a_m
d_a_m's Avatar
Got mine done too. Only concern i have now is the tips I ordered are aftermarket Akrapovich style. The 335i exhaust has those stubs which may prevent the tips from being placed in correctly. Has Anyone experienced this issue?
///437m wheels///Depo Headlights ///3M 1080 Carbon Fiber Interior Wrap///M-Sport Bumper Conversion///Dinan Suspension///M-Style Kidney Grilles
"If we knew what it was we were doing, it would not be called research, would it?"
      05-01-2018, 04:35 PM   #215
thatf30
thatf30's Avatar
Drives: 2017 330i M Sport
2017 BMW 330i  [10.00]
Probably only with the 328i since I did not have any issues with my 330i. Mine lined up and tips were center (340 MPE).
For anyone considering upgrading their 328/330 exhaust to 335/340 might as well spend a few bucks more and get the MPE... so worth it
Thatf30.com
      06-12-2018, 10:44 AM   #216
Rylo Ken
Drives: BMW 2014 328i
So could you essentially get any axle back exhaust (i.e. Active Autowerke 335i) and install it on to the 328i?
      06-12-2018, 09:40 PM   #217
7iM3less
7iM3less's Avatar
Drives: F80 M3 ZCP
Yes
2016 BMW F80 ZCP
      06-16-2018, 10:18 AM   #218
d_a_m
d_a_m's Avatar
Update: the tailpipe needed to be cut at the studs since they prevented non BMW tips (or at least my tips) from fitting. Overall, good look and sound.
      08-20-2018, 10:46 AM   #219
awmenard
Drives: 2012 320i
Finally picked up my 335 exhaust yesterday.
I have a base 320i rear bumper.
My plan is to fit the exhaust with quad 4" tips.
Once it's all installed I will fit a 2015 WRX rear diffuser to the back.
Here are a few Pics, please don't judge my poor photoshop mobile skills.
      08-20-2018, 11:09 AM   #220
madmortar
People will judge you putting quad exhaust on a 320i, not on your photoshop shills.
No hate intended btw, just be prepared for haters
rjd_F301999.50
awmenard142.00
