BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > 335i Exhaust Installed on 328i (pictures and video attached)
      10-29-2015, 07:21 PM   #155
TurboM
TurboM's Avatar
Drives: 2018 F82 M4 ZCP
Originally Posted by Espi2 View Post
If you are adding the 335i exhaust to a 328i do you need any additional hangers? Right now I have diffuser, clamp and 335i axle back. Want to be sure I have everything in time for install. Thanks.
That's all I needed. Used the factory hangers
      10-30-2015, 12:47 PM   #156
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
Nobody ever thought of doing a before and after dyno?
Lemania 2320
      10-30-2015, 01:27 PM   #157
tboooe
tboooe's Avatar
925
Drives: F36 428i GC, E36 M3 - gone :(
I dont think it would be worth spending the money. This swap was entirely for looks.
My build thread
2015 428i GC - Alpine White - Coral Red - M Sport
      10-30-2015, 05:03 PM   #158
chazmink
chazmink's Avatar
Drives: 2013 328i M Sport
You need the right side hanger from a 335. Alternatively, a muffler shop can alter the existing bracket with a little welding. I think that is shown earlier in the thread.
Good luck.
Best,
Charlie
2013 328i MSport Estoril Blue, 6spd MT, Premium, Tech & Drivers Assist +, Bavsound Stage One/Ghost, Bimmertech Amp
      10-31-2015, 08:57 AM   #159
TurboM
TurboM's Avatar
Good luck.
As stated before, I used the existing hangers and rubber bushings. No alterations to the mounting hardware were necessary.
      10-31-2015, 09:25 AM   #160
chazmink
chazmink's Avatar
Good luck.
Interesting. The parts breakdown for both applications is different. I've read that it doesn't align properly if you don't get the 335 hanger. Glad yours worked out.
Best,
Charlie
      10-31-2015, 10:45 AM   #161
tboooe
tboooe's Avatar
925
You dont need the hangers but on the right side the horizonal rod attached to the muffler that fits into the rubber is too short. It wont reach all the way through the rubber piece. My shop ended up cutting off the rod and welding on a longer piece.
My build thread
      11-01-2015, 09:15 AM   #162
SeanWRT
SeanWRT's Avatar
3179
I think difference is there.
At low RPM when valve is closed, the exhaust flow doesn't have to travel all the way to left side, which will either translate to a loss at low end or faster spool up or both. At high end, flow is certainly less restrictive. N20 will see gains if stock setup is truly restrictive for the power, or the flow turbo/engine makes, which is the case with a tune.
Lemania 2320
      11-01-2015, 04:30 PM   #163
TurboM
TurboM's Avatar
Mine was the same way but I've never had an issue with it falling off.
      12-03-2015, 08:35 PM   #164
Project Elite
Project Elite's Avatar
137
Drives: F30
Really wish someone did this to their non m-sport bumper to see what the turn out was.
      12-03-2015, 10:16 PM   #165
pkancel
pkancel's Avatar
Drives: BMWs
There are at least a couple of people that have done it to non-M sports, just search the forum. I almost started that way and then realized the 328i base model bumper had to be trimmed and I had only seen one diffuser that would fit on the existing bumper to make it look right. Not sure that even exist any longer.
      05-28-2016, 10:03 PM   #166
hoita
Taiwan
Drives: F32 428i
Hello,guys:
I was change my muffler again,
this time I choose Remus exhaust for 35i uses.
this installation:
http://hoita.blogspot.tw/2016/05/f32...i-exhaust.html
video:
      09-13-2016, 08:58 AM   #167
leholtet
Drives: BMW 123d
Did the exhaust hangers fit?
      09-13-2016, 09:06 AM   #168
tboooe
tboooe's Avatar
925
Yes but you may want to extend the right side hanger a bit so that it fully seats in the rubber piece. My exhaust guy just welded on an extra length metal rod.
My build thread
      09-13-2016, 10:15 AM   #169
leholtet
Drives: BMW 123d
Cool! Im definately going to do the same!
      09-14-2016, 02:32 AM   #170
leholtet
Drives: BMW 123d
Does the oem 335i exhaust make a better sound, or is it just the 335i m performance Version that does it for the N20?
      09-14-2016, 08:44 PM   #171
chazmink
chazmink's Avatar
The regular 335 muffler definitely sounds better that the original muffler on my 328i. I'm sure it's not as robust as the MPE but I got mine for $100.
Best,
Charlie
      09-15-2016, 09:41 AM   #172
bratwurst1
Drives: 2014 428i X drive
Same fitment on a 428i?
2014 428i X Drive / Dinan Sport Tuner
      09-15-2016, 09:51 AM   #173
donkey
donkey's Avatar
464
Drives: 6MT M2
If anyone in SE PA area needs a 335i exhaust shoot me a PM... I have everything except the downpipe taking up space in my garage.
      09-16-2016, 10:10 AM   #174
leholtet
Drives: BMW 123d
Just ordered a brand new 335i m performance exhaust to my 320i. So what i basically need is a clamp that goes from 60mm to 75mm?
      09-16-2016, 10:15 AM   #175
tboooe
tboooe's Avatar
925
What you have to do is have your exhaust shop add a small piece of pipe to the muffler so its diameter matches that of the pipe on your car. Then you can use the clamp. The other option is have the installers just weld the muffler to your car. I would not do that so that I can always revert back to the original muffler if I wanted.
Check out my build thread. I have a detailed post on when I did this mod.
My build thread
      09-18-2016, 01:19 PM   #176
leholtet
Drives: BMW 123d
Thanks!
Does anybody know if exhaust tips are included with 18302354340? If not- does anybody have suggestion of any? BMS wont fit MPE they say :/
