02-07-2025, 02:24 PM | #15247 |
![]() ![]() ![]() ![]() 470
Rep 478
Drives: 2018 BMW 340ix (Enzian Blue)
Oil change done at 35,000 miles.
0W-20 and OE filter. ![]()
2018 BMW 340ix - Enzian Blue
2018 BMW M3 ZCP - Avus Blue - DCT (SOLD) 2014 BMW 328i xDrive - Black Sapphire - FBO Stage 2+ (SOLD) 1995 BMW M3 - Alpine White - 5MT Instagram: @boznien |
02-07-2025, 05:53 PM | #15248 |
![]() ![]() ![]() 1102
Rep 332
Drives: 2012 335i Sport
Looks super clean- are those F80 door pulls I spy? I have eyed some of those with the red stitching but didn’t know how they would compare to the reds typically found in F30 interiors
02-07-2025, 07:20 PM | #15250 |
![]() 277
Rep 1,209
Replaced leaking turbo coolant hose, and updated the OFH
plsdntrply159.00 |
02-08-2025, 07:56 AM | #15251 |
![]() ![]() ![]() 474
Rep 548
How much of a pain was the coolant hose?
02-08-2025, 08:02 AM | #15252 |
Rep 548
Finished my FOD defense mesh. Removed the bumper and used the time to clean everything. Found an interesting hitchhiker though. And I'm pretty sure I'm set on deleting the fog lights. Please excuse the dirty car.
02-09-2025, 01:01 PM | #15253 |
![]() 725
Rep 210
Drives: BMW 330i Sport Wagon
I'm curious and need a project. What did you use for the defense mesh and where did you source it? Just as curious how you attached it - looks clean front and back.
W///AgonHo FB - @WagonHo | IG - @wagon_ho
2019 F31 330i SportWagon | M-Sport | Black Sapphire Metallic over Black Dakota 2016 F31 328i SportWagon | Sport Line | Alpine White over Beige Sensatec (sold - 2019) 2004 B5.5 Volkswagen Passat GLS Wagon | Northern Green | 5-Speed Manual (sold - 2016) BMW CCA | National Capital Chapter since 2019 - SCCA | Washington DC Region since 2021 |
02-09-2025, 02:45 PM | #15254 | |
Rep 548
The kidney grills were easy (cleaner?). I was able to hide the zip ties behind the slats. The lower grills (all three) didn't have a really good place to do that. If you zoom in, you can see the zip ties go around the horizontal/vertical slats to secure the mesh. I'm ok with that because it's honestly hard to see. The aux radiator is messed up - pretty much all the fins are bent. Swapping that out, and a fog light delete, are next on the list. |
02-09-2025, 02:50 PM | #15255 | |
![]() 148
Rep 299
_ObiJon473.50 plsdntrply159.00 |
02-09-2025, 02:55 PM | #15256 | |
Rep 548
02-09-2025, 03:19 PM | #15257 |
![]() 148
Rep 299
02-09-2025, 06:34 PM | #15258 |
Eh?
312
Rep 103
Yup, thanks! Being Sakhir Orange they are a little lighter than the Coral Red, but the only time you really notice that is in direct sunlight. It's close enough that I'm glad I put them in, they feel & look better and also make for a comfy knee rest on long drives.
thatgarrett1102.00 |
02-14-2025, 08:39 PM | #15260 |
Rep 332
Discovered just how many lights go off when the brake pad wear sensor trips- got right at 40k out of a set of Akenbono front pads, just ordered another set.
I also discovered you can trigger your panic alarm while driving with the key fob, as when I was bending down to plug my BT dongle to double check the code my keys in my locked must have hit the button, what a strange feature! If it lets me start my car then walk walk away and lock it with a fob to warm it up, I guess I’ll take that trade off though |
02-14-2025, 10:57 PM | #15261 |
Rep 18
Bought my first BMW a couple weeks back, a 2015 335i. Really wish I got an msport but I got a good deal on one that was well maintained with 64,000 miles. Oil changes every 6-8K and has recently had the valve cover gasket replaced. However, it makes a squeal noise when auto-stopping, and after some research I may need to replace the entire valve cover
![]() Today I replaced both air filters and the spark plugs. Was on the fence about also replacing the ignition coils, but after looking at them they look great. Replaced the plugs with the Bosch ZR5TPP33. I also replaced the front passenger door lock actuator. It seemed like some water was getting inside the door, which might have led to the door lock failing. It rained pretty hard on/off yesterday. Anyone have experience with this? Excited to tinker around with this car and make it mine ![]() |
02-15-2025, 02:40 PM | #15262 |
![]() 277
Rep 1,209
Cat has to come out of the way, so depending on your situation that may be an issue with space. But overall it wasn't bad
02-15-2025, 02:49 PM | #15263 |
Rep 548
02-15-2025, 05:08 PM | #15264 |
![]() 21
Rep 58
New wheels.
02-15-2025, 11:28 PM | #15267 |
![]() 22
Rep 4
I washed my car 2 days ago, and then this happened today. Minnesota weather is Bipolar
Onizukachan1975.00 plsdntrply159.00 |
02-15-2025, 11:44 PM | #15268 |
Rep 5
i just recently bought a 2018 328D so changed the oil for the first time.
Onizukachan1975.00 ssf55653.50 |
