05-25-2020, 10:54 AM | #1 |
![]() 116
Rep 182
Hey all, new to the f30 forums, but not new to BMW after having three E90s, but new to the f series generation. My 328d is a pre-LCI Model, and I have the opportunity to get some LCI OEM tail lights for cheap, however, I'm worried about the issues regarding coding and fitment and the issues about wiring the inner turn signals to function, so besides the housings themselves, what else will I need wiring wise? Does anyone sell retrofit harnesses? I'm familiar with INPA and Ncs Expert, but I don't think that applies to F30s... any help would be greatly appreciated.
2020 BMW 530i M Sport
2015 BMW 740Li M Sport 2016 BMW 328d M Sport |
05-25-2020, 11:16 AM | #2 |
![]() ![]() 1791
Rep 4,452
I just did this to my 2013 328 sedan. I used BimmerCode for coding and if I can do it anyone can. Just have to look up how to do it and follow instructions. There are videos on YouTube.
I bought new drip rails as well. I will try to put links here to help show you what I bought. Drip rail issue thread https://f30.bimmerpost.com/forums/sh....php?t=1699363 This is the harness I bought. It’s expensive but made the installation super easy. https://europeanautosource.com/bmw-l...-3-series.html Good thread for information. https://f30.bimmerpost.com/forums/sh....php?t=1180852 Had a little water leak but was fixed easily. https://f30.bimmerpost.com/forums/sh....php?t=1717758 Here is a google search with lots of info. There is a difference installing these between OEM and Depo lights. https://www.google.com/search?rlz=1C...e-gws-wiz-serp Last edited by obert; 05-25-2020 at 11:27 AM.. |
upsidedownfunnel1986.00 |
05-25-2020, 04:08 PM | #4 |
![]() ![]() ![]() ![]() 458
Rep 928
Just you bro, I bought LCI sequentials and they're the sickest things ever
OP, if you buy them elsewhere like online they come ready with the harness and much less work. |
Silverlining_m21757.00 |
05-25-2020, 04:35 PM | #5 |
![]() ![]() 1986
Rep 2,501
I installed the OEM LCI headlights. You can find an OEM retrofit harness kit for much less than $100. Part is 61122410220. Search online and you can find them for well under $100 and they are Genuine BMW OEM parts.
If you're comfortable with coding, you just have to code a bunch of stuff and you can do this with Bimmercode, though I used E-sys. Bimmercode is a smartphone app and E-sys is Windows PC software. To code you'll also need an ENET cable and if you're using Bimmercode an iOS network adapter to connect the ENET cable. Bimmercode also supports Bluetooth but I'd recommend using the ENET cable. I've attached a few files that should help you with wiring up the harness and coding the correct settings. You just need to do a little online research. I was able to get everything hooked up without a hitch. It took about an hour to do the wiring start to finish and another 30-60 minutes to get the lights installed. I'm fairly comfortable with wiring work, but this doesn't require much experience. You just have to be careful when removing pins from the old harness to put in the new harness. A pick tool should help you with that. |
05-25-2020, 05:29 PM | #6 |
I want to drive a Zamboni
![]() 1194
Rep 5,623
Drives: 13 E93 M3 18 F80 M3 16 K71
How did you get the LCI lights work in sequential format? The OEM version did not have this feature.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni ![]() ![]() |
05-25-2020, 05:30 PM | #7 | |
Rep 928
here's the link: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
05-25-2020, 05:32 PM | #8 |
![]() ![]() 1791
Rep 4,452
05-25-2020, 05:34 PM | #9 | |
![]() 1194
Rep 5,623
05-25-2020, 05:48 PM | #10 |
![]() ![]() 1986
Rep 2,501
IMO, I don't think the sequential looks particularly good. Sequential tail lights usually use at least 3 or more segments that are equally sized so you can get a sense of movement. Having two differently sized lights blinking light like that just looks like it's broken or connected incorrectly.
05-25-2020, 06:07 PM | #11 |
![]() 520
Rep 1,453
I don’t care one way or another. Of course the later ones are from 17 and above. Back in the old days, the year used to be stamped on the taillights. That would be like swapping them out so people would think you have a newer car. As far as the looks. It doesn’t matter one way or another.
05-25-2020, 06:21 PM | #12 | |
Rep 928
05-25-2020, 06:23 PM | #13 |
Rep 928
05-25-2020, 10:09 PM | #15 |
![]() 1194
Rep 5,623
Totally aggreged it's a BMW not Mustang or Audi.
05-25-2020, 10:40 PM | #16 |
Rep 928
Honestly, I bought them for me. It's your car do what you want. You guys are diving into a subject that has no business being dived into. You can go without all the extra details of wiring. He can buy the aftermarket ones without sequential.
& FYI sequentials are becoming more popular, Tacomas & tons of other cars are beginning to run them. Limiting them to one or two car brands is ignorant. |
05-25-2020, 10:49 PM | #17 |
Rep 928
05-26-2020, 06:24 AM | #18 |
![]() ![]() 12
Rep 41
05-26-2020, 10:02 AM | #19 |
![]() 116
Rep 182
I appreciate everyone's responses, this gave me a much better idea of what I was getting into. In my opinion, everyone's car is their own and I respect whatever they want to do, personally, not a fan of the sequential tail lights, they don't look bad, they just aren't my taste. I think the pre-lci tails look just as good as far as parking lights go, but the halogen brake lights and turn signals make the car look cheap and dated in my opinion, I think what I'm going to end up doing is throwing the OEM taillights up on marketplace and see if anyone wants to trade me DEPO taillights mostly because those come pre wired and I prefer the orange Euro style turn signals over the red.
05-26-2020, 12:39 PM | #21 |
Rep 928
Was pre-LCI previously. Install wasn't hard at all. Each light comes with a harness that is either for 2016+ or 2012-2015. Pre-LCI uses the 2012-2015 and the rest is just removing the trunk areas panels which can be viewed in a youtube video. Literally nothing more then a few of those expanding rivets and weather liners.
05-26-2020, 12:43 PM | #22 |
Stance to make her dance
840
Rep 2,086
I did install DIY videos on my channel. Went from Pre-LCI to LCI blacklines from Unique Style Racing. Pretty simple install. Only additional wiring to do is for the inner trunk turn signals that have to be tapped into the outer turn signals. Otherwise, plug n play!
INSTAGRAM: thompsac_m3 YouTube: ACCELERATED MOTION
2023 G80 CX M3, Individual BRG |
