BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F80 Cluster installed in my F30
      10-09-2024, 01:46 PM   #89
armenh7
Drives: 2017 340i
Originally Posted by armenh7 View Post
Does anybody know how to code out the shift lights? They are all red starting from 5000 rpm and it doesn't look good.
Answering my own question
CTR_DISP_M_SYS_TIMEOUT
CTR_DISP_M_SYS_ALIVE
CTR_DISP_M_SYS_APPL
Setting these 3 to nicht_aktiv will disable the shift lights BUT you also lose RPM if you have HUD.
      10-11-2024, 04:31 PM   #90
SuspecTARX
Drives: BMW F30 330d
CTR_DISP_M_SYS_APPL
I coded it to show the one yellow and two red shift lights a few weeks ago, only changed two of these values if I remember correctly and my M HUD still works, or by RPM on the HUD you meant the shift lights above the M HUD?
Shift lights don't flash for me anyways since I can't reach the rpm needed, so I can't test those
      10-11-2024, 04:33 PM   #91
armenh7
Drives: 2017 340i
When I disabled all 4 values, RPM overall stopped working in the HUD. Can you check which values you disabled please?
      10-11-2024, 04:34 PM   #92
SuspecTARX
These are all the differences between F30 and F80 cluster coding.
• BMW_LOGO: ag (00) -> M3 (06)
• DIG_KVA_BEREICH: 20_l/100km (14) -> 30_l/100km (1E)
• HUD_LOGO: wert_01 (00) -> wert_02 (06)
• KL_PREDRIVE_F51_DTC_SCHRIFT: nicht_aktiv (00) -> aktiv (01)
• DSC_ENABLE: nicht_aktiv (00) -> aktiv (01)
• M_DRIVE_BLINKFREQUENZ: wert_02 (00) -> wert_01 (06)
• SPA_ENABLE: aktiv (01) -> nicht_aktiv (00)
• SPA_IST_GANG_ENABLE: nicht_aktiv (00) -> aktiv (01)
• ALLRAD: allrad (01) -> kein_allrad (00)
• M_VARIANTE: ag_variante (00) -> motorsport (01)
• VZA_ENABLE: aktiv (01) -> nicht_aktiv (00)
• BR_KENNUNG: f30 (04) -> f80 (0B)
• TACHO_HUD_HYSTERESIS: wert_01 (00) -> wert_02 (02)
• SU_SW_DRDY_TIMEOUT: aktiv (01) -> nicht_aktiv (00)
• SU_SW_DRDY_ALIVE: aktiv (01) -> nicht_aktiv (00)
• SU_SW_DRDY_APPL: aktiv (01) -> nicht_aktiv (00)
• SU_SW_DRDY_2_TIMEOUT: aktiv (01) -> nicht_aktiv (00)
• SU_SW_DRDY_2_APPL: aktiv (01) -> nicht_aktiv (00)
• DISP_DCRN_ASST_APPL: aktiv (01) -> nicht_aktiv (00)
• MOST_LISTE_N_V_EMPFANGEN: aktiv (01) -> nicht_aktiv (00)
• CTR_DISP_M_SYS_TIMEOUT: nicht_aktiv (00) -> aktiv (01)
• CTR_DISP_M_SYS_ALIVE: nicht_aktiv (00) -> aktiv (01)
• CTR_DISP_M_SYS_APPL: nicht_aktiv (00) -> aktiv (01)
• ST_MDRV_2_TIMEOUT: nicht_aktiv (00) -> aktiv (01)
• ST_MDRV_2_ALIVE: nicht_aktiv (00) -> aktiv (01)
• ST_MDRV_2_APPL: nicht_aktiv (00) -> aktiv (01)
• TNK_FILTER_STEIGEND: 90_liter_h (66) -> 150_liter_h (AA)
• TNK_FILTER_FALLEND: 90_liter_h (66) -> 150_liter_h (AA)
• TNK_RW_VERBRAUCH: 8l_100km (10) -> 10l_100km (14)
• KI_PIA_ANALOG_RW_KVA: aktiv (01) -> nicht_aktiv (00)
• KI_PIA_M_SPORT_DIGI_TACHO: nicht_aktiv (00) -> aktiv (01)
• HUD_PIA_M_SPORT: inaktiv (00) -> aktiv (01)
• FDS_MENUE_TEXT_1: menue_3 (01) -> menue_4 (02)
• FDS_MENUE_SIGNAL_1: menue_3 (05) -> menue_4 (04)
• FDS_MENUE_TEXT_2: menue_3 (02) -> menue_4 (04)
• FDS_MENUE_SIGNAL_2: menue_3 (04) -> menue_4 (03)
• FDS_MENUE_TEXT_3: menue_3 (04) -> menue_4 (06)
• FDS_MENUE_SIGNAL_3: menue_3 (03) -> menue_4 (07)
• FDS_MENUE_TEXT_4: menue_3 (06) -> menue_4 (0F)
• FDS_MENUE_SIGNAL_4: menue_3 (07) -> menue_4 (0F)
• FDS_MENUE: menue_3 (03) -> menue_4 (04)
Did you pull the F8x values from an actual F8x or those are the standard F8x values the cluster you installed had?
      10-11-2024, 05:21 PM   #93
armenh7
Drives: 2017 340i
This is comparing cluster VO coding between a 340i and M3
      10-15-2024, 12:47 PM   #94
phoenixorion
phoenixorion's Avatar
Drives: 2018 BMW F30
2018 BMW F30  [8.50]
Thank you buddy.
      10-15-2024, 01:15 PM   #95
phoenixorion
2018 BMW F30  [8.50]
BimmerRetroLA helped me with the coding when I first got the cluster, you can find him on Instagram or Facebook.
I am fairly certain that it's just a matter of some coding and you should be able to see them without the adapter or xhp as I don't have those on my automatic car
I was educated by shawnsheridan on this:On ///M car, FDS signal comes from DME, and not ICM, and Gear position comes from DKG instead of EGS, so Gear Display and FDS Display's would not work. This is what you have, no FDS (Driving Mode, and no Gear).
triax37146.50
      10-15-2024, 09:08 PM   #96
sqwinny
Drives: 2013 6MT 328i M Sport
Originally Posted by oem.plus_440gc View Post
Likely going to be parting out my F80 cluster/adapter in the next month or 2 if anyone is interested, hmu.
Send me a dm if you still have it. I’ll pick it up if it’s reasonable.
MY13: IM500 n20 g25-660 Hybrid Turbo. Estimated 500whp on hybrid turbo
e80 tune + Port Injection by Navardi Tuned.
100% forged and hero build N20
Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413
IG + YT: Sqwin_n20
      10-17-2024, 11:15 PM   #97
armenh7
Drives: 2017 340i
      11-11-2024, 08:16 AM   #98
SuspecTARX
Hey, you are correct about the RPM not showing in M HUD after those values being disabled (all or like I have disabled only some of them), I just didn't notice it not showing the RPM anymore when I quickly checked it ��
      11-21-2024, 12:21 PM   #99
sqwinny
I guess it was my turn. Officially ghosted and scammed by George over at Coding Dynamics. Sent cluster and paid them for their services 3 weeks ago.
Posting this everywhere for awareness.
IG + YT: Sqwin_n20
      01-04-2025, 10:58 AM   #100
sqwinny
It's been over 2 months. No cluster. Stated they shipped it the week of Thanksgiving. nothing. George appears to have gone ghost. Avoid at all costs.
IG + YT: Sqwin_n20
      01-15-2025, 11:33 AM   #101
Ngnet
Drives: F30 340i xdrive 6mt
If coming from 6wa cluster, It’s possible to just swap the motherboard from original f30 car and mount it into f80 cluster. No need for to virginize or do any coding. Rpm in heads up will not work obviously.
      01-17-2025, 10:06 AM   #102
triax37
Drives: 2017 F31, 2014 F15, 2002 M3
Just to be clear - you just unscrewed your complete F3x motherboard, and reinstalled it into the F8x housing? Any soldering? Everything worked (except for the RPM)? I'm guessing the LED's are still orange, of course, but I may swap to white if I take my F3x cluster apart. Thanks!
      01-18-2025, 11:16 AM   #103
Ngnet
Yup, dynamic rpm won’t work but I just took a red pen and highlighted the white lines to indicates redline. See pics. I was going to go down the route of coding, adapter and all that but too expensive and effort for what it is. Gives the interior a nice vibe. Got the cluster and m3 steering wheel with airbag from a local salvage yard for $500. So all in all it’s a decent bang for buck.
      01-18-2025, 04:51 PM   #104
QueenCityLurker
Drives: 2009 135i, 2018 440i
That's brilliant. You're a G for that!
Ngnet19.50
      01-18-2025, 06:10 PM   #105
Ngnet
To clarify further, there are two circuit boards in both the f8x and f3x 6wa cluster. The first circuit board is where the connectors to the car are mounted. This board is the brain and has eprom chip which stores the car’s mileage and vin. This needs to remain with the car.
The second circuit board controls the gauge needs (speed, rpm, gas etc…). Thes is the board that can be swapped from f8x 6wa to f3x 6wa cluster to achieve this mod. It’s completely plug and play and fits right up. No soldering, cutting, coding or anything.
Warning- Do not plug in the first board from the donor cluster into your car. If the donor cluster has a higher mileage, your car can instantly jump to the higher mileage.
Do all of this at your own risk and have fun!
triax37146.50
      01-21-2025, 06:19 PM   #106
cfm56d7b
Innovative to say the least. Big fan of engineering projects which demonstrate the art of possible. Great writeup!
Ngnet19.50
      02-16-2025, 03:01 AM   #107
SuspecTARX
I wonder which of the boards controls what unit of measure (mph or kmh) the cruise control/LIM uses, as you might know this can't be changed with coding, so if you were to install a US spec cluster into a EU spec car you would have cruise control/LIM values shown in mph, like I do have in mine, minor inconvenience, but would be nice to sort it
Might try playing around with my clusters and see if anything changes
      02-16-2025, 03:06 AM   #108
SuspecTARX
How are your rpm gauges reacting after this mod? Are they displaying correctly on the larger 8.5k rpm scale or does the cluster think the max is 7.5k where the 8.5k is?
      02-16-2025, 05:43 AM   #109
Ngnet
I’m not sure about units because both the donor car and my car were us specs.
      02-16-2025, 05:47 AM   #110
Ngnet
This was something I was concerned with initially but to my pleasant surprise the rpm’s and speed display correct values without any coding. Obviously it will not reach 200mph or 8.5k rpm
