BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 2013 328i Coil Springs - same on M sport vs other models
      02-11-2025, 12:56 PM   #1
COSENT27
Drives: BMW f30 328i Xdrive
For context, I have a 2013 328 I xdrive m sport without adaptive m suspension n20 engine.
About a year and a half ago, I replaced my front suspension with new struts and mounts. In the process using a rental spring compressor from autozone, I bent one of the springs. So I ordered new springs and struts installed at the same time from fcp euro and again I'm having suspension issues front and back. Ever since I installed the new springs and struts the car has felt softer, even though I bought from fcp euro oem sachs struts and Lesjofors springs.
I'm wondering if maybe the springs that I ordered were incorrect bc I have the m sport without adaptive suspension? Are the springs different for m sport non adaptive vs others?
Yes I did input my vehicle information before purchasing from fcp euro and all the parts were verified to fit. I also replaced the steering rack bushing about 6 months ago just FYI.
My ride is really bad now, loose and clunks and rattles over every bump. I know I didn't replace the rear suspension at the time and that needs to be done now, but don't understand why my front is so bad.
Last time my front suspension went bad I took it to a bmw specialist and they said they couldn't diagnose the problem without disassembling which was far more expensive than just replacing the front struts myself. So I did the repair myself.
I can't get the car up because it has been snowing and freezing cold this entire winter.
Appreciate your thoughts and any help out there.
      02-13-2025, 05:54 PM   #2
Wires
Drives: 2016 340i xDrive
Check realoem. They will list which springs are for your car. They might be all the same, I have no idea, but realoem will list the options.
      02-15-2025, 11:06 AM   #3
COSENT27
Realoem doesn't have the spring part # for my vehicle oddly enough. I checked that before posting
      02-15-2025, 06:37 PM   #4
keithyo88
Drives: 340i msport rwd
Looks like there are a few springs that fit your car:
https://www.bmwpartsnow.com/coil-spr...bqu-j7Va-eD2Kx
Wonder which one fcp sent you.
