01-15-2020, 03:58 PM | #1 |
Rep 59
VCG leak & replacing OFHG- Need to prime oil system to avoid engine failure?
So i recently discovered that I have the typical valve cover gasket leak above the turbo which is causing oil to drip onto my downpipe resulting in alot of smoke. I want to DIY this, so I figured if I was going to replace this I might as well replace the oil filter housing gasket as well (as preventative maintenance) since the car has 78k miles, but then i started researching.
I came across alot of engine failure threads which apparently link the failure to the OFHG replacement, however i couldnt find any concrete reasons as to why it happens. I did find that BMW released documentation regarding the need to prime the engine first after "replacing anything that interrupts the engine oil supply circuit of the engine, including the Vanos gears, camshafts, bed plate sealing, engine oil pump, engine oil filter housing, cylinder hear, and engine oil cooler". After reading this I thought maybe its best to just let a good indy shop do the work so i started calling shops that specialize in BMW's in my area. I called about 10, and only 2 of which heard about any type of relation to engine failures after the OFHG install. One of which went into detail about bearing clearances and that if you do not prime the system after the OFHG change then the bearings may not get enough oil and can potentially seize the motor. His shop has been following this priming procedure since BMW released it some time ago. The second shop I spoke to the owner, who was/used to be a bmw master tech and he said that there is no need to prime the system after a OFHG install and that he does 10+ of these a week and has never done this and has never had any engines fail. So finally to my questions: 1 - If i were to DIY this, should i replace the entire valve cover, or only the gasket. Is there any engine/oil priming that would be needed by replacing only the valve cover gasket or any other parts I should replace while doing this? 2 - Has anyone found a concrete reason that links the OFHG and engine failures? 3 - If you have replaced the OFHG, did you follow this priming procedure, and if not did you do anything specific to allow for a cleaner install (drain coolant and oil first, pour oil back into the OFHG after install, etc). Currently my OFHG is not leaking but Ive also read that if it does leak its possible that the oil can cause the serpentine belt to come off the HB, shread, and move past the front mail seal and into the motor. I initially figured these would be easy DIY's but apparently thats not the case. Car currently has 78k miles, is outside of warranty, and never had any issues before this. My plan was to keep this car for a while. Any info would be appreciated. Last edited by Zyler; 01-15-2020 at 04:03 PM.. |
01-15-2020, 06:05 PM | #2 |
Rep 1,115
If it ain't broke don't fix it. No one knows for sure why they seize after OFHG, there's theories but nothing concrete. I wouldn't change it if it isn't leaking, just do the valve cover and monitor the OFHG. It has to be leaking badly to cause the belt the slip.
sspade2464.50 |
01-15-2020, 07:16 PM | #3 | |
Rep 10,351
And install a new valve cover. ya I know the genuine part runs about $500 but....
"Drive more, worry less. "
01-15-2020, 07:27 PM | #4 | |
Rep 445
I am also very worried about these cases after the OFHG job, and I am almost leaning towards getting a shop to do it if they by some chance agree to warranty it even if it costs me a large premium. I am definitely not touching mine until it starts leaking. |
01-15-2020, 07:30 PM | #5 |
Rep 141
I replaced my valve cover with the URO aftermarket one. Everything good so far. I would replace the whole valve cover since the PCV system is probably worn out.
01-15-2020, 10:49 PM | #6 |
Rep 1,934
I don't see how a VCG or OFHG change could starve anything of oil, especially the bearings. For either of those jobs the only sub task related to the bearings is draining the oil. If there was any supporting proof that the failure was related then a simple oil change should and would cause the same kind of failure.
Preciseyyc160.00 |
01-15-2020, 11:11 PM | #7 | |
Rep 1,115
01-15-2020, 11:14 PM | #8 | ||
Rep 1,934
01-16-2020, 12:52 PM | #9 |
Rep 1,827
Personal anecdotal evidence. I have done my OFHG twice (88.5k & 102.2k miles), VCG once (113.8k miles), and oil changes every 5-6k miles all in my garage. No special priming procedures done. Currently at over 126K miles. Feel free to take it for what it's worth.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
01-17-2020, 07:21 AM | #10 |
Rep 819
Drives: Bmw 335i f30 N55 ( sold)
Like I told you Bmw was going to replace my oil filter area but they decided to just do the valve cover and want me to come back after 1,000 mile to see if the bottom is actually leaking or it's just oil dripping. I wouldn't do it unless you end up seeing that is truly needs to be replaced. Good luck with the valve cover man! You'll just need patience lol
2012 bmw 335i sedan
VRSF catless DP VRSF 5? HD IC Stock intake(had open before and was sick of noise) BMS CP 550i 351m rims with 275/245 set up. No tune as of yet. |
01-17-2020, 07:22 AM | #11 |
Rep 819
Car still run strong with 126k? I too plan on keeping my 335i as long as I can. The longer I go without a car payment the better 😄😄
2012 bmw 335i sedan
01-17-2020, 07:35 AM | #12 |
Rep 67
Yes the same thing happened to me a few months back with an engine failure and it wasn't any concrete proof i made a post about it as well. But the shops that looked at my car said it could have been due to the car not being primed properly just like what you've heard. Being that is the case they stated it could cause air bubbles of some sort to get to the oil pump and then thats what causes the starvation of oil and result in a spun bearing.
Pray for Mojo429.50 |
01-17-2020, 08:03 AM | #13 |
Car Hypochondriac
335
Rep 901
I was doing some reading on rod bearings and read that pouring oil into the oil filter housing goes straight to the oil pump. This should prime the system so it has oil pressure immediately...
01-17-2020, 09:18 AM | #14 | |
Rep 1,827
I'm gonna see if I can get to 200k+
Tpriest7893215.00 |
01-17-2020, 09:19 AM | #15 | ||
Rep 819
2012 bmw 335i sedan
jh_f301306.00 |
01-17-2020, 12:06 PM | #16 | ||
Rep 819
2012 bmw 335i sedan
01-17-2020, 12:35 PM | #17 | |||
Rep 1,827
02-25-2020, 04:20 PM | #18 | |
Rep 55
How'd it go? I've been looking into this myself on the forums. If you DIY'd what pre-cautions did you take? What was the outcome? Any feedback is welcome |
03-05-2020, 04:05 PM | #19 | |
Rep 59
https://f30.bimmerpost.com/forums/sh...php?p=25716635 |
juliomadara721.00 |
03-08-2020, 10:26 PM | #20 |
Rep 25
I replaced my OFHG with a Mahle one from Carquest. Replaced both gaskets. No issues 10k miles later. I don't see how changing these gaskets will cause engine failure unless things fell into the oil/coolant passage way.
juliomadara721.00 |
03-11-2020, 06:23 PM | #21 | |
Rep 24
03-11-2020, 06:37 PM | #22 |
Rep 10,351
Man I wish I could do this job. It's so infuriating having to spend $375 in labor. F-ng BS.
