11-16-2018, 11:10 AM | #1 |
Rep 27
door trim lighting
Hi guys I bought door trim panels that change from classic to sport mode through iDrive. I have the LCI retrofit AC panel that changes from classic to sport, but I cant get the door trim panels to change through iDrive. Has anyone purchased these trim panels from Aliexpress and get them to work?
11-18-2018, 09:25 AM | #2 |
¯\_(ツ)_/¯
945
Rep 1,762
Did your car initially come with the ambient lighting in the original door cards?
11-18-2018, 04:23 PM | #3 |
Rep 27
Yes it did, but only it only had the orange. I coded my car for it to include the sport lighting. It only changes the color from orange to blue on the Radio/AC LCI trim. It is not changing the lights on the door trim. The new trim has both colors.
11-20-2018, 03:34 PM | #4 | |
Rep 13
11-21-2018, 07:15 PM | #5 |
Rep 439
how much brighter are these than the stock ones? I like the new door cards in the newer bmws but worried about aftermarket ones looking too "aftermarket"
01-20-2019, 02:15 PM | #6 |
Rep 27
01-20-2019, 02:18 PM | #7 |
Rep 27
They are a lot brighter if you have it up all the way, but you can lower the brightness in iDrive. The actual trim piece looks great in the piano black. Ive gotten many complements on them.
02-11-2019, 11:41 AM | #8 |
Rep 81
its probably because you are missing a wire. the ambient 2 wire from fem.
did the original connector from the original light in the door had 3 or 2 wires? if it had 2 you need te add a wire from fem. connector 9B. you can also check another thing. you say you can change color with the switch. that means you connected the wrong connector. on the lights there are 2 connectors. 1 with 2 wires and one with 3 wires. you need to plug the 3 wire plug in or else it will only change with the switch |
07-15-2021, 04:07 AM | #9 | |
Rep 1
HU_CIC: Colour_Switch aktiv HU_CIC: Colour_Switch_Lines sport FEM_BODY CS_type two_colours FEM_BODY PIA_DEFAULT_CS Farbe_2 FEM_BODY MAPPING_LCI_7_FUNCTION cs_2 AC panel that changes from classic to sport, but cant get the door trim panels to change,and have already check the connector all with 3 wires on it, but still can't figure out why is the door trim only shows orange light! can anyone help? |
