05-14-2018, 03:09 PM | #1 |
Rep 68
Rear toe, alignment settings?
Hi, I am after alittle advice.
Currently have a F31 M Sport with 19” 403m wheels. I have noticed the inner rears are wearing quicker than the rest of the tyre. Camber didn’t look excessive, I am assuming rear toe is causing this wear, does anybody have a setup I can use to stop the rear wear? Everything is stock, and using Conti RFT. Many thanks |
05-15-2018, 01:54 PM | #3 |
Cheapskate
4447
Rep 4,993
You'll need to bring it to an alignment shop to make sure toe is in the green range. If it's not, then get it fixed. If it is, then something else is causing the wear. i.e. too much camber for how you drive, too much tire pressure, wheel bearing, etc.
