08-20-2018, 08:11 PM | #1 |
TH320i
23
Rep 41
Car stalled, what are these codes???
I checked online already there isn't much info out there...
INTEGRATED CHASSIS MANAGEMENT (ICMQL): ***61623; D01646 Message (angle, accelerator pedal, 40.1.4) missing, receiver ICM, transmitter DME/DDE ***61623; D018E1 Message (torque, crankshaft 1, 40.1.4) missing, receiver ICM, transmitter DME/DDE ***61623; D01557 Message (wheel torque, engine 1, 41.3.4) missing, receiver ICM, transmitter DME/DDE ***61623; D01558 Message (wheel torque, engine 2, 41.3.4) missing, receiver ICM, transmitter DME/DDE ***61623; D0156D Message (wheel torque, engine 3, 61.3.4) missing, receiver ICM, transmitter DME/DDE ***61623; D01570 Message (wheel torque, engine 4, 40.3.4) missing, receiver ICM, transmitter DME/DDE ***61623; D01B3F Message (wheel torque, engine 5, 40.3.4) missing, receiver ICM, transmitter DME/DDE ***61623; D01A08 Message (wheel torque, engine 6, 61.3.4) missing, receiver ICM, transmitter DME/DDE Any info would be much appreciated ... Turned off and on and the car ran fine...
2012 BMW 320i - Catless DP - Full 3" exhaust system - Cold Air Intake - S55plugs - GFB DV+ - ProjectA Stage 2 Remap (270 hp on E20).
01-14-2019, 07:52 AM | #2 | |
Rep 137
30 mile drive in limp mode and restarted the car and it's fine. F87 M2. Thanks! |
01-30-2019, 02:19 AM | #3 |
TH320i
23
Rep 41
Erm after a long time i have finally come down to it being a faulty DME unit wether from the previous owner playing around in the engine bay without disconnecting the battery or from just degradation... My car is a 2012 model...
But i found a video from a guy in South Africa with the exact same problem.. he has it resolved at BMW SA by replacing the DME unit... So now i am in the process of finding a new or used DME unit.... I hope this helps ... once the problem has been fixed 100% i will post up the solution. Thanks
01-31-2019, 03:43 AM | #4 | |
Rep 137
Hmm that doesn't sound good. Mine is only a year old.... Do you happen to have a link to that video you mention by any chance? Thanks! |
02-09-2019, 05:03 AM | #6 | |
TH320i
23
Rep 41
