07-23-2018, 03:29 PM | #1 |
Rep 2,653
CP and IC Install Wed. 7/25
Hey guys -
So I'm having my VRSF CP and AA IC installed this coming Wednesday. The dealer quoted me 2.5 - 3 hrs. for the labor. This seems fair to me, what do you guys think? |
07-23-2018, 03:48 PM | #3 |
Rep 2,653
07-23-2018, 03:51 PM | #4 | |
Rep 77
Intercooler install is straightforward, since it just drops right out from underneath the car. Charge pipe takes some wiggling, but should be 1-1.5hrs from a dealer... |
07-23-2018, 03:52 PM | #5 |
Rep 2,653
They're cool with aftermarket parts, they just don't warranty them. They do however warranty the work though.
07-23-2018, 05:38 PM | #6 | ||
Rep 2,653
07-23-2018, 10:14 PM | #8 |
Rep 5,457
Seems fair from a dealer standpoint.
You could have done it yourself though, I promise. |
07-23-2018, 10:15 PM | #9 | |
Rep 5,457
07-24-2018, 12:06 AM | #11 |
Rep 5,457
07-24-2018, 05:03 AM | #12 | |
Rep 2,653
07-24-2018, 11:34 AM | #13 |
Rep 3,539
From a "book time" rate that's probably about right. For a practical time rate it'll probably get done in under 2hrs (if they're adding time for full vehicle inspection that might bump things up a bit).
At the track this weekend I swapped my IC in under 30min at the end of the first day (hopped off the track at 4:58PM, did a download with my coach, drove to the paddock, put the car up, and lowered it by 5:32PM). I already had my quickjack lift in place since I had the car up in the morning to swap the brake pads. Last edited by FaRKle!; 07-24-2018 at 11:41 AM.. |
07-24-2018, 11:51 AM | #14 | |
Rep 2,653
07-24-2018, 01:23 PM | #15 | |
Rep 3,539
07-26-2018, 08:11 AM | #16 |
Rep 6,989
OP - how did things turn out now that your install is done? Did you make sure to tighten the bung plug on the CP?
07-26-2018, 08:19 AM | #17 |
Rep 2,653
Yep all good. Car seems more responsive on throttle and pulls harder towards the top of RPM range. Very happy so far. No issues, fingers crossed.
wdeerfield2745.00 |
07-26-2018, 08:54 PM | #18 |
A family of bimmers
2745
Rep 7,741
I would have paid for the 2.5h labor as well. Not a bad price when you don't have to do it yourself. All comes down to what you value your time at. Sometimes throwing money at the problem is worth it. I may cough up for a spring install just because I don't want to dedicate a half day plus to it myself.
07-27-2018, 08:12 AM | #19 |
Rep 6,989
After 10 days with my new CP, all is good so far. I've pushed it hard several times with no ill effects. I really think the aluminum CP promotes better airflow into the TB as well as being stronger.
07-27-2018, 11:02 AM | #20 | |
Rep 5,392
07-27-2018, 04:00 PM | #21 | |
Rep 3,539
