BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 2014 320i - cold start rattle? (video)
      10-06-2019, 12:47 PM   #1
zummrox
Drives: 2014 BMW 320i Xdrive
Whenever i cold start my 2014 320i x drive, there is this metallic rattle noise coming from the engine bay. This sound lasts for about a minute and goes away. It goes away quicker as you rev the engine - seems to be linked to engine temperature. Never does this when starting the engine warm.
Can anyone point in the direction to what this is? I don't remember hearing this when i first got the car. See video below:
      10-06-2019, 02:59 PM   #2
lacrimarum
lacrimarum's Avatar
Russia
68
Drives: 2015 F30 320xi lci
It sounds to me like it's a wastegate rattle.
      10-07-2019, 05:11 PM   #3
zummrox
I've heard this before too. What is wastegate? something i should be concerned about?
      10-07-2019, 09:10 PM   #4
ToniD
Drives: BMW 320i
would like to know as well.
      10-08-2019, 03:41 AM   #5
lacrimarum
lacrimarum's Avatar
Russia
68
A wastegate is a valve of a turbocharger, through which compressed air bypasses in order to regulate boost pressure. In my experience, if it operates significantly wrong, engine control unit will instantly write an error and shutdown turbocharger. So I'd suggest you to check for errors (in independent shop or you could even do it yourself). If there are none, and you never notice any power losses, then it's quite possibly nothing more than sound, and there's not much to worry about.
      10-09-2019, 06:56 AM   #6
Neil07
Drives: 340
Sounds like fuel injector "tick". It is normal. Do a search on You Tube you can find videos of many cars with the same noise.
      10-11-2019, 04:57 PM   #7
zummrox
I was more referring to the first 60 seconds or so of the coldstart - there this loud metallic rattle which seems to go away once the engine slightly warms up. Sounds like absolute crap (to any bystander - hard to hear inside the cabin) although the car runs perfectly fine.
      10-11-2019, 05:03 PM   #8
Troy27
Drives: Bmw f30
My car sounds pretty much the same on a cold start. It runs great and has never thrown any codes. It bothered me at first but now I'm not worried about it.
2014, 320i, cold start, engine rattle, f30
