BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY: F30 F31 Power Folding auto dimming & dipping mirrors
Studio RSR
      09-19-2018, 06:58 AM   #23
Max18771
Italy
Drives: BMW 320d F30 Mperformance
Thanks To VIPER for DIY, i'v just do it but in my car (ITALY) the cables to be connected are not the same.
My original car with Heated mirrors, not folding, not electrocrom.
I do this by verifing schemes.
Pin 7 to pin 11 (Brown) Ground
Pin 8 to pin 2 (Blu green striped) Lin Bus
Pin 9 to pin 12 (Red) Power 12v
The only thing let me worried it's the pin 7/8/9 gauge AWG, it's 0,35mm insted 0.5mm of original +12v and ground wiring.
Max
      12-03-2018, 07:19 AM   #24
Shabnq
Drives: F-G serie
It seems that the passenger side mirror LINBUS is connected to the FEM module directly on F20. Which should be the same for F30
SSP-BTS-SP0000058811 for F20 LCI
SSP-BTS-SP0000058810 for F20 LCI no powerfold
      08-23-2020, 01:13 PM   #25
RokasLTU
RokasLTU's Avatar
Drives: Volvo V50, BMW 318d
Hello,
How to know if a switch is working?
I've bought a switch (9208111-01) but I am thinking it's not working.
Neither windows nor even lights are working. Shouldn't it be plug and play? At least for the windows.
https://youtu.be/_QUl0iXcv1Q
      09-26-2020, 03:01 PM   #26
Pogne
France
Drives: G31 530d xDrive Luxury
Originally Posted by Abi View Post
My wires are different colours. Should I still cut same pins?
The driver mirror works as it should after coding.
View post on imgur.com
Thanks!
EDIT: Works
Hey, I’m in the same boat. Did you use the same pins as the OP’s?
      10-14-2020, 07:51 AM   #27
Pogne
France
Ok, I’ve successfully added PF mirrors.
Contrary to the OP, I didn’t cut the wires but instead I’ve soldered some pins together in the switch with the Fold button. The said switch comes with only 6 pins therefore it’s necessary to solder 3 more (took them from a male PC fan plug).
Pin 7 must short with Pin 1 (ground)
Pin 8 must short with Pin 2 (Lin Bus)
Pin 9 must short with Pin 10 (power)
This way you don’t damage the original plug harness that is in the driver’s door and you could always use the original switch and recode back.
fe7565552.50
      11-15-2020, 10:27 AM   #28
Siwysdz
Drives: F30 335d
Hi POGNE.
I am to understand that you have inserted these 3 missing pins and connected with a soldering iron in the switch?
There will be no short circuit if you put the original pins in their place and connect them as shown in the diagram. I took the pins out of another switch
      11-16-2020, 04:29 AM   #29
Pogne
France
Hi,
Yes, you're understanding correctly.
Just be careful about the pins you bridge: (my colors were different than yours btw, I kept yours to be clearer)
Pin 7 to pin 1 (Brown) : Ground
Pin 8 to pin 2 (Blu green striped) : Lin Bus
Pin 9 to pin 3 OR 10 : Power 12v ==> BE CAREFUL HERE: as you initially wrote "pin 9 to pin 12" which is incorrect as there should be no wire in pin 12. Both pin 3 and pin 10 provide 12v, so you should pick one. I chose pin 10 and it's working well. Pins 7/8/9 are connected to the passenger side so by bridging these with the appropriate pins from the driver side you make everything work without cutting wires.
fe7565552.50
      11-16-2020, 04:39 AM   #30
Wibbles
Coding ECU's remotely
Wibbles's Avatar
445
Drives: M3LR
You do not need to change any wiring, you can add 3 pins in the switch pack and bridge them with the ajacent pins, then no wiring changes are needed.
fe7565552.50
      11-16-2020, 04:40 AM   #31
Siwysdz
Drives: F30 335d
Hi.
Thank you for your huge help.
I am grateful.
Regards.
Jarek
      11-16-2020, 04:41 AM   #32
Pogne
France
No worries, keep us posted about how it went
      11-16-2020, 01:35 PM   #33
Siwysdz
Drives: F30 335d
Welcome back.
There is 12v power on pin 10 and no power on pin 3.
Connector plugged into the switch when checking
Hello. There was no 12v on pin 3 because I was checking on the old switch
      11-21-2020, 02:48 PM   #34
Siwysdz
Drives: F30 335d
Hello. Connected without coding, everything works except dimming the mirrors and lowering the mirror in reverse
      12-26-2020, 11:10 AM   #35
Icona
Majesty
Icona's Avatar
Drives: 2017 BMW 320i X-Drive
Quick question: When u say ‘switch pack’ do you mean the connector or on the switch itself? Where can I get the pins? What did u use to bridge them?
      12-26-2020, 12:33 PM   #36
Wibbles
Wibbles's Avatar
445
Drives: M3LR
Switch pack = the panel in the door to control the windows and mirrors.
Pins can be bought on ebay, just add 3 to the connector and bridge them.
      12-30-2020, 05:33 PM   #37
Icona
Majesty
Icona's Avatar
Hello. You originally posted ‘added 3 pins on the switch pack’. So is it the switch pack where you add the pins or the connector? 🤷🏻*♂️
      12-31-2020, 07:54 AM   #38
Wibbles
Wibbles's Avatar
445
Drives: M3LR
You add the pins to the switch pack where the connector slots in.
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube
      01-09-2021, 10:23 AM   #39
zatelli
zatelli's Avatar
Morocco
45
Drives: 2013 RWD F30
May I kindly ask you to post a picture showing the master window switch with the pins bridged. I take it, pins were bridged at the farthest point inside the socket.
Did you add some fleece tape to insulate the bridges? Much appreciated
      01-09-2021, 03:51 PM   #40
Wibbles
Wibbles's Avatar
445
Drives: M3LR
Hope this helps:
mrpingu180.50
      01-15-2021, 04:16 PM   #41
Icona
Majesty
Icona's Avatar
Edit
Hope this helps:
Nice work!!! Thanks for clarifying that. This is most definitely a cleaner approach. I rather do this than splice the wiring. I have a few PC Fans laying around from older gaming rigs, how did u get the pins out of those kind of fans?!? I can pull the pins out of one of those fans and take it to a pro for the bridging. Also, I have a 2017 F30, will the wiring/bridging be the same with my car as yours? I just received my mirrors and haven’t got the chance to look at the wiring harness for the mirror yet.
      01-16-2021, 04:34 AM   #42
Wibbles
Wibbles's Avatar
445
Drives: M3LR
You can just buy the pins on ebay or maybe even Amazon.
The PCB's for these controllers are all the same, I have done many of these on F10's, F20,F30,F25 etc...
As you say, it saves cutting and splicing wires - that way, if you ever sell the car you can put it back to stock quickly and sell the folding mirrors as a plug and play solution (with coding)
      01-16-2021, 06:13 AM   #43
Pogne
France
If you have one of these lying around, cut the male part then strip the plastic piece. Then you may proceed with removing the tiny black insulation plastic and unsolder the pins from the wires. It takes 5-10min overall and it prevents a purchase on amazon and the like.
      01-16-2021, 10:46 AM   #44
Wibbles
Wibbles's Avatar
445
Drives: M3LR
This is the sort of thing you want:
https://www.ebay.co.uk/itm/2-to-40-W...sAAOSwjRpZVj4w
