08-12-2019, 12:29 PM | #1 |
Rep 57
Drives: 2016 435i xDrive Convertible
Whistling after MPE exhaust on F33 - someone must have a fix!
Folks, I too suffer from the infamous whistling sound that occurs under WOT past 4K RPMs. Started right after MPE install on my 2016 435i xDrive. Have scoured every post I could find on the forum and not yet have I seen a verified fix for it. The closest one was “try removing / adjusting the exhaust tips” and that didn’t work either.
Today my local dealer decided to order a new MPE after spending 4 hours diagnosing and adjusting it, but to no avail. I told the dealer that a replacement is likely not going to fix this but I am okay testing this hypothesis. So simple question for you, especially those that at some point were plagued with this same issue: what is the fix for this? How did you rectify this? I know going back to stock will fix the issue but hoping to make the MPE work. Also note that I have no desire to do any other modifications to address this as I don’t want to void my certified warranty in any way. Thx! |
08-12-2019, 01:59 PM | #3 |
Rep 57
08-12-2019, 02:16 PM | #4 |
Rep 5,369
It's not the internals of the MPE. It's the improved flow/less sound damping. What you're hearing is the air going supersonic as it blows past the wastegate flap edges when the DME opens it to manage boost. You'll hear this sound more often when it's hot out (can't tell you why it's that way). There's no fix.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
08-12-2019, 03:51 PM | #5 | |
Rep 57
08-14-2019, 10:35 AM | #8 | |
not good, but bad
333
Rep 361
They are spelled BRAKES not breaks!!!! Oh FFS, not another spark plug thread!
BreadsBMW on Youtube |
lens2069.50 |
08-17-2019, 09:40 AM | #9 |
Rep 2,639
08-17-2019, 10:52 AM | #10 |
Rep 57
So got a new replacement MPE put on by the dealer. Problem still persists. Dealer said they cannot do anything and this has been chalked up to “completely normal”. I can’t be driving around with this annoying sound so will be selling my MPE that now has a total of 50 miles on it.
Which other exhausts should I consider? |
08-18-2019, 07:17 PM | #11 |
Rep 7,606
08-18-2019, 07:54 PM | #12 | |
Rep 57
08-18-2019, 09:00 PM | #14 |
Rep 7,606
08-18-2019, 10:26 PM | #15 |
Rep 57
08-18-2019, 10:27 PM | #16 | |
Rep 57
08-19-2019, 09:55 PM | #17 |
Rep 7,606
There are tons of options. Basically depends if you want catless or catted and what your budget is. Cheapest catless is VRSF at about $250. Maximum performance benefit from catless, but you have to deal with the smell and emissions issues if you are in a strict state. Other end of the spectrum is fabspeed catted DP, which is 90+% of the performance benefit of catless, but a hefty $1400 price tag.
I'll try to post some info i have compiled in an excel file below as plain text and see if it works. The formatting wont be great but its basically: <type> <manufacturer> <description> <price> <link> Code:
Catless DP VRSF VRSF CATLESS DOWNPIPE 2012+ BMW N55 M135I/M235I/335I/435I/M2 F20/F21/F22/F30/F32/F33 $249.99 https://x-ph.com/vrsf-catless-downpipe-2012-bmw-n55-m135i-m235i-335i-435i-m2-f20-f21-f22-f30-f32-f33/ Catless DP Wagner WAGNER TUNING BMW F CHASSIS N55 DOWNPIPE $390.00 https://x-ph.com/wagner-tuning-bmw-f-chassis-n55-downpipe/ Catless DP Megan Racing MEGAN RACING BMW N55 F22/F30/F32/F87 M235I/335I/ 335IXI/435I/435XI/M2 2016+ (EXCLUDES 2012-JULY 2013) DOWNPIPE $399.99 https://x-ph.com/megan-racing-bmw-n55-f22-f30-f32-f87-m235i-335i-335ixi-435i-435xi-m2-2016-excludes-2012-july-2013-downpipe/ Catless DP ER EVOLUTION RACEWERKS ( ER) N55 DOWNPIPES M235/335/435/M2 $465.50 https://x-ph.com/evolution-racewerks-er-n55-downpipes-m235-335-435-m2/ Catless DP Enzo ENZO PERFORMANCE BMW N55 4" CATLESS DOWNPIPE $599.00 https://x-ph.com/enzo-performance-bmw-n55-4-catless-downpipe/ Catless DP Agency Power AGENCY POWER DOWNPIPE BMW 335I 435I F30 SERIES $600.00 https://x-ph.com/agency-power-downpipe-bmw-335i-435i-f30-series/ Catted DP VRSF VRSF CATTED DOWNPIPE 2012+ BMW N55 M135I/M235I/335I/435I/M2 F20/F21/F22/F30/F32/F33 $399.99 https://x-ph.com/vrsf-catless-downpipe-2012-bmw-n55-m135i-m235i-335i-435i-m2-f20-f21-f22-f30-f32-f33/ Catted DP Wagner WAGNER TUNING BMW F CHASSIS N55 DOWNPIPE $790.00 https://x-ph.com/wagner-tuning-bmw-f-chassis-n55-downpipe/ Catted DP ER EVOLUTION RACEWERKS ( ER) N55 DOWNPIPES M235/335/435/M2 $825.50 https://x-ph.com/evolution-racewerks-er-n55-downpipes-m235-335-435-m2/ Catted DP FI FREQUENCY INTELLIGENT (FI) BMW F CHASSIS N55 CATTED DOWNPIPE $1,050.00 https://x-ph.com/frequency-intelligent-fi-bmw-f-chassis-n55-catted-downpipe/ Catted DP Agency Power AGENCY POWER DOWNPIPE BMW 335I 435I F30 SERIES $1,250.00 https://x-ph.com/agency-power-downpipe-bmw-335i-435i-f30-series/ Catted DP Fabspeed FABSPEED M235 / 335 / 435 / M2 DOWNPIPES $1,395.00 https://x-ph.com/fabspeed-m235-335-435-m2-downpipes/ |
08-19-2019, 09:58 PM | #18 | |
Rep 57
I think I will stick to catted DP. |
08-19-2019, 10:00 PM | #19 | |
Rep 57
08-19-2019, 10:11 PM | #20 |
Rep 1,105
If you are getting the resonator delete and stock axelback then I'd say go with cates because it will be very quiet with a catted dp. But I'd say start with the resonator delete and see how you like it.
08-19-2019, 10:21 PM | #21 | |
Rep 57
08-19-2019, 11:35 PM | #22 | |
Rep 7,606
Tune and DP will mostly likely ruin any chance of powertrain coverage. |
mpe, performance exhaust, whistling, whistling noise |
