01-17-2021, 06:39 AM | #1 |
Rep 4,576
3 year brake fluid service
I appreciate there are a few people on here who will never have a car for 3 years....
My car due brake fluid service at end of Feb. Is it just in my head, or do you feel your brakes being less "biter" than they were? Sure I will see if there is a difference after the service...... |
01-17-2021, 07:35 AM | #2 | |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
Having the brake fluid changed should have no effect on the feel of the brakes themselves.
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
Rbrown2765.50 |
01-17-2021, 09:16 AM | #3 | |
Rep 107
Make of car doesn’t really have an effect on it but most manufactures recommend a change at between 2 and 3 years and then every two years after. Most manufacturers recommend that anything above 3% water content you want to be changing the fluid Most people won’t notice the drop in quality of the fluid but it does drop off, the peddle will start to feel different as the water compress at a different rate to the fluid , but as this is over a period of time most people don’t notice it |
Rbrown2765.50 |
01-17-2021, 09:19 AM | #4 |
Rep 725
Isn't it to do with the fluid being hygroscopic and absorbing water over time, I guess having a brake fluid with no water in and therefore a higher boiling point would perform better under harder braking situations. I doubt you would notice much difference in most situations. Still better to get it done though.
Rbrown2765.50 ukbeemerboy462.00 |
01-17-2021, 09:25 AM | #5 | ||
Rep 725
I'm not being a dick as I've only just found this out myself as I always thought it was hydroscopic too when talking about water in brake fluid. |
Rbrown2765.50 |
01-18-2021, 12:43 AM | #6 | |
Beemer Heaven
462
Rep 2,941
Scott
Rbrown2765.50 |
01-18-2021, 03:07 AM | #7 |
Rep 424
/Pedant mode on...water doesn't compress - but it'll boil earlier than brake fluid and the steam does
Techno 9000518.00 |
01-18-2021, 05:37 AM | #8 |
Rep 749
Drives: F31 320d xDrive M Sport
The only reason it should feel different (in normal driving) after a fluid change is if there is/was air in the system, either before or after the fluid change.
Old wet fluid shouldn't feel any different to new fresh dry fluid. Not under normal street driving. Brake pads/discs on the other hand can make the pedal feel different. They say to change brake fluid every 2 years (after the first change) but the fluid usually is still ok at that point, within acceptable % of water absorption.
Rbrown2765.50 |
01-18-2021, 08:04 AM | #10 |
Rep 2,048
It shouldn't make any difference IMO until the fluid gets significantly older. The biggest damage to fluid, again IMO, comes from heat rather than age. And unless you're road rallying or doing trackdays modern car brakes simply don't get hot enough to boil fluid. Those who do experience 'fade' tend to find the pedal stays the same but the slowing effect lessens and that's a result of the brake pad friction material overheating rather than the fluid going. If you feel your pedal going long after repeated big stops then that'll be your fluid 'boiling' and the moisture in it becoming gas, which then compresses and gives you the long pedal. I'd replace it reasonably regularly but if it wasn't for trying to keep 'FSH' I wouldn't be doing it every two years on a stock car that isn't ragged. Even bike brakes which get relatively hotter much more regularly and have less fluid capacity still don't need bleeding that regularly for performance.
Rbrown2765.50 |
01-18-2021, 11:35 AM | #11 |
Rep 709
I do my own brakes including fluid. Biggest difference comes from cleaning the calliper of all the built up dirt that prevents the pads and slides from moving as they should and wasting energy. This combined with new pads and discs properly bedding in makes them feel like new.
Having said that I change the brake fluid every 2 years on the cars and yearly on the bike. The fluid that comes out is always darker than what goes in. Not sure if this is from heat or the seals. An hours work and £10 worth of fluid it's no hardship. |
Rbrown2765.50 |
01-18-2021, 02:14 PM | #12 | |
Rep 944
When I was 19 I had an experience of 'fluid fade'. Driving down a very long hill (circa 3/4 mile) 30 limit in a town, nothing ahead of me, (foolishly) keeping my speed down all the way with the brakes. Traffic lights ahead at Red, that turned to Green as I approached, off the brakes, turned a bend in the road that levelled out and, at the next set of (Red) lights a couple of hundred yards further on, hit the brake pedal to find it went to the floor... Cue much pumping of the pedal to re-pressurise the system. Haven't done that again in the next 30+ years I can tell you... Under pressure the water doesn't boil easily, its when you come off the pedal that the water can be raised to boiling point, and the amount of 'slack' that needs taking up needs many presses of the pedal. If you're pushing on, you won't necessarily have the luxury of that time. Agree that, in 'normal driving' / light use you don't feel any difference under foot. Last edited by Techno 9000; 01-18-2021 at 02:22 PM.. |
Rbrown2765.50 |
01-20-2021, 12:50 AM | #14 |
Rep 4,576
Very true - the jokes took longer than I thought.
Was expecting something like this.... "During lockdown I have developed a drink problem and I am now drinking brake fluid....but I know I can stop whenever I want......." |
jackstrath658.50 |
01-20-2021, 02:22 AM | #15 |
Rep 820
I boiled the brake fluid on one of my Alfa’s at a track day years back- then it feels different!!!!
Otherwise I’ve never really notice significant differences with stock fluid changes although I’m sure there maybe a small placebo effect to make us feel better when handing over money to get it done! If there is a significant difference then I’d agree perhaps the fluid change has corrected something more than the fluid itself..... |
