08-06-2019, 08:18 PM | #23 |
Cheapskate
4457
Rep 4,995
Yep. to thisismikeyb point, lowering does nothing other than sit the car lower within the suspension's standard travel. The arc doesn't change. Any time you go over big bumps or load the suspension around turns, you're "lowering" your suspension on that side. So unless people are popping axles at track days and autox, lowering isn't the issue.
08-06-2019, 08:29 PM | #24 | ||
Rep 3,540
08-07-2019, 06:03 AM | #25 | |
Cheapskate
4457
Rep 4,995
That changes significantly when you adjust your control arms, because now the camber gain is different. Especially if your roll center moves. Adjusting with camber plates won't have the same effect to your dynamic handling regardless of ride height. You're only really changing your static camber to compensate for a crappy camber curve. |
08-07-2019, 07:31 AM | #26 | |
Rep 61
However by lowering you are putting it there all the time including when you have a lot or even full lock on and putting power through the driveshafts You would very rarely, if ever, have the suspension compressed, more than half a turn of lock and introduce full power in normal driving. When going through fast corners it is surprising how little steering lock you actually need. I can see how a combination of lowering and camber adjustment through bushings or M3 arms could be an issue, although it seems the M3 arms are enough on their own! I would probably shy away from camber adjusting bushes after reading this and stick to lowering plus Camber plates and/or correction hubs. I thought the whole reason the x-drive has SE springs is because Msport springs were too low for the CV joints in BMW's view? Last edited by motoring_101; 08-07-2019 at 07:41 AM.. |
08-07-2019, 09:41 AM | #27 | |
Rep 141
If your car started at -0.6 degrees of camber, to achieve -1.8 degrees you would have to dial in -1.2 degrees, which you did by effectively lengthen your LCA. SoCalCarGuy's car started at -0.7 degrees of camber because he is lower, to achieve that same camber he only had to add -1.1 degrees, which means his LCA should effectively be shorter than yours. With that in mind, if you were to lowered your car to match, and used the same LCA setting you have now, I'm guessing your front camber would be closer to -1.9 degrees. Since the lower your car goes, the more negative camber you get. Which should be the same effect when you are taking corners at the track, and compressing your front suspension. Your front axles should be further stretched due to your LCA's being longer. Additionally, there probably is not enough suspension travel to cause a situation where SoCalCarGuy's front hub extend past yours. This again is because your LCA should effectively longer than his. Which would mean his front wheels should not be pushed out as far, and his camber arc should be inside your camber arc. ie: less aggressive. Now the other common thing between Kies' 335ix and SoCalCarGuy's 440ix is they are both I6's, which as we know are inherently balanced by design. Could it be due to the I4's needing to have balanced crank shafts, that the lower portion of the block is wider to accommodated that? This currently is my theory to why you have not had an axle fail, but SoCalCarGuy and Kies did. Finally, you might want to put a disclaimer on your thread where you initially reported getting -1.8 degrees of camber using these bushings. Don't need anyone else breaking axles on the forums until the root cause is found.
2014 328i xDrive M-Sport EBII--M-Performance BBK/LSD/Aero--AA Signature Exhaust--Bilstein B6 DampTronic + Eibach Springs + H&R Swaybars + Millway Street Camber Plates + M3 Bump Stops + Dinan Shockware--Apex ARC-8 18x9.5et35+12mm Front Spacers w/Kumho Ecsta V730 275/35--FL-5/EC-7 18x8.5et35 w/Pilot Alpin PA4/Hakkapeliitta 10 Studded 245/45--BavSound Stage 1+Ghost Subs
Blahx929.50 |
08-07-2019, 12:37 PM | #28 | ||
Rep 3,540
When I look at my suspension as it currently sits (I'm lowered by 5.5mm, a bit less than 1/4") my LCA is angled just slightly below being parallel to the ground. At a lowered amount that the H&R springs give, the LCA is very likely already pointing at an upward angle. Therefore, when my suspension is under compression, and the LCA is at the same angle as SoCalCarGuy's, my camber is less than -1.8deg, and my arm length is shorter. Quote:
08-07-2019, 05:38 PM | #29 |
Rep 345
Got my car back today.
Asides from the axle breaking ($1200), a mount on the transfer case broke ($140) and replacing the bushings with more stock original bushings ($60) + labor and alignment ($660) shoutout to JMP autowerkz in Canoga Park |
08-08-2019, 03:06 AM | #30 | |
Rep 141
08-08-2019, 04:48 AM | #31 |
Rep 141
Better yet, let me ask you a question FaRKle! , If you were to design a suspension for a car, at what point would you want maximum camber? This would be the point at which the LCA and Strut would form a 90 degree angle, which coincides with peak of the camber arc. I would put it at maximum point of compression of the suspension, wouldn't you? Last thing I would want is for my car to start losing camber while it is under maximum cornering load. This also means at any point in the camber arc, the farther away from that point, you are losing camber.
08-08-2019, 10:08 AM | #32 | |
Cheapskate
4457
Rep 4,995
You can also upgrade your swaybars to reduce how much each side will compress in a hard turn. |
FaRKle!4023.50 |
08-08-2019, 10:36 AM | #33 | ||
Rep 3,540
There's a difference between what we want and what "is." As kern417 mentioned, the dual wishbone/A-arm design achieves what you want with increasing camber as the suspension is compressed. Why wasn't that designed in from the get go? Cost. Macpherson struts are cheaper, which is a big reason why they're more common. Also remember that as the height of the car is raised (say to OE levels) the LCA is pointing more downward, so in its arc it has more travel where camber is increased up to the parallel to ground LCA position. Of course there are other vehicle factors at play that detract from cornering ability when OE height is set, so the camber curve gain may be negated. As far as design goes, this may be a reason why BMW uses such long bump stops. We already know they engage pretty early, and are used as a device to try and slow/limit roll since they add to the spring rate. Maybe they're used to try and limit how compressed a side gets so the LCA doesn't enter the part of the arc where camber loss is high (or what BMW considers high/not acceptable).
kern4174456.50 |
08-08-2019, 01:14 PM | #34 | |
Cheapskate
4457
Rep 4,995
08-16-2019, 07:28 PM | #35 |
Rep 345
08-16-2019, 09:53 PM | #36 |
Rep 1,934
Wondering why people here don't opt for camber plates more often? Is there something I'm not aware of when running those??
08-16-2019, 09:54 PM | #37 |
Rep 681
Typically the added noise. There's only a small bit of NVH, if any with using an LCA camber bushing.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
08-17-2019, 10:02 PM | #38 | |
Rep 205
Drives: 14 F30 335i xDrive
Regarding the axles, this is my second xDrive 3 series and I've probably driven over 100k miles lowered between the 2 cars. Some has been with stock top hats. Some has been with camber plates. I've never had an axle problem. And my cars have been fairly low. Like almost tucked to slightly tucked low. The problem is definitely the lower bushings pushing the hubs out and thereby pulling the axle joints apart. Similar to adding the longer M3 lower control arms. Just avoid doing those camber bushings. That way the axles should be able to stay within the designed range. And anyone should be fine as long as there's not other problems. |
08-17-2019, 11:12 PM | #39 | |
Yoda of mods
1676
Rep 3,007
Drives: X5 RWD
Current: 2020 Explorer ST (Agate Black Metallic) AWD, F15 SGM RWD
kern4174456.50 |
08-18-2019, 12:36 AM | #40 | |
Rep 681
2006 997.1 C4S |
08-18-2019, 02:06 AM | #41 |
Rep 205
It's true there are different tolerances for people. But I'd hardly say it was a huge difference in NVH. To me it was like a 10% or slightly more increase. I didn't find I had to start rasing my voice in the car to have a conversation. Much less mild than a down pipe or slightly aggressive exhaust for noise. Little vibration more through the steering wheel. Which can be good for starting to get some road feel back in the car. Vibrations weren't enough for me to feel through the seats. But there are other factors like tires and which shocks or springs and which plates you use.
08-18-2019, 09:07 AM | #42 | |
Cheapskate
4457
Rep 4,995
08-18-2019, 06:05 PM | #43 |
Rep 205
I do agree, there is an increase in road noise. Just not so much it makes the drive unbearable. But, like we said, each person has their own version of what is unbearable to them.
You also bring up another point, camber plates bring more maintenance. If you leave them on year round, the bearings will wear faster. And make more noise as a result. I put new bearings in mine this spring for that very reason. I don't mind because it they don't cost much and I can change them in just a few hours, start to finish. But if you don't do your own work it would be a costly maintenance to pay someone to change them every year or so, and an inconvenience. Definitely something to consider. |
