BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding 5AG retrofit
      10-24-2017, 08:11 AM   #1
drapi13
Drives: 435xi
Coding 5AG retrofit
Hi guys i tried to code 5AG but i have problem with CAF files:
So after installation i updated the VO, i coded all modules and than i tried to initialize flex-ray... but every time the initialization was successful when i should get error since the HC2 module wasn't coded yet. So if the flexray initialization was successful i wasn't able to see HC2 (or SWW in ISTA+). So i opened port 4 flex ray with tool32 and since then i was able to see HC2 BUT!!! :
In this step i should create a Cafd file for HC2.
I have two HC2 modules one new and one used.
My i-step is F020-15-07-502
On the used HC2 e-sys shows me files form y2012
and on the new one i get from:
F20-16-03-500 till F20-17-03-505
So non is compatible with the car i inserted F20-16-03-500 but in ISTA+ i get :
Ofc coding in ISTA does nothing and if i reinitialize flexray with ISAT+ it closes port 4 and SWW disappears.
Can some one help me with some advice ?
      10-28-2017, 11:47 AM   #2
drapi13
Drives: 435xi
Enyone ??
      04-07-2018, 05:03 PM   #3
deneyer
Belgium
29
I have the same problem did complete retrofit, initalised flex ray didn't get error but succes and no HC2 module to find. So cant installed CAFD file
Don't have tool32 so can't open flexray.
Anybody any ideas what the problem is?
      12-15-2018, 09:09 PM   #4
markqu
Drives: BMWf34
hi,i have same problem with you
Originally Posted by deneyer View Post
I have the same problem did a complete retrofit, initialised flex-ray didn't get error but succes and no HC2 module to find. So cant installed CAFD file
I have the same problem with you, do you hc2 module found, thx
      12-16-2018, 03:33 AM   #5
deneyer
Belgium
29
Probably means you bought the wrong master/slave module
      12-16-2018, 08:04 PM   #6
markqu
Drives: BMWf34
I already open the port by tool32, hc2 module was found and sww working now
but had an error code in Rheingold, that remind initialization FlexRay.
but the FlexRay port will be closed when I initialization FlexRay. what can I do next?
Thx
      03-19-2021, 09:33 AM   #7
nyuly
Drives: F34
Thx
HI , i have the same problem . Did you solved it ?thanks .
      03-21-2021, 05:23 PM   #8
nyuly
Drives: F34
Problem solved .
      09-12-2021, 01:16 AM   #9
PisuM
Romania
Drives: 320D
Originally Posted by nyuly View Post
Problem solved .
Hi,
How did you resolved the problem? In my case , tried with tool32 0x03;0x01 and still with EIN status.is there something i am missing? Could some give an advice?
      09-12-2021, 03:24 PM   #10
Siki78
Switzerland
30
Drives: F30
reset flexray after opening port
steuern_flexray_pfad=>0x03;0x01=>F5
steuern_reset_learn_flexray=>F5
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and ASD
      10-17-2021, 11:58 AM   #11
iansolway
iansolway's Avatar
Drives: BMW F20
uy
