BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > what type of fluid to use for transmission and differential?
      11-23-2020, 06:51 PM   #1
airwolf09
I was going to change the transmission fluid and differential but not sure what to use. can someone let me know what is recommended for F30 328i besides the manufacturer one?
There are Liqui Moly ATF Top Tec 1800 that sell as a kit for F30. Is that a good fluid to use for F30 8-speed auto?
what about rear differential Fluid? what is the recommendation or what should be the one to use?
How many liters do I need and what are the expected liters to put back?
      11-24-2020, 11:16 AM   #2
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
Just get the kit from FCP Euro if you are unsure.
      11-24-2020, 07:35 PM   #3
airwolf09
I think I'm going to stick with ZF® - LifeGuardFluid 8 as it is the same as OEM. not sure if Liqui Molly is compatible with OEM fluid as the fluid can't completely drain off 100% the transmission.
I'm still having a hard time finding the right differential fluid for the axle.
      12-03-2020, 06:55 AM   #4
dmaxdmax
dmaxdmax's Avatar
Drives: 2016 M235i 6-spd
Wondering if you've found your answer.
For my 340i xDrive, the front diff takes G2 Hypoid Axle Oil...the rear G1.
I show just half a liter for the front diff...wondering if that's right--realoem didn't show a quantity needed.
Have you found a listing of fluid capacities?
'92 325i, '99 328i, '16 340i, '16 M235i all manuals
dmax on FB
My last pre-covid standup set
      12-03-2020, 07:13 AM   #5
airwolf09
I emailed Red Line and they suggested that I use Red Line Gear Oil 75w85 for my 2016 and 75W90 for my 2013.
I'm gonna stick with Red Line Gear Oil 75w90 for both to make my life simple
      12-03-2020, 04:28 PM   #6
dmaxdmax
dmaxdmax's Avatar
I'd like my life to be simpler...I just got my fluids, but now I'm worried if I'll have enough for front diff.
If you've done this, does 500ml seem right for the front diff...want to make sure I have enough before I start.
I've gotten one confirmation, but I've learned to trust no one, however trustworthy seeming!
dmax on FB
      12-04-2020, 04:37 AM   #7
airwolf09
My car is not xdrive. I have rear-wheel drive only so I can't help you much.
      12-04-2020, 05:52 AM   #8
dmaxdmax
dmaxdmax's Avatar
I figured out later...didn't bother to edit...sorry!
Anyway, I liked your TV show back in the day!
I'm pretty sure the front diff just takes 500 ml. If I'm short on it, I'll figure it out.
F'n bmw...no drains for fluids. tsk tsk
dmax on FB
      12-07-2020, 06:37 PM   #9
Honeybadger23
Drives: 2012 f30 328i sportline
I've been using redline fluid for my diff.
      12-08-2020, 05:49 PM   #10
USAF_Driver
USAF_Driver's Avatar
Drives: F33
I have a F33 and use Liqui Moly ATF Top TEC 1800 as you have pictured.
The FCP Euro Kit I purchased comes with 7L but you'll only use about 5L.
I have already done my spark plugs, oil change, cabin filter, engine filter, brake fluid and now will perform the transmission flush with filter replacement. I have saved well over $1000 in service costs.
I live in FL and it has been cold, as soon as it warms up I will tackle the tranny flush.
Good luck.
Stay cool and as always, Thank you!
__Driver__
'Merica"
      12-10-2020, 02:27 PM   #11
thejeremyman9
4364
Good luck.
FYI you don't really flush. You do Pan (which is the filter), and new fluid. Yes, this means you dont get all the fluid.
