09-02-2021, 05:35 PM | #243 |
Rep 2,302
Did you set E-Sys to this psdzdata?
I don't think so, because as i said your loaded psdzdata are from 2017 which doesn't contain the 794_017... So go into the settings of E-Sys and change the folder for the psdzdata. Or copy the psdzdata folder from your desktop to the folder C:/Data/ |
09-02-2021, 05:46 PM | #245 |
Rep 40,774
cafd_00000794.caf.017_068_021 is there.
But, psdzdata folder shows it is on your desktop. The psdzdata folder should be in C:\data folder so you have c:\data\psdzdata.
09-02-2021, 07:52 PM | #246 |
Rep 57
Success!!!!!!!sort of. The car took the codes and esys did what it needed to do. No heat yet to the steering wheel, but that is likely my mistake in the installation. Now I have to go back and re-do all the changes I have made in the last 3 years with bimmercode, I did not know those changes would get wiped out. Anyone know how to use esys in that manner?
Much, much Thanks to Shawn und vielen vielen Danke zum Atze |
atzebmw588.00 |
09-02-2021, 10:02 PM | #247 | |
Rep 40,774
09-26-2021, 02:41 AM | #248 |
Rep 8
Hi,
I wanted to code enable TPMS on my car F30 330e. I'm using E-sys Launcher Pro v2.8.2.162 & E-sys 3.27.1 with PSdZData_Lite v.4.16.32. I managed to establish connection via VIN and READ FA. However, when i "ACTIVATE FA", i'm getting "psdz error: no FP could be generated from FA. Not all elements of FA found in FA2FP: HO-WORD AKSA [72]" Could someone assist me please? |
09-26-2021, 05:08 AM | #249 | |
Rep 2,302
I just tested this for my car. No problems with "AKSA" and psdzdata 21_03, but the same problem with psdzdata 19_03 or 20_11. Also when i don't know what AKSA means. But here the psdzdata 21_03 for you. https://mega.nz/file/9CJVnQ7Z#oOeDQV...ZtoERzDh5tpB34 The 21_03 is not perfect for your old E-Sys version, because there can arise new problems, but you could try it. |
09-26-2021, 06:40 AM | #250 | |
Rep 8
will give a try with the new psdzdata |
12-09-2021, 11:37 AM | #252 |
Rep 40,774
PM sent.
12-23-2021, 06:38 AM | #253 |
Rep 3
Just got everything set up, but I’m also getting a CAFD file not found error — for the HU_NBT module. I guess I need the psdzdata update too. (2018 X35D, using F025 Target Selector - correct?)
Thanks! |
12-23-2021, 07:45 AM | #254 |
Rep 40,774
Yes, F025. PM sent.
12-27-2021, 08:40 AM | #255 |
Rep 96
Hi.
I have the same problem, please a solution? I have PSdZData_Lite_v4.33.11 HKFM2 [d] readCPS o.k. CAFD_00002098_004_011_010 Fehler: File for "cafd_00002098-004_011_010" not found! [C012] |
12-27-2021, 09:10 AM | #256 |
Rep 40,774
I replied to your same PM.
01-01-2022, 05:43 PM | #257 |
Rep 96
Good evening to all and we wish you happy years!!!
To ask two questions. first question: I have changed some settings with the program E-Sys in the car which did not show any change and was not activated, the questions are: do I have to reset it as it was originally or can I leave it as it is? second question: in the photo why does it show me three options? which one should I choose? thanks in advance |
01-01-2022, 05:48 PM | #258 | |
Rep 40,774
ACSM has 3 CAFD. Use 1st one.
01-01-2022, 06:58 PM | #259 |
Rep 96
Thank you very much for the answer and for all the help you give me. sorry i do not know english well and i can not understand the answer to the first question, can you please be clear? can you please explain me better? Last edited by alex_th32; 01-01-2022 at 08:11 PM.. |
01-01-2022, 10:15 PM | #260 |
Rep 40,774
No need to reset it. You can leave as is.
01-05-2022, 02:00 PM | #262 |
Rep 17
I messed somehow my Kombi module when tried to FDL code. Cannot find CAFD file at all. I was planning to reinstall PSDZdata files but couldn't find that anymore. Can someone help ?
01-05-2022, 02:20 PM | #263 | |
Rep 40,774
* NOTE: Injecting CAFD (Detect CAF for SWE) and Flashing ECU's with >= v.4.17.20 PSdZData requires using newer E-Sys 3.30.0 or higher. PM sent.
