10-05-2017, 05:49 PM | #1 |
Rep 6
Exterior Door Projector Aftermarket
Hey guys. Have a 430 GC. I was wondering is there a way to retrofit the door projector on the car? The one with the BMW logo when you unlock the car? And is it an easy install? Don't know why but i think its kind of cool and was hoping to put it on my car. Thanks
10-05-2017, 09:23 PM | #2 |
Rep 16,082
I put these in my F34, it took five minutes each.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
10-05-2017, 10:41 PM | #3 | |
Rep 6
10-06-2017, 08:33 AM | #5 | |
Rep 4,031
I have the OEM in the base of the door, 5 minute job to change them over.
2012 BMW 328i E93 | Deep Sea Blue Metallic - 2015 BMW 328i F31 MSport Sports Wagon | Alpine White - BMW CCA DelVal
10-06-2017, 10:56 AM | #6 |
Schmollbraten
12512
Rep 1,985
I second that, you wouldnt need a pry tool, just use one of your keys to lift the puddle light, pull it outta the hole and change it (with or w/o new adapter cables) to aftermarket lights. No big deal.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
10-06-2017, 08:32 PM | #7 |
A family of bimmers
2747
Rep 7,742
The knockoff ones will mess with your comfort access. Go with oem.
10-06-2017, 09:01 PM | #8 | |
Rep 488
Read over this thread for others with the same issue: http://f30.bimmerpost.com/forums/sho....php?t=1396657
2013 ActiveHybrid 3 (335ih) • N55 PWG • Meisterschaft GT catback • Wagner tuning catless DP and Stage 2 Evo Comp Intercooler • ER chargepipes • CTS intake • io2V3 O2 simulator • Pure Stage 2 turbo with high-flow inlet and DV upgrade • Fuel-It Stage 2 LPFP • JB4 ISO firmware • Fuel-It DIY PI Kit • bootmod3 •
10-08-2017, 08:53 AM | #9 |
Rep 164
I must be lucky I have not had any problems since I put these lights in my 335. When my daughter and sister saw them they wanted a set for their cars. I put a set in a 650I and X3 and so far they have had not problems. I would say the lights have been in for 2 - 3 years.
10-08-2017, 09:19 AM | #10 |
Schmollbraten
12512
Rep 1,985
Nonsens, had comfort access and never a single disturbance with them.
10-08-2017, 10:02 AM | #11 |
Rep 16,082
+1. The only time they pass any current is when the door is open, otherwise electrically speaking they might as well not be there at all. Even when the door is open they're just lights, LED at that, which do not create EMI/RFI that could conceivably interfere with CA.
Dang3r12512.00 |
10-08-2017, 02:22 PM | #12 |
Rep 488
I would tend to agree with you, and certainly did up until I experienced the issue myself. I'm sure the aftermarket ones come from different manufacturers, so perhaps one of them is using some really low quality parts that aren't shielded and causing RF interference on the key.
All I can say for 100% certainty is that I never had a "key not detected" issue before installing them, and haven't had once since removing them.
wdeerfield2746.50 |
10-08-2017, 02:42 PM | #13 |
Rep 16,082
I guess that's not impossible. Most are all plastic, the ones I linked to are aluminum, but the originals were all plastic as well. Still, for them to throw off EMI/RFI they'd have to be powered up, which only happens with the door open.
10-08-2017, 04:20 PM | #14 |
Rep 4,031
The OEM are $101 on Amazon.... I bought 2 sets. Getbmwparts are $122. Each to their own on price versus quality. I?m sure OEM are overpriced but I?m more comfortable with that.
10-08-2017, 06:14 PM | #15 |
Rep 488
Not trying to be facetious, but is this actually 100% verified? Perhaps they always have some level of current but not enough to light up?
10-11-2017, 09:23 AM | #17 | |
A family of bimmers
2747
Rep 7,742
afranke207.00 |
10-11-2017, 02:33 PM | #19 |
No 55mph
1622
Rep 8,476
Ya - mebbe he should have taken 3 min
10-11-2017, 03:05 PM | #20 |
Rep 1,500
I had cheap projectors from ebay and it was for sure messing up with my comfort access and signal from key fob when trying to start the car. I changed the key fob battery thinking it was that as well. Finally I ran into a thread here about them aftermarket projectors and took them off asap. Problems went away instantly. I have now OEM ones and not a single problem.
afranke207.00 |
10-11-2017, 05:07 PM | #21 | |
Rep 488
10-12-2017, 08:08 AM | #22 |
Rep 115
They are already the other way, that was when I first installed to test. Sent it to my brother who was looking at doing it on his Audi
