08-17-2017, 01:03 PM | #1 |
Rep 192
F30 330D engine belt squeal - 3 visits in and still not resolved...
This is driving me crazy! The engine makes that squeaky sound when at low RPM and unloaded - for example when pulling in and out of parking, slow traffic etc but only when the car has been out for a good run around and the engine is well up to temp.
Ive taken it 3 times in BMW Sytner to fix it but they can reproduce it. Any ideas what it might be so I can point them in the right direction? My bets are on engine belt but keen to hear your thoughts!! Video below... Last edited by ioannisG; 10-01-2017 at 07:50 AM.. |
08-17-2017, 01:19 PM | #2 |
Rep 1,696
I remember years ago I had a Fiat Marea (don't laugh it was wank) anyway I was skint and so I took it to my mates (mechanic, well sort of) he popped is head under the bonnet and sprayed a solution of soapy water on the belt that was squealing and it stopped. We knew it was the belt then, however the garage (a Fiat Dealer) couldn't fix it longer term and it drove me mad.
Now, I'm not saying that you should do something as primitive and I'm not sure that it may be a squealing belt but hopefully a decent garage should solve it. I hope you get it sorted |
08-23-2017, 08:21 AM | #6 |
Rep 192
So took the car to the dealer's today. Diagnosis is indeed alternator pulley having a bit of play in it. They will be replacing the alternator as well as the belts.
Also all four wheels (403Ms) have the dreaded centre hub corrosion so they are all getting replaced under warranty. Thankfully the warranty runs out in a few days (!!!) so just in time to get them sorted and hopefully they will be good for another year or two. |
Soul_Glo13342.00 |
08-23-2017, 08:41 AM | #8 | |
Rep 194
Current: 2022 Tesla Model 3 Performance.
Previous: F31 330d M Sport S Drive with ACS Sports Suspension and DMS remap. Remains the best car I've ever owned! |
08-23-2017, 08:58 AM | #9 |
Rep 192
Good result indeed! With a few days left in the warranty the car is basically like new. Had the transmission sump replaced last month due to a minor oil leak and now the wheels and alternator.
The only thing I haven't managed to get them to sort out is a creaking sound from the rear seats/parcel area when I go over my garage ramp. It feels like the body is flexing and the back seats/parcel shelf is rubbing on something causing it to creak badly. They have fobbed me off on this one unfortunately If anyone knows how to sort that one out DIY I'd be grateful!!! |
08-23-2017, 07:21 PM | #10 | |
Rep 548
Current: 2017 F31 335d M Sport - Estoril Blue, ACS Sports Suspension (Springs & Dampers), Black Grill, HK Sound & some other bits'n'pieces
Gone: 2015 F31 320d M Sport Xdrive Auto |
09-25-2017, 12:35 PM | #11 |
Rep 192
So the engine noise came back again. Turns out it wasn’t the alternator! Anyway after kicking up a fuss with BMW as the car now is out of its official warranty (auc only for the next 3 months) they got the car in for a check over. Luckily I recorded the issue on my phone again so there was no dispute. Turns out this time they will be replacing the water pump! This turns out to be an expensive squeal. At least the car is getting new parts so won’t complain.
Also they were refusing to replace the wheels due to the car being 4 days out of manufacturers warranty when I brought it in in August despite telling me otherwise when I dropped it in. I pointed out to them that this was due to their availability (I had called them 2 weeks before for an appointment) and that they missed the issue during the car end of warranty inspection and it’s service that happened a few weeks before. With a bit of pressure they agreed to replace. So the car is back in today to sort out both problems. Hopefully for good!
F30 330D
09-26-2017, 12:29 PM | #14 | |
Rep 163
Sorry, I know that's a little vague... Edit: http://f30.bimmerpost.com/forums/sho....php?t=1311296
2017 F20 M140i
09-27-2017, 01:46 AM | #15 | |
Rep 192
F30 330D
10-01-2017, 07:48 AM | #16 |
Rep 192
OK I've had enough with this issue! Its still not resolved
This will be the fourth time the car goes in. They have replaced the alternator, belt and water pump in the three visits its been in. Any ideas would be MUCH appreciated as BMW seems to have no clue whats wrong with it and they just keep replacing parts at random!
F30 330D
10-01-2017, 05:09 PM | #19 |
Rep 110
I remember i had it in my five series. Turned out to be the rubber grommet that mounts the air folter under the engine cover. Have a look to see if these are shot and maybe replace in the first instance
05-29-2018, 03:59 PM | #20 |
Rep 4
Cured
Hi, I had the exact same issue, squealing between 1-2k rpm, Car was sent into Douglas Park Hamilton, where they initially couldn't locate/ hear the noise, Following day a technician who had dealt with the issue previously on another F30
he diagnosed it as the Vibration Damper , replaced it, issue seems resolved. Part cost around £500 bangers , new belt also fitted. Replaced under warranty thankfully. Hope this shines some light on the problem should anyone else encounter it |
02-04-2019, 11:44 AM | #21 |
Rep 1
Hello, I had the same issue any other ideas??? I replace already the tensioner, serpentine belt???? help
It’s mostly only audible with the high temperature. i find this video maybe helps Last edited by AndresPG29; 02-13-2019 at 03:36 PM.. Reason: add video maybe helps |
02-04-2019, 11:52 AM | #22 | |
Rep 1,894
