11-25-2018, 09:44 AM | #1 |
Rep 22
Rear wheel bearing DIY help
Guys, I can't believe there is not a single video online for changing the rear wheel bearing in a DIY. I have found the TIS procedure for this, and it calls for removing the entire final drive. Is there no other way to get this half shaft out? Who by any chance has a copy of the Bentley manual to look for me in the wheel bearing change section ? Also if you know of an F30 repair manual that can be purchased online, in actual PDF format, let me know, the only reason i haven't bought it for this is that it's a paper copy only as far as i can tell.
11-25-2018, 10:45 AM | #3 |
Rep 22
thank you
thank you sir much appreciated, i will attempt to get the knuckle off instead and just get it re aligned it needs it anyway.
unless someone has a better idea. |
11-25-2018, 12:10 PM | #4 |
Rep 227
Drives: 2000 BMW E39 M5
I'd say that's a solid alternative plan. Not sure why the OEM procedure says to take out the entire final drive, seems like overkill to me.
2017 BMW 330i Sport Wagon - M-sport, EBII, THP, DHP
Supersprint cat-back exhaust (resonated, dual outlet) - H&R rear sway bar - ER charge pipe Waiting for: Bootmod3 - xHP Flashtool - xDelete |
