01-21-2019, 11:50 AM | #1 |
Rep 94
BMW Shops in the Hudson Valley NY?
Does anyone know of reputable BMW shops in the Hudson Valley NY area (Poughkeepsie, Fishkill, Kingston).
Thanks, Lu |
01-21-2019, 03:42 PM | #2 |
Rep 188
Drives: 2013 328i xDrive
What are you looking to be done?
01-21-2019, 06:21 PM | #3 |
Rep 94
The car is skipping a lot under medium and hard acceleration and I believe it has to do with fuel delivery. I changed spark plugs and gapped them correctly, changed intercooler and piping is tight. I need to clean the MAF as a third option but so far no ECL lights are on. I checked bimmer code and saw the MAF sensor notification on there. I just want a second opinion if I am still having an issue after I clean the MAF.
02-12-2019, 05:37 PM | #5 |
Rep 781
Drives: 2013 328i E92 LMB
Bavarian Rocket Science is supposed to be good but they're further north in Albany.
Based on your description it could be coils or maybe carbon buildup too, depending on your mileage. I hope it works out!
BMW CCA Member# 481791 Current: 2013 E92 328i LMB/Saddle Brown (1 of 21 for E92 LCI in that combo), 2018 F31 330xi AW/Saddle Brown Sold: 2011 1M BS/Black, 2008 E90 328xi AW/Beige, 2001 E46 330xi SG/Black |
02-19-2019, 06:08 AM | #6 |
Rep 188
Sorry Didn't get back to you, you could reach out to Lomotion in poughkeepsie, JJ has alot of experience with European cars, any thing else with be Jersey (AUTOcouture Motoring)
02-20-2019, 07:09 AM | #9 |
Rep 94
75K. I've gone through the coils and overall the system is working well. I took off the tune and have noticed no hesitations now during full throttle acceleration. I do believe either I have a fuel issue or boost leak, or maybe something with the tune (Jb Stage 1)
02-20-2019, 07:33 AM | #10 |
Rep 94
I'm also looking to clean out the intake valves; possible carbon buildup causing the hesitations. If this doesn't work, at least I'll have cleaner intake valves!
02-21-2019, 07:39 PM | #12 |
Rep 94
Have you guys heard of the tune acting this way? I would have thought the tune would only apply a single code set to the parameters of the car.... wasn't sure if you guys are aware of a tune not functioning as it should later during it's life. Any feedback would be great on this topic.
02-23-2019, 06:38 PM | #13 |
Rep 188
Sounds like your issues are pointing towards JB stage 1 (I'm assuming) or is it a JB4
02-24-2019, 10:33 AM | #14 | |
Rep 3,679
02-24-2019, 11:06 AM | #15 | ||||
Rep 94
I am going to clean out the intake runners to see if there is extensive carbon build up. Again, I am at 75K so why not anyway. But I am thinking it is a fuel issue, I just don't want to do the fuel injectors; 1 haven't done that before and 2 I can do it but it's time and also a lot of things to do too like also changing the seals on the filter which makes this job not so much fun to do right now I'm the winter. |
