12-02-2021, 09:57 PM | #1 |
Rep 101
F30 335i loud fan noise help
Hello everyone, today when I was driving back from an alignment, i noticed that my oil temp was dropping below the 245/250 degress it normally is at and dropped to literally half or maybe even less. The car is always properly warmed up and usually is around the 245 degree mark when driving. But today, I noticed that the oil temp was very low after driving for about 30 minutes and then my fan started blowing super loud. I was worried so i drove very slowly back home while the fan was blowing super loud. The car felt a little rough when I came to a stop a few times, but my rpms were perfectly fine. Im curious to see if this is a one time issue or if it could possibly be either the fan or water pump going out or anything else? This is the first time it has happened so I am a little worried it may happen again since I do daily drive the car about 20 miles a day. I have a 2013 335i sedan and has 51k miles on it. Please let me know if anyone has had a similar experience or if you know what the issue potentially could be. Any future maintenance tips would be appreciated as well, thank you!
12-02-2021, 11:18 PM | #3 |
Rep 101
Appreciate the feedback/help! Yea i was planning to maybe get a coolant flush as well as top off coolant and possibly replace the thermostat. Will also scan for codes tomorrow at my local shop. Thank you again!
12-03-2021, 10:42 AM | #4 |
Rep 7,620
I wouldn't do that all until you at least check/monitor the temp, otherwise you are just throwing parts at it. It could be a fan/control issue, but checking those first is key to try and gather more info.
12-03-2021, 06:29 PM | #5 |
Rep 101
Got it. I drove the car today in total about 60 miles and towards the last few miles of my commute, same thing happened. It was good pretty much all day and when I got close to home, i felt the car almost vibrating a little bit, then the oil temp dropped to about 190-200 and then the fan started to run super loud. Im also curious as to why the oil temp would be dropping so much and quickly after a full day of driving.
12-03-2021, 07:55 PM | #6 |
Rep 69
I would follow everything thejeremyman9 is saying. And will add that I had this problem with the additional issue of not being able to go over 3000 RPM in 1-3 gears (8AT). Not sure but may want to check this attached SIB. Also, there are other posts on this usually labeled something like, "first limp mode" or similar.
https://f30.bimmerpost.com/forums/sh...irst+limp+mode Note sure if your issue is completely the same, but sounds similar to others with high fan and oil temp staying in one spot (not working). Codes may or may not show if I remember correctly. Sorry for your issues. Mine got corrected with an ISTA update. Hasn't happened since.
2013 335i M-Sport || MPPK || M-LSD || M-BBK || VRSF CP - DP - FMIC || Bilstein B16 PSS10 || Vorshlag CPs
12-03-2021, 08:05 PM | #7 | |
Rep 101
Can I ask how you did the ISTA update or what is needed for the update to be done? Sorry, im brand new to this platform so Im still learning about this car and doing my best to research the forums a lot haha |
12-04-2021, 09:05 AM | #8 |
Rep 69
I had my independent shop in Orlando do it for me. They had a version past what the SIB required. I wasn't comfortable doing a whole version upgrade on my own. Some folks could definitely do it, I am just not at that level of comfort.
12-04-2021, 09:58 AM | #9 |
Rep 101
Got it, I was planning to do it at a local shop near me as well as I am not experienced nor do i have the equipment to do the update myself. I appreciate the info and help!
